Home » Language IDEs » Java Development Tools (JDT) » xman plugin not detected.
xman plugin not detected. [message #79445] Wed, 23 July 2003 14:15 Go to next message
Originally posted by: xraymond2003.yahoo.ca
Hi all,
I tried to install xman (xml editor) plugin for my eclipse 2.1.0. But i
couldn't get it to worked.
I simply extracted the zip file(org.xmen_0.4.2.1.zip) to the eclipse plugin
directory, everything looks fine except that i couldn't find the plugin
setting for xman in the window/preferences.
any help is appreciated,
ray.
Re: xman plugin not detected. [message #79593 is a reply to message #79445] Wed, 23 July 2003 22:56 Go to previous messageGo to next message
Anything in your .log file?
Does xman work with 2.1.0?
Have you asked the provider of the xman plugin for help?
Darins
"exquisitus" <xraymond2003@yahoo.ca> wrote in message
news:bfmjcf$mjl$1@eclipse.org...
> Hi all,
plugin
> ray.
Re: xman plugin not detected. [message #79716 is a reply to message #79593] Thu, 24 July 2003 10:01 Go to previous messageGo to next message
Originally posted by: kalabp.netscape.net
I noticed that the current Xmen plugin has a dependency on org.eclipse.xsd
package (look in the plugin.xml file for Xmen); this package does not exist
in my Eclipse 2.1.1 installation (I install the core and JDT download, not
the full plugin development version). I commented out that dependency and
X-men appears to work.
<requires>
<import plugin="org.eclipse.core.resources"/>
<import plugin="org.eclipse.ui"/>
<import plugin="org.eclipse.swt"/>
<import plugin="org.eclipse.core.boot"/>
<import plugin="org.eclipse.core.runtime"/>
<import plugin="org.apache.xerces"/>
<!-- <import plugin="org.eclipse.xsd"/> -->
</requires>
Peter
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:bfnhls$nie$1@eclipse.org...
> Darins
> > Hi all,
> plugin
> > ray.
Re: xman plugin not detected. [message #79822 is a reply to message #79716] Thu, 24 July 2003 11:49 Go to previous messageGo to next message
Thanks for the reply.
I commented out the dependency, the X-Men XML Editor option became available
on the preferences, but when I click on it, I got this error,
Unable to create the selected preference page.
Reason:
Plug-in org.xmen was unable to load class
org.xmen.internal.ui.preferences.EditorPreferencePage.
I checked the class, it is there and also in the right path.
thanks,
ray.
P.S. i'm also running 2.1.1 now.
"Kalab, Peter" <kalabp@netscape.net> wrote in message
news:bfooqk$vch$1@eclipse.org...
exist
> <requires>
> </requires>
> Peter
> > Darins
> > > Hi all,
i
> > plugin
plugin
> > > ray.
Re: xman plugin not detected. [message #79837 is a reply to message #79716] Thu, 24 July 2003 12:02 Go to previous messageGo to next message
Originally posted by: burner.zclipse.org
On Thu, 24 Jul 2003 10:01:27 -0400, Kalab, Peter wrote:
> <requires>
> </requires>
Instead of doing this, why not just get the xsd plugins? I would expect
this to undoubtedly to break the plugin (though I've never used Xmen)
http://www.eclipse.org/xsd/
> Peter
http://zclipse.org
Re: xman plugin not detected. [message #79852 is a reply to message #79837] Thu, 24 July 2003 12:16 Go to previous messageGo to next message
I actually did grap the xsd (version 1.1.0. XSD Runtime) afterwards, but I
ran into the same problem, the preferences again couldn't detect X-Men. I
checked all the require this time, but they all look alright.
any thoughts?
thanks,
ray.
"Michael R Head" <burner@zclipse.org> wrote in message
news:pan.2003.07.24.16.02.21.737738@zclipse.org...
> > <requires>
> > </requires>
> > Peter
> http://zclipse.org
Re: xman plugin not detected. [message #79867 is a reply to message #79837] Thu, 24 July 2003 13:20 Go to previous message
Sigh... turned out that the latest X-Men has problem with Eclipse. I tried
version .37, it worked fine.
thanks for all the kind input,
ray.
> > <requires>
> > </requires>
> > Peter
> http://zclipse.org
Previous Topic:JRE detection troubles - patch available for M2
Next Topic:Re: Programmatically launch Java
Current Time: Fri Jul 18 17:16:46 EDT 2025
Powered by FUDForum. Page generated in 0.04484 seconds
