xman plugin not detected. [message #79445] |
Wed, 23 July 2003 14:15  |
Originally posted by: xraymond2003.yahoo.ca
Hi all,
I tried to install xman (xml editor) plugin for my eclipse 2.1.0. But i
couldn't get it to worked.
I simply extracted the zip file(org.xmen_0.4.2.1.zip) to the eclipse plugin
directory, everything looks fine except that i couldn't find the plugin
setting for xman in the window/preferences.
any help is appreciated,
ray.
Re: xman plugin not detected. [message #79822 is a reply to message #79716] |
Thu, 24 July 2003 11:49   |
Thanks for the reply.
I commented out the dependency, the X-Men XML Editor option became available
on the preferences, but when I click on it, I got this error,
Unable to create the selected preference page.
Reason:
Plug-in org.xmen was unable to load class
org.xmen.internal.ui.preferences.EditorPreferencePage.
I checked the class, it is there and also in the right path.
thanks,
ray.
P.S. i'm also running 2.1.1 now.
"Kalab, Peter" <kalabp@netscape.net> wrote in message
news:bfooqk$vch$1@eclipse.org...
> I noticed that the current Xmen plugin has a dependency on org.eclipse.xsd
> package (look in the plugin.xml file for Xmen); this package does not
exist
> in my Eclipse 2.1.1 installation (I install the core and JDT download, not
> the full plugin development version). I commented out that dependency and
> X-men appears to work.
> <requires>
> <import plugin="org.eclipse.core.resources"/>
> <import plugin="org.eclipse.ui"/>
> <import plugin="org.eclipse.swt"/>
> <import plugin="org.eclipse.core.boot"/>
> <import plugin="org.eclipse.core.runtime"/>
> <import plugin="org.apache.xerces"/>
> <!-- <import plugin="org.eclipse.xsd"/> -->
> </requires>
> Peter
> "Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
> news:bfnhls$nie$1@eclipse.org...
> > Anything in your .log file?
> > Does xman work with 2.1.0?
> > Have you asked the provider of the xman plugin for help?
> > Darins
> > "exquisitus" <xraymond2003@yahoo.ca> wrote in message
> > news:bfmjcf$mjl$1@eclipse.org...
> > > Hi all,
i
> > plugin
plugin
> > > ray.
Re: xman plugin not detected. [message #79867 is a reply to message #79837] |
Thu, 24 July 2003 13:20  |
Sigh... turned out that the latest X-Men has problem with Eclipse. I tried
version .37, it worked fine.
thanks for all the kind input,
ray.
"Michael R Head" <burner@zclipse.org> wrote in message
news:pan.2003.07.24.16.02.21.737738@zclipse.org...
> On Thu, 24 Jul 2003 10:01:27 -0400, Kalab, Peter wrote:
> > <requires>
> > </requires>
> Instead of doing this, why not just get the xsd plugins? I would expect
> this to undoubtedly to break the plugin (though I've never used Xmen)
> http://www.eclipse.org/xsd/
> > Peter
> http://zclipse.org
FUDForum. Page generated in 0.03726 seconds
