Home » Archived » M2M (model-to-model transformation) » [QVTO]Incompatible input type 'modelparam::ResourceEObject', expected 'uml::Model'
[QVTO]Incompatible input type 'modelparam::ResourceEObject', expected 'uml::Model' [message #79451] |
Wed, 16 April 2008 18:37  |
Originally posted by: comouraf-lixo.yahoo.fr
I'm getting this error, when I create a new run configuration for my
transformation:
'uml::Model'
If I provide a plain uml model, everything works fine, but as soon as I
apply a profile (in fact, when I apply a stereotype), the above message is
displayed. Looking at the xml code, we can see that applying a given
stereotype causes the xml root element to change from <uml:model/> to
<xmi:XMI/> in order to accommodate the stereotype applications (which are in
the same level as uml:model).
Any idea on how to solve this problem ?
César
ps: just in case, I use an M6 build.
Re: [QVTO]Incompatible input type 'modelparam::ResourceEObject', expected 'uml::Model' [message #79466 is a reply to message #79451] |
Thu, 17 April 2008 07:17   |
Hi César,
Could you please make sure you use signature-less main() entry operation
in your
transformation? I think this is the cause.
Anyway, it looks like you have hit a bug :)
/Radek
On Thu, 17 Apr 2008 00:37:28 +0200, kaiserlautern <comouraf-lixo@yahoo.fr>
wrote:
> transformation:
> 'uml::Model'
> is displayed. Looking at the xml code, we can see that applying a given
> are in the same level as uml:model).
> César
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: [QVTO]Incompatible input type 'modelparam::ResourceEObject', expected 'uml::Model' [message #79506 is a reply to message #79466] |
Thu, 17 April 2008 16:17  |
Hi, Radek,
You're right. Using a main without parameters solves the problem. Thanks.
César
"Radek Dvorak" <radek.dvorak@borland.com> a écrit dans le message de
news:op.t9q5nowwhj1a1g@czprl-rdvorak2.emea.borl.net...
> Hi César,
> in your
> /Radek
> wrote:
>> transformation:
>> 'uml::Model'
>> Thanks,
>> César
Current Time: Sat Jul 26 03:51:11 EDT 2025
Powered by FUDForum. Page generated in 0.05814 seconds
