Home » Archived » BIRT » DesignReader.openDesign exception SAXParseException can't find extension with ID
DesignReader.openDesign exception SAXParseException can't find extension with ID [message #79660] Thu, 06 October 2005 19:32 Go to next message
hello, I'm using eclipse 3.1, BIRT 1.0.1 source. I have a java project
that references the BIRT source, and when I try to run the java project
(as a java console application), it, I get the following error when I
try to load my report Template.
It seems the parser can't locate datasource information, when it is
parsing my report template. Any ideas?
Error.DesignFileException.INVALID_XML - 1 errors found!
1.) ( line = 7) org.xml.sax.SAXParseException (message : The extension
with ID 'org.eclipse.birt.report.data.oda.sampledb' is not found!)
org.eclipse.birt.report.model.parser.DesignReader.read(Desig nReader.java:101)
org.eclipse.birt.report.model.parser.DesignReader.read(Desig nReader.java:153)
org.eclipse.birt.report.model.core.DesignSession.openDesign( DesignSession.java:157)
org.eclipse.birt.report.model.api.SessionHandle.openDesign(S essionHandle.java:90)
Re: DesignReader.openDesign exception SAXParseException can't find extensionwith ID [message #79889 is a reply to message #79660] Fri, 07 October 2005 18:20 Go to previous messageGo to next message
Hi Mike,
You are seeing this error because, the report design uses the sampledb datasource type.
The sample db datasource is implemented as an oda extension in the following plugin
If you are writting your standalone application, you need to make sure the oda
extensions are available.
One way of doing this would be copying all related files and making them available at
runtime.
- Copy all the extensions from $/Viewer/plugins folder to a location
$BirtRuntime/plugins
- In you java application, set BIRT_HOME path to $BirtRuntime folder
System.setProperty( "BIRT_HOME", "$BirtRuntime" );
System.setProperty( "PROPERTY_RUN_UNDER_ECLIPSE", "false" );
Let me know if this works.
--Rima Kanguri
> at
> at
> at
> at
Re: DesignReader.openDesign exception SAXParseException can't find extensionwith ID [message #79904 is a reply to message #79889] Fri, 07 October 2005 18:36 Go to previous message
A minor correction
I used $Viewer to indicate $eclipse\plugins\org.eclipse.birt.report.viewer_1.0.1\birt
folder.
--Rima
Rima Kanguri wrote:
> Hi Mike,
> runtime.
> --Rima Kanguri
> > at
> > at
> > at
> > at
Previous Topic:how to group data by month with non-SQL datasource
Next Topic:adding Scriptable object to report
Current Time: Sun Aug 31 01:57:34 EDT 2025
Powered by FUDForum. Page generated in 0.02869 seconds
