Home » Eclipse Projects » GEF » Connections clipping and "re-anchoring"
Connections clipping and "re-anchoring" [message #79277] Wed, 14 May 2003 12:04 Go to next message
Originally posted by: bgrieder.nospam.thanks
I have connections going from nodes inside a container to nodes inside
the same container and inside a different container.
When a container is resized, and an inside node is hidden (not in the
clipping region), connections are still visible outside the clipping
region.I understand the basic issue: connections are children of the
ConnectionLayer which is attached to the root element, not the container.
Still, I wish to change the behaviour and wonders what is the best
approach (reparenting the connection, moving anchors, etc....). I have
browsed thru this group and found a note from Randy Hudson saying:
QUOTE
This is by design. If you want to change the figure which parents the
connection to be some layer in your container, see
AbstractConnectionEditPart#activateFigure(). This determines the
connection's parent, and therefore its clipping.
UNQUOTE
I have two issues with this note:
1- I do not fully understand "and therefore its clipping"; can someone
elaborate on the inner workings
2- I believe the "reparenting" approach solves the issue for two nodes
connected inside the same container, but not accross containers.
Thanks for you help.
bruno
Re: Connections clipping and "re-anchoring" [message #79366 is a reply to message #79277] Wed, 14 May 2003 10:40 Go to previous messageGo to next message
What behavior do you want for:
1) Connection within a container where only one of the two nodes is visible
2) Connection accross 2 containers, where one node is not visible.
I assume your containers allow for scrolling, otherwise the children would
always be visible. What type of application are you writing?
"Bruno Grieder" <bgrieder@nospam.thanks> wrote in message
news:b9tic3$mqr$2@rogue.oti.com...
> QUOTE
> UNQUOTE
> bruno
Re: Connections clipping and "re-anchoring" [message #79411 is a reply to message #79366] Wed, 14 May 2003 13:26 Go to previous messageGo to next message
Hi Randy,
(my answers are inline)
Thnks for your help
The connection should only be visible in the "clipping region" of the
container, i.e, the connection should "stop" at the container border
which is the closest to the hidden anchor.
Same thing: the connection should stop at the border of the container
parent to the "hidden node", which is the closest border to the anchor
of the "hidden node".
> always be visible.
Yes - the containers implement a ScrollPane
Some sort of process modeling tool
>>Hi,
>>QUOTE
>>UNQUOTE
>>bruno
Re: Connections clipping and "re-anchoring" [message #79425 is a reply to message #79411] Wed, 14 May 2003 13:11 Go to previous messageGo to next message
news:b9tn60$mqr$3@rogue.oti.com...
> Hi Randy,
> Thnks for your help
visible
This could be done by having a layer local to the container, and parenting
the connection in that layer. It could also be done by cheating in the
connection anchor. the location of the anchor could be clipped to the
container's client area.
This could not be done at the layer. The only way to do this would be
having the connection anchor clip to the node's container. Some mockups
might help describe what you want better.
would
> > always be visible.
> >>Hi,
container.
> >>QUOTE
> >>UNQUOTE
> >>bruno
Re: Connections clipping and "re-anchoring" [message #79441 is a reply to message #79425] Wed, 14 May 2003 15:49 Go to previous message
--------------070803080106030704060900
Content-Type: text/plain; charset=us-ascii; format=flowed
Randy,
I have attached drawings of the "current" and "expected" behaviours. The
container on the right holds one "visible" node and two "hidden" nodes,
one at the top, one on the right.
In the "expected" drawing, we could even have some decoration at the end
of the truncated connections to precisely indicate that: they are truncated.
I was thinking to go the route you mentioned i.e. tricking the router by
moving the "hidden" anchor location of the node to the border of the
container.
This is a bit tricky, as calls on the getLocation method of these
anchors should be distinguished between calls to find and anchor and
calls to actually draw the connection. This does not worry me too much
however.
My biggest problem now, is actually getting the Rectangle representing
the actual clipping area of the content pane of the container starting
from its Figure. The method getBounds return as expected the Smallest
Rectangle that holds all of the children, including the hidden ones.
However getClientArea returns the same Rectangle.
How do I get the clipping Rectangle?
I will then try to implement the behaviour and publish code snippets.
rgds
bruno
>>Hi Randy,
>>Thnks for your help
> visible
> would
>>>always be visible.
>>>>Hi,
> container.
>>>>QUOTE
>>>>UNQUOTE
>>>>bruno
Content-Type: image/png;
name="current.png"
Content-Disposition: inline;
filename="current.png"
iVBORw0KGgoAAAANSUhEUgAAAfQAAAExCAYAAACK81CNAAAABmJLR0QA/wD/ AP+gvaeTAAAA
CXBIWXMAAAsSAAALEgHS3X78AAAAB3RJTUUH0wUOEyACFatkxQAACWFJREFU eJzt3eFx27ga
hlHxTppIF5E62BTudGC5C7kL7o8d7c2aVkxRhIjv5Tm/MlHsQWxaj0GCxDCO 43gAAEr739YD
AAAeJ+gAEEDQASCAoANAAEEHgACCDgABBB0AAgg6AAT4tvUAlhqGYesh8BvP JwLYlhk6AAQo
O0O/MjPcljMlAH0wQweAAIIOAAEEHQACCDoABBB0AAgg6AAQQNABIICgA0AA QQeAAIIOAAEE
HQACCDoABBB0AAgg6AAQoPz2qbbvBAAzdACIUH6GPo7j1kPYNWdIAPpghg4A AQQdAAIIOgAE
EHQACCDoABBA0AEggKADQABBB4AAgg4AAQQdAAIIOgAEEHQACCDoABBA0AEg gKADQABBB4AA
gg4AAQQdAAIIOgAEEHQACCDoABBA0AEggKADQABBB4AAgg4AAQQdAAIIOgAE EHQACCDoABDg
29YDAKaGYfj3z+M4Tv7ud17f9vWvXD8eWhvGokfb9Yer6PBj+D60MQyDr2nn 5gTe95Bncsod
AAIIOsACX82+zc55NkGHDokBcC9BB1jo1i9efiFjC4IOHVq6ohrYL0EHeMDH 2bjZOVsRdAAI
4MEyC1Q6HWq2AO2N4+jZAWxO0O9Q8SEqFccMwP2ccp+pahgffWwlME+19wby CPodqv7AVh33
nvmeAfcSdAAIIOjQIZdIgHsJOgAEEHQACCDoABBA0AEggKADQABBhw65Dx24 l6ADQABBhw65
Dx24l6ADQAC7re3IrVnfVxu4zN3gpdXn3+vrHzcE6m18W79unQH81zAW/al4 9u5n1fc6bjX+
qrvQUVv1n0dowSl3AAgg6EA5ZucwJegAEEDQgXLc1gdTgg4AAQQdAAIIOgAE EHQACOBJcVCM
BWH/8HXI5bbEZczQASCAGToUZRZDGmddHmOGDpTjjR+mBP0OVd9Eqo4bgPkE faa5W4j2xm5o
APvgGvodKkZdyAH2QdAXEEkAeuOUOwAEEHSgHGfJYErQASCAoAPlVFqYCs8i 6AAQQNABIICg
A0AAQQeAAIIOAAE8KQ6K2vtK773//+EjM3QACGCGDkXt+WlpwzDs+v/fq/Pb efHHno6nFUey
T4IOwGqOP453/fvz2/nw8uul0Wj2RdABWNUjM3WWcw0dAAIIOgAEEHQAmrPo rT1BB8qxwr2W
a8xFvS1BB6CZjxEX9XYEHSjHU+JquBVvUW/DbWsANPF6ft16CLtihg4AAQQd AAIIOgAEEHQA
VuOxr9uxKA4ox33o/Vqy0crPv342GMn+DGPRn4zrbStFhx/D9+H5fM3p1SO3 E76eX/+9nc2x
vYwZOlCO/dD7dLlcth7CrrmGDgABBB0AAgg6AAQQdAAIIOgAEEDQgXKscIcp QQeAAIIOlGM/
dJgSdAAIIOgAEEDQASCAoANAAEEHgACCDpTjPnSYEnQACCDoQDnuQ4cpQQeA AIIOAAEEHQAC
CDoABPi29QAAqOH3xYjXWwdvLVC8XC6Hw+Fw+P79+92vD8Pw5eff+vU5nn17 5TAWvaHz+kUu
OvwYvg/P52vOVn4P7Wfe398f+vzXuPd+bM+J/Bb/B6fcASCAoAPluA+dLX01 +97qDIOgAzBL
76fC907QAeBOt3652fKXHkEHYBaXOvrmtjUAVnF5vyz+2NPxtOJInmMcx09v 5duKoAOwmuOP
413//vx2Prz8emk0mn0RdKCcrWdC/Nn57bz1EJ7mOkvv4Zh0DR0AAgg6UI7F WfSkh9n54SDo
AMzUS7j4nKADQABBB2AWlzr6JugAEEDQASCAoAPlWJwFU4IOAAEEHSjH4iyY EnQAZnGpo2+C
DgABBB2AWVzq6JugA0AAQQeAAIIOlGNxFkwJOgAEEHSgHIuzYErQAZjFpY6+ CToABBB0AGZx
qaNvgg4AAQQdAAIIOlCOxVkwJegAEEDQgXIszoIpQQdgFpc6+iboABBA0AGY xaWOvgk6AAQQ
dAAIIOhAORZnwZSgA0AAQQfKsTgLpgQdgFlc6uiboANAAEEHYBaXOvom6AAQ QNABIICgA+VY
nAVTgg4AAQQdKMfiLJj6tvUAAP7kVrw/+3un4tvy9e2bGTrQtbkRERv2TtAB mMWljr4JOtC9
r2bfZucg6AAQQdCBEm7Nws3O4R+CDgABBB0o4+Ns3Owc/k/QAZjFL1B9E3Sg lGtUxAX+S9AB
mMV96H3z6FegqVYRaPF5zfqpTNCBJq7BrRTJimOGK6fcgdVVDeN1vE4tU5Gg A01Ui/lV1XGD
oANAAEEHYBZnL/om6AAQQNABmMViwb4JOgAEEHQACCDoABBA0AEggKADQABB B2AW96H3TdAB
IIDd1gA+ceue6682cNnL6/RH0AE+8VW49v46/XHKHQACCDoABBB0AAgg6AAQ QNABIICgA0AA
QQeAAIIOAAEEHQACCDoABBB0AAgg6AAQQNCBJm7t1tW7quMGQQdW99UWnL26 jtdOY1Rk+1Sg
iYpRF3IqE3SgKZGE53DKHQACCDoABBB0AAgg6AAQQNABIICgA0AAQQeAAIIO AAEEHQACCDoA
BBB0AAgg6AAQQNABWM357bz1EHar/G5rlbZmBEj38uvl7o/5+dfPBiPZn2Es urehkPel6GFU
0vXY9zWnN4+8L7+eXw+n4+lwODi2lyo7Q/cNB+jL6/l18cdeY85yZYMOQH+O P453/fvz23nR
aXqmBB2AVVkYtw2r3AEggKADQACn3AFo4k8L3R5ZQMfnzNABaOJWtMW8DUEH oJmP8RbzdgQd
gKauERfztgQdgObEvD1BB4AAgg4AAQQdAAIIOgCr8djX7XiwDACrsR/6dsru hw57ZT90emU/
9G2ZoUNRj5zaPB1PbiNq4HQ8HS6Xy9bDWOzyvnzsp+NJiDcm6FDYo3tP3/vx fC5pT2/7mdcl
6FDco4uQLGLiI8dETVa5A0AAQYdQf9q6EuZyHNUh6BDImzBrcjzVIOgQxpsv LTiu+ifoEMSb
Li05vvom6BDEveW05Pjqm6BDGG+6tOC46p+gQyBvvqzJ8VSDoEMob8KswXFU h6ADQABBh8I8
9pW1OSbq8ix3KOzRvadtqrGelD297Wdel6BDUY/cE/z73tOsp/r15kePKbY1 jDawhVKGYdh6
CNCULC3jGjoABHDKHYoxewE+Y4YOAAEEHQACCDoABBB0AAgg6AAQQNABIICg A0AAQQeAAIIO
AAEEHQACCDoABPgbpYfjSCtrOs4AAAAASUVORK5CYII=
name="expected.png"
filename="expected.png"
CXBIWXMAAAsSAAALEgHS3X78AAAAB3RJTUUH0wUOEyUhyrvh8gAACTxJREFU eJzt3VFS20gY
hVFrKpvILmLvIFk42QFmF2YXnoeUMhmEg2SrUf9X5zylYkh1QPijpZZ6uF6v 1wMAUNo/Ww8A
AHicoANAAEEHgACCDgABBB0AAgg6AAQQdAAIIOgAEODL1gO41zAMWw+BP3g+ EcC2zNABIEDZ
GfrIzHBbzpQA9MEMHQACCDoABBB0AAgg6AAQQNABIICgA0AAQQeAAIIOAAEE HQACCDoABBB0
AAgg6AAQQNABIICgA0CA8tun2r4TAMzQASBC+Rn69Xrdegi75gwJQB/M0AEg gKADQABBB4AA
gg4AAQQdAAIIOgAEEHQACCDoABBA0AEggKADQABBB4AAgg4AAQQdAAIIOgAE EHQACCDoABBA
0AEggKADQABBB4AAgg4AAQQdAAIIOgAEEHQACCDoABBA0AEggKADQABBB4AA gg4AAQQdAAJ8
2XoAwNQwDL//fL1eJ3/3J69//uvj30FPhmvRI3P84So6/Bi+D20Mw+Br2inf G3rllDsABBB0
AAgg6NAhp3SBpQQdAAIIOnTo1oprgFsEHQACCDrAAtY30CsPlrlDpdOh3nxg Pe5Bp2eCvkDF
h6hUHDMAyznlPlPVMH70WEsAMgj6AtViPqo67j3zPeuXX47plaADzOQXLXom 6NAhs0BgKUEH
gACCDgABBB0AAgg6AAQQdIAFrHSnV4IOHRINYClBB1jALYX0StChQ6IBLCXo ABDAbms7cmvW
99EGLnM3eGn17+/19bcbAvU2vq1ft84A/m+4Fv2p+Ozdz6rvg9xq/FV3oaO2 LX8eq78XkMsp
d4AFxJxeCTpQzpZRtWCRXgk6AAQQdKAcs2SYEnQACCDoABBA0AEggKADLOC2 NXrlSXFQjAVh
v/g65PJL033M0AEggBk6FGUWsw2Pfm3HWZfHmKED5XjjhylBX6Dqm0jVcQMw n6DPNHcL0d7Y
DQ1gH1xDX6Bi1IUcYB8E/Q4iCfvl559eOeUOAAEEHSjHLBmmBB1ggUpraNgX QQfKEVWYEnQA
CCDoABBA0AEggKADLOQaPj3yYBmABdwyR68EHYra+yxx7/9/eMspdwAIYIYO Re351O8wDLv+
//fq/HK++3NPx9OKI9knQQdgNcdvx0Uff345H55+PjUazb4IOgCremSmzv1c QweAAIIOAAEE
HYDmLHprT9CBcqxwr2WMuai3JegANPM24qLejqAD5XhKXA234i3qbbhtDYAm ns/PWw9hV8zQ
ASCAoANAAEEHgACCDsBqPPZ1OxbFAeW4D71f92y08uP7jwYj2Z/hWvQnY7xt pejwY/g+fD5f
c3r1yO2Ez+fn37ezObbvY4YOlGM/9D5dLpeth7BrrqEDQABBB4AAgg4AAQQd AAIIOgAEEHSg
HCvcYUrQASCAoAPl2A8dpgQdAAIIOgAEEHQACCDoABBA0AEggKAD5bgPHaYE HQACCDpQjvvQ
YUrQASCAoANAAEEHgACCDgABvmw9AABq+HMx4njr4K0FipfL5XA4HA5fv369 63WWG65Fb+gc
D6Kiw4/h+/D5fM3ZyjAMfz3uXl9fH/r3x7g7tu/jlDsABBB0oBz3ocOUoAMw i1PhfRN0AAgg
6ADM4lJH39y2BsAqLq+Xuz/3dDytOJJ9EnQAVnP8dlz08eeX8+Hp51Oj0eyL oAPlWJzVt/PL
eesh7JJr6AAQQNCBcizOgilBB2AWlzr6JugAEEDQAZjFpY6+CToABBB0AAgg 6EA5FmfBlKAD
QABBB8qxOAumBB2AWVzq6JugA0AAQQdgFpc6+iboABBA0AEggKAD5VicBVOC DgABBB0ox+Is
mBJ0AGZxqaNvgg4AAQQdgFlc6uiboANAAEEHgACCDpRjcRZMCToABBB0oByL s2BK0AGYxaWO
vgk6AAQQdABmcamjb4IOAAEEHQACCDpQjsVZMCXoABBA0IFyLM6CKUEHYBaX Ovom6AAQQNAB
mMWljr4JOgAEEHQACCDoQDkWZ8GUoANAAEEHyrE4C6a+bD0AgL+5Fe/3/t6p +LZ8fftmhg50
bW5ExIa9E3QAZnGpo2+CDnTvo9m32TkIOgBEEHSghFuzcLNz+EXQASCAoANl vJ2Nm53DfwQd
gFn8AtU3QQdKGaMiLvB/gg7ALO5D75tHvwJNtYpAi3/XrJ/KBB1oYgxupUhW HDOMnHIHVlc1
jON4nVqmIkEHmqgW81HVcYOgA0AAQQdgFmcv+iboABBA0AGYxWLBvgk6AAQQ dAAIIOgAEEDQ
ASCAoANAAEEHYBb3ofdN0AEggN3WAN5x657rjzZw2cvr9EfQAd7xUbj2/jr9 ccodAAIIOgAE
EHQACCDoABBA0AEggKADQABBB4AAgg4AAQQdAAIIOgAEEHQACCDoABBA0IEm bu3W1buq4wZB
B1b30RacvRrHa6cxKrJ9KtBExagLOZUJOtCUSMLncModAAIIOgAEEHQACCDo ABBA0AEggKAD
QABBB4AAgg4AAQQdAAIIOgAEEHQACCDoABBA0AFYzfnlvPUQdqv8bmuVtmYE SPf082nx5/z4
/qPBSPZnuBbd21DI+1L0MCppPPZ9zenNI+/Lz+fnw+l4OhwOju17lZ2h+4YD 9OX5/Hz3544x
535lgw5Af47fjos+/vxyvus0PVOCDsCqLIzbhlXuABBA0AEggFPuADTxt4Vu jyyg431m6AA0
cSvaYt6GoAPQzNt4i3k7gg5AU2PExbwtQQegOTFvT9ABIICgA0AAQQeAAIIO wGo89nU7HiwD
wGrsh76dsvuhw17ZD51e2Q99W2boUNQjpzZPx5PbiBo4HU+Hy+Wy9TDudnm9 f+yn40mINybo
UNije08v/Xzel7Snt/3M6xJ0KO7RRUgWMfGWY6Imq9wBIICgQ6i/bV0JczmO 6hB0CORNmDU5
nmoQdAjjzZcWHFf9E3QI4k2XlhxffRN0COLeclpyfPVN0CGMN11acFz1T9Ah kDdf1uR4qkHQ
IZQ3YdbgOKpD0AEggKBDYR77ytocE3V5ljsU9uje0zbVWE/Knt72M69L0KGo R+4J/nPvadZT
/Xrzo8cU2xquNrCFUoZh2HoI0JQs3cc1dAAI4JQ7FGP2ArzHDB0AAgg6AAQQ dAAIIOgAEEDQ
ASCAoANAAEEHgACCDgABBB0AAgg6AAQQdAAI8C9FS7ZxXvJzpwAAAABJRU5E rkJggg==
--------------070803080106030704060900--
Re: Connections clipping and "re-anchoring" [message #79470 is a reply to message #79441] Wed, 14 May 2003 15:26 Go to previous message
This could be done with connection anchors which clip to the parent
container. However, the arrowtip would always appear.
news:b9tvh6$mqr$4@rogue.oti.com...
> Randy,
truncated.
> container.
> however.
> rgds
> bruno
> >>Hi Randy,
> >>Thnks for your help
> > visible
parenting
> > would
> >>>always be visible.
> >>>>Hi,
> > container.
> >>>>QUOTE
> >>>>UNQUOTE
> >>>>bruno
Previous Topic:placing dialog relative to editor
Next Topic:Bug in RoundedRectangle?
Current Time: Tue Jul 22 02:26:53 EDT 2025
Powered by FUDForum. Page generated in 0.05512 seconds
