Home » Archived » M2M (model-to-model transformation) » [ATL] error with oclAny
[ATL] error with oclAny [message #79200] Tue, 15 April 2008 07:01 Go to next message
Hi all,
I try to copy some classes from a profiled source model to the target
model. I get this error
SEVERE: ERROR: get unsupported on OclAny.
java.lang.RuntimeException: ERROR: get unsupported on OclAny.
org.eclipse.m2m.atl.engine.vm.SimpleDebugger.error(SimpleDeb ugger.java:195)
Is this error means something wrong in my transformation code or a plug in
is missed.
Thanks very much in advance for your help.
Rasha
Re: [ATL] error with oclAny [message #79361 is a reply to message #79200] Wed, 16 April 2008 03:25 Go to previous messageGo to next message
--------------050007060306040804000703
Rasha a
Re: [ATL] error with oclAny [message #79521 is a reply to message #79361] Thu, 17 April 2008 22:32 Go to previous message
Thanks William. The problem was in the getValue() method. I fixed the type
for its arguments. But I have another error
SEVERE: ****** BEGIN Stack Trace
SEVERE: exception:
SEVERE: null
org.eclipse.m2m.atl.drivers.uml24atl.ASMUMLModelElement.real Invoke(ASMUMLModelElement.java:624)
org.eclipse.m2m.atl.drivers.uml24atl.ASMUMLModelElement.invo ke(ASMUMLModelElement.java:581)
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:240)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation .java:171)
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:143)
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:101)
I think the problem is in these helpers as the rest of the code works fine
without them.
helper context UML!"uml::Element" def: getTaggedValue(stereo :
String ,tag : String) : UML!"uml::Element" =
self.getValue(self.getAppliedStereotype(stereo),tag);
helper context UML!"uml::Element" def : checkMyPropertyValue() : Boolean =
if (self.hasStereotype('MyStereotype')) then
if (self.getTaggedValue('MyStereotype','myProperty')-> exists (s| s.name
<> 'value1')) then ...
Any hint will be great,
Rasha
Previous Topic:[QVTO]Incompatible input type 'modelparam::ResourceEObject', expected 'uml::Model'
Next Topic:[QVTO] transforming profile-based models
Current Time: Sun Jul 13 15:51:50 EDT 2025
Powered by FUDForum. Page generated in 0.35313 seconds
