Home » Archived » M2M (model-to-model transformation) » [ATL] allInstances() not delivering expected results, returns empty set instead
[ATL] allInstances() not delivering expected results, returns empty set instead [message #79662] Mon, 21 April 2008 06:42 Go to next message
Originally posted by: goetz.botterweck.lero.ie
WHAT I WANT TO DO
I want to define a helper function isVisible() based on allInstances().
PROBLEM
allInstances() and allInstancesFrom('modelname') do not return the
expected results, they return empty sets instead.
Or to be more specific: When I use the debugger to step to this
particular point in the ATL file, the watch variables are empty.
ADDITIONAL INFO
I tried both allInstances() and allInstancesFrom('modelname').
The models referenced by settingsIn, componentIn and scm are NOT empty
and DO contain instances of Setting, Component and SettingComponentMapping.
With other rules in the ATL file, the contents of the component model
are copied as expected (see rule "component"). So it look like the
settings in the launch config and filenames etc. are correct.
I assume that I made some simple mistake, but can't spot the problem.
Maybe is there some special behaviour of allInstances() that I have to
take into account?
Thanks for any hints,
Goetz
----------- ATL FILE ------------------
module generateComponentModel;
create componentOut : COMPONENTMETA from settingsIn : SETTINGSMETA,
componentIn : COMPONENTMETA, scm : SCMMETA;
-- Definition of visibility
helper context COMPONENTMETA!Component def : isVisible() : Boolean =
let allComponents : Sequence(COMPONENTMETA!Component) =
COMPONENTMETA!Component -> From('componentIn') in
let allSettings : Sequence(SETTINGSMETA!Setting) =
SETTINGSMETA!Setting -> allInstancesFrom('settingsIn') in
let allSettingComponentMappings
:Sequence(SCMMETA!SettingComponentMapping) =
SCMMETA!SettingComponentMapping -> allInstancesFrom('scm') in
-- ***** HERE ***********
-- Here I would like to define the isVisible() function based
-- on the helper variables allComponents, allSettings, and
-- allSettingComponentMappings
-- however these are all empty
true
-- Copy Rules
rule componentsModel {
from s : COMPONENTMETA!ComponentsModel (
s.isVisible()
to t : COMPONENTMETA!ComponentsModel mapsTo s (
name <- s.name,
components <- s.components
rule component {
from s : COMPONENTMETA!Component (
s.isVisible()
to t : COMPONENTMETA!Component mapsTo s (
name <- s.name
Re: [ATL] allInstances() not delivering expected results, returns empty set instead [message #79756 is a reply to message #79662] Tue, 22 April 2008 05:08 Go to previous messageGo to next message
Originally posted by: Hugo.Bruneliere.univ-nantes.fr
Hi Goetz,
You have to do
SETTINGSMETA!Setting.allInstancesFrom('settingsIn')
instead of
Hugo
Goetz Botterweck a écrit :
> WHAT I WANT TO DO
> PROBLEM
> ADDITIONAL INFO
> take into account?
> Goetz
> true
> -- Copy Rules
> s.isVisible()
> name <- s.name,
> rule component {
> s.isVisible()
> name <- s.name
Hugo Bruneliere - R&D Engineer
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssiniere
44322 Nantes Cedex 3 - France
office +33 2 51 12 58 10 /\ cell.+33 6 07 42 45 30
EMail: Hugo.Bruneliere@univ-nantes.fr
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [ATL] allInstances() fails with error "could not find operation From on MOF!EClass" [message #79813 is a reply to message #79756] Tue, 22 April 2008 16:08 Go to previous messageGo to next message
You are right, Hugo, but that did not solve the problem.
Hugo Bruneliere wrote:
> You have to do
> instead of
I am now using -> again.
However, I still have a problem: To use the latest version of ATL
(including potential bug fixes) I switched to the latest version from CVS.
Now executing the ATL transformation (See [1] below) fails with the
error message "could not find operation From on MOF!EClass having
supertypes: [MOF!EClassifier, OclType, OclAny]". However, the ATL
transformation does not contain a reference to From(). Could this be
caused by the implementation of allInstances()?
(see [2] for a full stack trace).
ADDITIONAL INFO
- COMPONENTMETA and SETTINGSMETA are independent ecore meta-models,
where SCMMETA is referencing the other two meta-models.
- Also switching on "Allow intermodel references" did not solve the problem.
Goetz
---- [1] ATL file -----------------------------------------
helper context COMPONENTMETA!ComponentsModel def : isVisible() : Boolean =
true
COMPONENTMETA!Component -> allInstances() in
SETTINGSMETA!Setting -> allInstances() in
let allSettingComponentMappings :
SCMMETA!SettingComponentMapping -> allInstances() in
-- here I would like to define the isVisible() function based on the
helper variables
-- allComponents, allSettings, and allSettingComponentMappings
true
s.isVisible()
name <- s.name,
rule component {
s.isVisible()
name <- s.name
---- [2] stack trace --------------------------------------
SEVERE: ****** BEGIN Stack Trace
SEVERE: message: ERROR: could not find operation From on MOF!EClass
having supertypes: [MOF!EClassifier, OclType, OclAny] (including Java
operations)
SEVERE: A.main() : ??#22 null
SEVERE: local variables = {self=generateComponentModel : ASMModule}
SEVERE: local stack = []
SEVERE: A.__matcher__() : ??#3 null
SEVERE: A.__matchcomponent() : ??#26 44:9-44:22
SEVERE: local variables = {s=componentIn!C1,
SEVERE: MCOMPONENTMETA!Component;.isVisible() : ??#4 14:3-14:50
SEVERE: local variables = {self=componentIn!C1}
SEVERE: ****** END Stack Trace
INFO: Execution terminated due to error (see launch configuration to
allow continuation after errors).
SEVERE: ERROR: could not find operation From on MOF!EClass having
supertypes: [MOF!EClassifier, OclType, OclAny] (including Java operations)
java.lang.RuntimeException: ERROR: could not find operation From on
MOF!EClass having supertypes: [MOF!EClassifier, OclType, OclAny]
org.eclipse.m2m.atl.engine.vm.SimpleDebugger.error(SimpleDeb ugger.java:195)
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:95)
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:91)
org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModelElement.invok e(ASMEMFModelElement.java:700)
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:240)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation .java:171)
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:143)
org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModelElement.invok e(ASMEMFModelElement.java:683)
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:338)
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:101)
org.eclipse.m2m.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:299)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:169)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:111)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:87)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:326)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:426)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.launch(AtlReg ularVM.java:398)
org.eclipse.m2m.atl.adt.launching.AtlLaunchConfigurationDele gate.launch(AtlLaunchConfigurationDelegate.java:42)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:759)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:608)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:899)
org.eclipse.debug.internal.ui.DebugUIPlugin$7.run(DebugUIPlu gin.java:1102)
INFO: /ATL Experiments/transformations/generateComponentModel.atl
Re: [ATL] allInstances() fails with error "could not find operation From on MOF!EClass" [message #79860 is a reply to message #79813] Wed, 23 April 2008 07:46 Go to previous messageGo to next message
Hi Goetz,
>> You have to do
>> instead of
You cannot use "->" because it is only for collections:
- "COMPONENTMETA!Component" is not a collection, it is a single
element which represents the COMPONENTMETA!Component type
- allInstances & allInstancesFrom are not operations on collections
You must write:
COMPONENTMETA!Component.allInstances()
COMPONENTMETA!Component.allInstancesFrom('InputModelName')
Are you using the standard VM or the new EMF VM?
Hugo
> ADDITIONAL INFO
> problem.
> Goetz
> true
> helper variables
> true
> s.isVisible()
> name <- s.name,
> rule component {
> s.isVisible()
> name <- s.name
> operations)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
Re: [ATL] allInstances() fails with error "could not find operation From on MOF!EClass" [message #79875 is a reply to message #79860] Wed, 23 April 2008 09:18 Go to previous messageGo to next message
> You must write:
D'oh! Yes of course. Fixed that. However, that does not solve the problem.
I assume you are referring to the run dialog setting
ATL Virtual Machine = (Regular VM | EMF specific VM)
I tried both. Does not solve the problem.
In both cases I get something like
An internal error occurred during: "Launching generateComponentModel".
operation not found: COMPONENTMETA!Component.From
Any hints?
Would it help if I attach some files from my project?
Thanks for your help,
Goetz
true
COMPONENTMETA!Component.allInstances() in
SETTINGSMETA!Setting.allInstances() in
SCMMETA!SettingComponentMapping.allInstances() in
helper variables
true
-- Copy Rules
s.isVisible()
name <- s.name,
rule component {
s.isVisible()
name <- s.name
operations)
operations)
Re: [ATL] allInstances() not delivering expected results, returns empty set instead [message #80221 is a reply to message #79662] Tue, 29 April 2008 03:17 Go to previous messageGo to next message
There was a bug in the debugger: contents of OrderedSet was not shown.
It is now corrected on branch R2_1_0_dev.
This problem does not impact normal execution though.
Note that you can also get the value of the OrderedSet using debug:
SETTINGSMETA!Setting.allInstancesFrom('settingsIn').debug('R esult of
allInstancesFrom')
This will display the value in the console during the execution.
Frédéric Jouault
> WHAT I WANT TO DO
> PROBLEM
> ADDITIONAL INFO
> take into account?
> Goetz
> true
> -- Copy Rules
> s.isVisible()
> name <- s.name,
> rule component {
> s.isVisible()
> name <- s.name
Re: [ATL] allInstances() not delivering expected results, returns empty set instead [message #80265 is a reply to message #80221] Tue, 29 April 2008 03:55 Go to previous messageGo to next message
Frédéric Jouault a écrit :
> Hello,
Now the bug has also been corrected on HEAD, so it will be fixed for
next ATL releases.
> allInstancesFrom')
> Frédéric Jouault
>> WHAT I WANT TO DO
>> PROBLEM
>> ADDITIONAL INFO
>> take into account?
>> Goetz
>> true
>> -- Copy Rules
>> s.isVisible()
>> name <- s.name,
>> rule component {
>> s.isVisible()
>> name <- s.name
Re: [ATL] allInstances() not delivering expected results (Problem solved) [message #80462 is a reply to message #80265] Tue, 29 April 2008 15:34 Go to previous message
William Piers wrote:
> Now the bug has also been corrected on HEAD, so it will be fixed for ...
I updated org.eclipse.m2m.atl.* from CVS.
The debugger now works as expected.
Thanks for the quick response,
Goetz
Previous Topic:[ATL] Multiple source patterns
Next Topic:Generate UML2 model using api
Current Time: Sun Aug 31 07:40:30 EDT 2025
Powered by FUDForum. Page generated in 0.05098 seconds
