RAP application problems. [message #79400] |
Thu, 27 March 2008 02:48  |
This is a query regarding RAP demo application.
We have a RAP application which has been developed taking RAP demo as the
reference.I tried the new project set serveletbridge bundles and the newly
built war is not getting deployed.The logs are full of bundle exceptions.
So i thought of cross-checking with the RAP demo application.
I installed RAP target platform and tried running the rap demo application
on the jetty server using the eclipse RAP launcger and it worked.
When i tried to deploy the pre-built rapdemo.war application on to a
tomcat server, i tried it on 2 versions...5.5 and 6.0.16.The pre-built
rapdemo.war file worked on tomcat_5.5 while it failed on 6.0.16.
On 6.0.16, i get a bridegservlet error.When i look into the logs,is
referring to
" org.osgi.framework.BundleException: The activator
org.eclipse.equinox.http.servletbridge.internal.Activator for bundle
org.eclipse.equinox.http.servletbridge is invalid ".
I thought of building it using the rap.demo.feature project.
When i tried to build the rapdemo.war using the project set and when
deployed, the deployment logs showed a lot of bundle exceptions, referring
to unresolved javax.servlet..packages.
When I tried the same demo some time back with the required servletbridge
bundles .psf project and it was working fine.Yesterday, i tried to
download the latest and everything went haywire.
What migtht be the problem, has it got to do with tomcat versions, or
javax.servlet package version constraints.Everything was working fine, all
of a sudden, these problems cropped up.Do help me in this regard.
The following is seen, when i invoke the url:
HTTP Status 404 - BridgeServlet: /rapdemo/rap
type Status report
message BridgeServlet: /rapdemo/rap
description The requested resource (BridgeServlet: /rapdemo/rap) is not
available.
LOG INFORMATION.
!SESSION 2008-03-27 11:25:54.177
eclipse.buildId=unknown
java.version=1.5.0_07
Command-line arguments: -console
!ENTRY org.eclipse.equinox.http.servletbridge 4 0 2008-03-27 11:25:54.177
!MESSAGE
!STACK 0
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:350)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1118)
org.eclipse.osgi.framework.internal.core.PackageAdminImpl.re sumeBundles(PackageAdminImpl.java:268)
org.eclipse.osgi.framework.internal.core.PackageAdminImpl.do ResolveBundles(PackageAdminImpl.java:236)
org.eclipse.osgi.framework.internal.core.PackageAdminImpl$1. run(PackageAdminImpl.java:164)
at java.lang.Thread.run(Thread.java:595)
Caused by: java.lang.Error: Unresolved compilation problem:
The type javax.servlet.http.HttpServlet cannot be resolved. It is
indirectly referenced from required .class files
org.eclipse.equinox.http.servletbridge.internal.Activator.<init >(Activator.java:25)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAccessorImpl.java:39)
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:4 94)
at java.lang.Class.newInstance0(Class.java:350)
at java.lang.Class.newInstance(Class.java:303)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:136)
... 8 more
Root exception:
!ENTRY org.eclipse.core.runtime 2 0 2008-03-27 11:25:54.505
!MESSAGE Authorization infrastructure
(org.eclipse.core.runtime.compatibility.auth) not installed.
!STACK 0
java.lang.NoClassDefFoundError:
org/eclipse/core/internal/runtime/auth/AuthorizationHandler
org.eclipse.core.internal.runtime.InternalPlatform.initializ eAuthorizationHandler(InternalPlatform.java:603)
org.eclipse.core.internal.runtime.InternalPlatform.start(Int ernalPlatform.java:745)
org.eclipse.core.internal.runtime.PlatformActivator.start(Pl atformActivator.java:31)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
org.eclipse.osgi.framework.internal.core.MultiSourcePackage. loadClass(MultiSourcePackage.java:31)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:405)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319 )
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:161)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:501)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:471)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:430)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:413)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:408)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:134)
org.eclipse.update.internal.configurator.ConfigurationActiva tor.installBundles(ConfigurationActivator.java:218)
org.eclipse.update.internal.configurator.ConfigurationActiva tor.start(ConfigurationActivator.java:82)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:634)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:508)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:282)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:468)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:195)
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:297)
!ENTRY org.eclipse.equinox.http.servletbridge 4 0 2008-03-27 11:25:54.708
!MESSAGE
!STACK 0
... 10 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2008-03-27 11:25:54.708
!MESSAGE Bundle
initial@reference :file:plugins/org.eclipse.equinox.http.servletbridge_1.0.0.2 00803271123.jar/
[3] is not active.
Re: RAP application problems. [message #79942 is a reply to message #79400] |
Fri, 28 March 2008 12:30  |
Originally posted by: fappel.innoopract.com
the demo war for download is pretty outdated and indeed doesn't run with
tomcat 6.x. We should probably remove it or replace it with a newer
version of it. Please check that all the bundles you are referring to in
your feature.xml are available in the target. The RAP target is
currently only a minimalistic development-time target. So often the
update-configurator is included in the feature, but it's not available
in the target so the deployed war does not work properly.
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Murali Krishna [mailto:murakris@gmail.com]
Bereitgestellt: Donnerstag, 27. März 2008 07:48
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: RAP application problems.
Betreff: RAP application problems.
the reference.I tried the new project set serveletbridge bundles and the
newly built war is not getting deployed.The logs are full of bundle
exceptions.
application on the jetty server using the eclipse RAP launcger and it
worked.
referring to
referring to unresolved javax.servlet..packages.
servletbridge bundles .psf project and it was working fine.Yesterday, i
tried to download the latest and everything went haywire.
all of a sudden, these problems cropped up.Do help me in this regard.
type Status report
available.
LOG INFORMATION.
11:25:54.177
!MESSAGE
!STACK 0
st.java:346)
undle.java:350)
k.java:1118)
dminImpl.java:164)
is
or.java:25)
Method)
... 8 more
Root exception:
is
or.java:25)
Method)
st.java:346)
undle.java:350)
k.java:1118)
dminImpl.java:164)
!STACK 0
m.java:745)
tor.java:31)
st.java:346)
ndle.java:260)
dleLoader.java:340)
ader.java:369)
ader.java:357)
thManager.java:501)
dleLoader.java:340)
ader.java:369)
ader.java:357)
ader.java:289)
..java:227)
st.java:346)
ndle.java:260)
st.java:346)
undle.java:350)
k.java:1118)
ger.java:195)
nager.java:297)
11:25:54.708
!MESSAGE
!STACK 0
st.java:346)
undle.java:350)
k.java:1118)
ger.java:195)
nager.java:297)
is
or.java:25)
Method)
... 10 more
Root exception:
is
or.java:25)
Method)
st.java:346)
undle.java:350)
k.java:1118)
ger.java:195)
nager.java:297)
!MESSAGE Bundle
initial@reference:file:plugins/org.eclipse.equinox.http.servletbridge_1.
0.0.200803271123.jar/
[3] is not active.
FUDForum. Page generated in 0.03367 seconds
