Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] Incremental initialize capability in Teneo
[Teneo] Incremental initialize capability in Teneo [message #79588] |
Thu, 12 April 2007 06:11  |
Hi Martin,
As I mentioned that now I have nearly 14 emf models (which will increase
with time) and initialization takes time. Though I have started using
binary hibernate files, but still time is high.
With one emf model, “overall” time is nearly 1 sec.
As, at the moment I have to set all packages before calling initialize()
on HbDatastore i.e.
hbds.setEPackages(modelPackages); // array of 14 models
So just wondering, if it is possible to add incremental feature, where
initially user supplies only one or few models and once initialized,
then later one can add more models to the same session, and hibernate
mapping file can be broken per model.
I think this concept may be difficult to implement due to hibernate. But
just a thought.
Just wondering about your reactions ;-)
- Parvez
Re: [Teneo] Incremental initialize capability in Teneo [message #79633 is a reply to message #79588] |
Thu, 12 April 2007 07:46   |
Hi Parvez,
It sounds like a nice feature. Do the new epackages refer to the other (already existing) epackages?
If not then it should be possible.
gr. Martin
PC wrote:
> Hi Martin,
> on HbDatastore i.e.
> just a thought.
> - Parvez
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Incremental initialize capability in Teneo [message #79648 is a reply to message #79633] |
Tue, 10 April 2007 08:06   |
Hi Martin,
Yes, in my case, new packages do refers existing packages (inheritance
or otherwise). But I “think" if initialization can be done in proper
order (user’s responsibility) i.e. if a package refers to existing
package which already has been loaded/initialized then it should not be
a problem or will it be?
- Parvez
Martin Taal wrote:
> Hi Parvez,
> (already existing) epackages? If not then it should be possible.
> gr. Martin
> PC wrote:
>> Hi Martin,
>> increase with time) and initialization takes time. Though I have
>> started using binary hibernate files, but still time is high.
>> initialize() on HbDatastore i.e.
>> But just a thought.
>> - Parvez
Re: [Teneo] Incremental initialize capability in Teneo [message #81490 is a reply to message #79648] |
Mon, 30 April 2007 05:18   |
Hi Martin,
Just wondering if you have any further thoughts on it.
Thanks.
Parvez
PC wrote:
> Hi Martin,
> - Parvez
> Martin Taal wrote:
>> Hi Parvez,
>> gr. Martin
>> PC wrote:
>>> Hi Martin,
>>> where initially user supplies only one or few models and once
>>> initialized, then later one can add more models to the same session,
>>> and hibernate mapping file can be broken per model.
>>> But just a thought.
>>> - Parvez
Re: [Teneo] Incremental initialize capability in Teneo [message #81555 is a reply to message #81490] |
Mon, 30 April 2007 07:11   |
Hi Parvez,
Hmmm yes sorry, I missed your answer.
Which part of the initialization takes most time?
I am not sure if hibernate supports incremental loading, did you test it?
Afaics the challenge is that if there are relations between the current and the new parts of the
model that the parts of the current relational schema have to be updated because foreign keys can be
created at the opposite side of the relation (if A has a list of B's then a foreign key column can
be created in B to refer to A).
gr. martin
PC wrote:
> Hi Martin,
> Thanks.
> Parvez
> PC wrote:
>> Hi Martin,
>> be a problem or will it be?
>> - Parvez
>> Martin Taal wrote:
>>> Hi Parvez,
>>> other (already existing) epackages? If not then it should be possible.
>>> gr. Martin
>>> PC wrote:
>>>> Hi Martin,
>>>> But just a thought.
>>>> - Parvez
The Netherlands
Re: [Teneo] Incremental initialize capability in Teneo [message #81570 is a reply to message #81555] |
Mon, 30 April 2007 08:20  |
Hi Martin,
Ok, I see your point regarding work involved in schema updation. Anyway,
I am also sure that hibernate doesn't support incremental build up, so
it won't be possible to implement this because of hibernate.
Thanks.
- Parvez
Martin Taal wrote:
> Hi Parvez,
> and the new parts of the model that the parts of the current relational
> schema have to be updated because foreign keys can be created at the
> column can be created in B to refer to A).
> gr. martin
> PC wrote:
>> Hi Martin,
>> Thanks.
>> Parvez
>> PC wrote:
>>> Hi Martin,
>>> (inheritance or otherwise). But I “think" if initialization can be
>>> done in proper order (user’s responsibility) i.e. if a package refers
>>> to existing package which already has been loaded/initialized then it
>>> should not be a problem or will it be?
>>> - Parvez
>>> Martin Taal wrote:
>>>> Hi Parvez,
>>>> gr. Martin
>>>> PC wrote:
>>>>> Hi Martin,
>>>>> session, and hibernate mapping file can be broken per model.
>>>>> hibernate. But just a thought.
>>>>> - Parvez
Re: [Teneo] Incremental initialize capability in Teneo [message #604689 is a reply to message #79588] |
Hi Parvez,
gr. Martin
PC wrote:
> Hi Martin,
> on HbDatastore i.e.
> just a thought.
> - Parvez
The Netherlands
Re: [Teneo] Incremental initialize capability in Teneo [message #604693 is a reply to message #79633] |
Hi Martin,
- Parvez
Martin Taal wrote:
> Hi Parvez,
> gr. Martin
> PC wrote:
>> Hi Martin,
>> But just a thought.
>> - Parvez
Re: [Teneo] Incremental initialize capability in Teneo [message #605141 is a reply to message #79648] |
Hi Martin,
Thanks.
Parvez
PC wrote:
> Hi Martin,
> - Parvez
> Martin Taal wrote:
>> Hi Parvez,
>> gr. Martin
>> PC wrote:
>>> Hi Martin,
>>> But just a thought.
>>> - Parvez
Re: [Teneo] Incremental initialize capability in Teneo [message #605157 is a reply to message #81490] |
Hi Parvez,
gr. martin
PC wrote:
> Hi Martin,
> Thanks.
> Parvez
> PC wrote:
>> Hi Martin,
>> - Parvez
>> Martin Taal wrote:
>>> Hi Parvez,
>>> gr. Martin
>>> PC wrote:
>>>> Hi Martin,
>>>> But just a thought.
>>>> - Parvez
The Netherlands
Re: [Teneo] Incremental initialize capability in Teneo [message #605159 is a reply to message #81555] |
Hi Martin,
Thanks.
- Parvez
Martin Taal wrote:
> Hi Parvez,
> gr. martin
> PC wrote:
>> Hi Martin,
>> Thanks.
>> Parvez
>> PC wrote:
>>> Hi Martin,
>>> - Parvez
>>> Martin Taal wrote:
>>>> Hi Parvez,
>>>> gr. Martin
>>>> PC wrote:
>>>>> Hi Martin,
>>>>> - Parvez
Current Time: Sat Jul 26 14:11:23 EDT 2025
Powered by FUDForum. Page generated in 0.07210 seconds
