Home » Eclipse Projects » Remote Application Platform (RAP) » Several brandings
Several brandings [message #79253] Wed, 26 March 2008 07:32 Go to next message
I recognized a strange behavior. Is it intended, that several brandings
for an application causes a "java.lang.IllegalStateException: The context
has been disposed."-Exception?
I have a very simple application running, with several brandings (use case
is, that the application should be customizable for different customers,
which could be easily done with brandings), but only the first
servlet-mapping seems to work?
Access to all other mappings causes the Exception.
Martin
Re: Several brandings [message #79268 is a reply to message #79253] Wed, 26 March 2008 12:26 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
the branding mechanism should work as you intend to use it. So this is
strange - could you please add the stacktrace, maybe this brings some
light in the dark...
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Martin Dilger [mailto:mdilger@splitshade.de]
Bereitgestellt: Mittwoch, 26. März 2008 12:32
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: Several brandings
Betreff: Several brandings
context has been disposed."-Exception?
case is, that the application should be customizable for different
customers, which could be easily done with brandings), but only the
first servlet-mapping seems to work?
Martin
Re: Several brandings [message #79431 is a reply to message #79268] Thu, 27 March 2008 03:54 Go to previous messageGo to next message
Hi Frank, sure..
Exception in thread "UIThread [16o3s1rfn52eo]"
java.lang.IllegalStateException: The context has been disposed.
org.eclipse.rwt.internal.service.ServiceContext.checkState(S erviceContext.java:154)
org.eclipse.rwt.internal.service.ServiceContext.getStateInfo (ServiceContext.java:104)
org.eclipse.rwt.internal.service.ContextProvider.getStateInf o(ContextProvider.java:165)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadCont roller.run(RWTLifeCycle.java:126)
at java.lang.Thread.run(Unknown Source)
As I wrote, the first mapping I access always works, no matter which one I
use, all other mappings cause this Exception.
Martin
Re: Several brandings [message #80286 is a reply to message #79431] Mon, 31 March 2008 07:49 Go to previous messageGo to next message
Originally posted by: andy.allgaeu.org
Hi again,
is there any progress on this topic? the problem still persists, is this a
bug, should i file a bug-report?
Andy
Re: Several brandings [message #80314 is a reply to message #80286] Mon, 31 March 2008 08:07 Go to previous messageGo to next message
Hi Andreas,
sure you can file a bug. Maybe with a snippet attached to reproduce the
problem easily. I'll investigate what the problem could be later this day.
Greets
Benny
Andreas wrote:
> Hi again,
> a bug, should i file a bug-report? Thanks
> Andy
Re: Several brandings [message #80588 is a reply to message #80286] Tue, 01 April 2008 05:52 Go to previous messageGo to next message
Hi Andreas,
I was not able to reproduce this in any form with CVS HEAD.
I used the demo plugin and added an additional branding so I had three
brandings.
Switching between brandins, entrypoints and branding+entrypoint
combinations never lead to the ISE.
Do you have a simple plugin with several brandings to reproduce this? If
yes, please open a bug and attach the snippet.
Thanks!
Benny
Andreas wrote:
> Hi again,
> Andy
Re: Several brandings [message #80759 is a reply to message #80588] Tue, 01 April 2008 13:48 Go to previous message
Hi Benny,
I filed a bug-report: https://bugs.eclipse.org/bugs/show_bug.cgi?id=225167
I hope I did not forget something, if I made a mistake, please correct me
then.
But since I am not alone with this problem, propably this is really a bug.
Thank you very much!
Greetings
Martin
Previous Topic:Browser memory leak?
Next Topic:synchronized
Current Time: Sun Jul 13 14:44:39 EDT 2025
Powered by FUDForum. Page generated in 0.03876 seconds
