PHP missing since EMF update [message #79418] |
Wed, 03 September 2008 04:47  |
Originally posted by: dafish.soundtrack-board.de
Eclipse showed an EMF update yesterday and I installed it. After the
neccesary restart, the PHP perspective is gone and I'm unable to get it
back.
I've tried to reinstall PHP both through the Update feature and by
downloading the latest 1.0.3 release. Nothing worked.
Any chance of getting my "old" configuration back?
Marcus
Re: PHP missing since EMF update [message #79447 is a reply to message #79433] |
Wed, 03 September 2008 12:15   |
Originally posted by: codeslave.ca.ibm.com
PDT 1.0.3 is targeted for Eclipse 3.3, WTP 2.0, and EMF 2.3.
http://download.eclipse.org/tools/pdt/downloads/release.php? release=R20080603
If you're using something newer, YMMV.
If you want a PDT that works with Eclipse 3.4, use the latest Nightly
build of PDT 2.0.
If you want one that works with Eclipse 3.5, you'll have to wait until
2.0 is released.The latest EMF build (from yesterday) is for Eclipse 3.5
-- there are no guarantees that the still-in-progress Eclipse 3.5 + EMF
2.5 will work for the still-in-progress PDT 2.0 (which is being built
with Eclipse 3.4, not 3.5.)
If you want to develop PHP without having to worry about Eclipse
version, WTP version, or EMF version, get phpeclipse. It may not be
quite as feature-rich, but it's MUCH easier to install. :)
Nick
Ed Merks wrote:
> Marcus,
> Try running with "-clean -debug" and have a close look at
> <workspace>/.metadata/.log. You might want to delete this file first so
> you create a fresh new one. With the -debug flag, there should be
> detailed messages about why a feature or plugin fails to activate
> (typically because of version range restrictions). Which Eclipse are
> you on and which EMF did you update to?
> Marcus Stöhr wrote:
>> it back.
>> Best regards,
>> Marcus
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
Re: PHP missing since EMF update [message #79550 is a reply to message #79535] |
Thu, 04 September 2008 14:31   |
Marcus,
EMF 2.4 targets Eclipse 3.4 and doesn't work with Eclipse 3.3. You'll
need EMF 2.3 for it to work with Eclipse 3.3.
Marcus Stöhr wrote:
> Ed Merks schrieb:
>> Marcus,
>> so you create a fresh new one. With the -debug flag, there should be
>> Marcus Stöhr wrote:
>>> Hi,
>>> it back.
>>> Best regards,
>>> Marcus
> Ed,
> thanks for the hint with the .log-File. Some of the entries indicate
> problems with EMF:
> !ENTRY org.eclipse.osgi 2 0 2008-09-04 09:17:51.212
> !MESSAGE One or more bundles are not resolved because the following
> root constraints are not resolved:
> !SUBENTRY 1 org.eclipse.osgi 2 0 2008-09-04 09:17:51.212
> !MESSAGE Bundle
> update@plugins/org.eclipse.wst.web.ui_1.1.101.v200706071630.jar was
> not resolved.
> !SUBENTRY 2 org.eclipse.wst.web.ui 2 0 2008-09-04 09:17:51.212
> !MESSAGE Missing required bundle org.eclipse.emf.ecore_[2.2.0,2.4.0).
> !MESSAGE Bundle
> update@plugins/org.eclipse.emf.ecore.change.edit_2.4.0.v200808251517.jar
> was not resolved.
> !SUBENTRY 2 org.eclipse.emf.ecore.change.edit 2 0 2008-09-04 09:17:51.213
> !MESSAGE Missing required bundle org.eclipse.core.runtime_[3.4.0,4.0.0).
> !SUBENTRY 1 org.eclipse.osgi 2 0 2008-09-04 09:17:51.213
> This goes on to the PDT feature:
> !MESSAGE Bundle
> update@plugins/org.eclipse.php.core_1.0.3.v20080603.jar [181] was not
> resolved.
> !SUBENTRY 2 org.eclipse.php.core 2 0 2008-09-04 09:17:51.230
> !MESSAGE Missing required bundle org.eclipse.wst.sse.core_0.0.0.
> !MESSAGE Missing required bundle org.eclipse.wst.html.core_0.0.0.
> !MESSAGE Missing required bundle org.eclipse.wst.xml.core_0.0.0.
> !MESSAGE Missing required bundle org.eclipse.wst.validation_0.0.0.
> !MESSAGE Missing required bundle org.eclipse.wst.common.frameworks_0.0.0.
> !MESSAGE Missing required bundle org.eclipse.jem.util_0.0.0.
> !SUBENTRY 1 org.eclipse.osgi 2 0 2008-09-04 09:17:51.230
> I'm using latest 3.3 and EMF is version 2.4.1 now.
Re: PHP missing since EMF update [message #79623 is a reply to message #79579] |
Fri, 05 September 2008 13:19  |
Ed Merks schrieb:
> Marcus,
> Yes, it seems kind of unhelpful to suggest/allow choices that are known
> to have unsatisfiable constraints...
> Marcus Stöhr wrote:
>> Ed Merks schrieb:
>>> Marcus,
>>> You'll need EMF 2.3 for it to work with Eclipse 3.3.
>> Ed,
>> this explains my problems. But I'm wondering why Eclipse would show
>> EMF 2.4 in my Eclipse 3.3 environment?
>> But thanks for the information and I'll try to fix my installation. :)
>> -Marcus
However,
I did it and made the step to Ganymede today and beside some annoyances,
everything works as expected.
FUDForum. Page generated in 0.03660 seconds
