Home » Language IDEs » C / C++ IDE (CDT) » Can I remove build targets
Can I remove build targets [message #79574] Mon, 01 September 2003 17:26 Go to next message
Originally posted by: bmnews.blueyonder.co.uk
Newbie here I'm afraid!
I'm using CDT 1.1
Is there any way to remove entries from the additional make targets list for
a project? I've got some targets which I added, then I modified the
makefile so they are no longer valid. I've hunted around for an XML file or
similar, but can't find where this list is stored.
TIA
CT
Re: Can I remove build targets [message #79592 is a reply to message #79574] Tue, 02 September 2003 09:26 Go to previous messageGo to next message
Originally posted by: kschallmo.logopak.de
> I'm using CDT 1.1
> TIA
> CT
here is the way to do it
1 open your c/c++ project.
2 open the menu item Windows->show view->other
3 select c->make targets
.. on the right side you will see a window with the title "Make Targets"
.. select the target you like to delete and click the right mouse button
.. select "Delete" and thats it.
best regards
Kurt
Re: Can I remove build targets [message #79607 is a reply to message #79592] Tue, 02 September 2003 15:10 Go to previous message
CT
Previous Topic:JBuilder to Eclipse Migration
Next Topic:Debug run won't stop on breakpoint
Current Time: Mon Jul 14 10:44:22 EDT 2025
Powered by FUDForum. Page generated in 0.12487 seconds
