Home » Language IDEs » Java Development Tools (JDT) » How to repeat JUnit TestCase for multiple data sets
How to repeat JUnit TestCase for multiple data sets [message #79475] Wed, 23 July 2003 17:02 Go to next message
Is there a way of running a testcase repeatedly for a database full of
fixtures? If you have a single class for which you want to test with an
arbetrarily large number of test data sets that are maintained outside the
implementation of TestCase for that class, how would it be done?
1. How do you pass the dataset to the setup method of the TestCase
implementation?
2. Where within the JUnit framework in Eclipse would you iterate through the
fixture data, e.g., retrieve the fixture data from the data source and build
an object to pass to the TestCase implementation for each fixture?
Matt King
Accessibility End UserAdvocate
IBM Business Transformation/CIO
Phone: (719) 520-3006, Tie line: 8-656-3006
Internet: mattking@us.ibm.com
Re: How to repeat JUnit TestCase for multiple data sets [message #88759 is a reply to message #79475] Sun, 24 August 2003 16:17 Go to previous message
Originally posted by: m_heisterberg.hotmail.com
You might want to look at the DBUnit framework - http://www.dbunit.org.
I haven't used it personally but it looks good.
lekkim
> implementation?
Previous Topic:Can files of same package be in different jars!
Next Topic:CVS - cvsignore not working!
Current Time: Mon Jul 21 22:15:23 EDT 2025
Powered by FUDForum. Page generated in 0.03669 seconds
