Home » Eclipse Projects » Nebula » What about sorting ?
What about sorting ? [message #7097] Tue, 25 July 2006 15:06 Go to next message
I've got a look at this Nebula control, it looks interesting.
Is there a way to sort like the Table SWT component ?
What do you think of comp4swt - http://www.wdev91.com/comp4swt/ and its
FormattedText component (Date, Number and Mask formatter) ? Do you think
possible to add this kind of control in SWT ?
Re: What about sorting ? [message #7121 is a reply to message #7097] Tue, 25 July 2006 16:46 Go to previous messageGo to next message
Yes, you would sort the Grid exactly like you would sort Table (i.e. you
need to create dispose and recreate the items).
They look interesting. I'm sure SWT has considered similar widgets.
Nebula could benefit from widgets like these.
-Chris
Re: What about sorting ? [message #9275 is a reply to message #7121] Thu, 17 August 2006 04:32 Go to previous messageGo to next message
Chris,
do I understand this the right way? You are working with that (imho)
ugly create - dispose mechanism SWT does? Is there a special reason for
it or is it just for SWT interface compatibility (as I understood so
far, the nebula grid is drawn on a canvas - so it should be possible to
put the GridItem positions in a container, reorder this container by the
sort criteria and redraw them dynamically)?
Don't get me wrong, I have an huge amount of respect for your work, it
should just be a hint to think about (because for column reordering you
do not have to dispose and create columns again).
Greets
Guido
>> its FormattedText component (Date, Number and Mask formatter) ? Do
>> you think possible to add this kind of control in SWT ?
> -Chris
Re: What about sorting ? [message #9294 is a reply to message #9275] Fri, 18 August 2006 15:43 Go to previous message
Enter a bug and I'll see whats necessary to add support for this...
>> you need to create dispose and recreate the items).
> Chris,
> Greets
> Guido
>> -Chris
Re: What about sorting ? [message #563309 is a reply to message #7097] Tue, 25 July 2006 16:46 Go to previous message
-Chris
Re: What about sorting ? [message #563978 is a reply to message #7121] Thu, 17 August 2006 04:32 Go to previous message
Chris,
Greets
Guido
> -Chris
Re: What about sorting ? [message #564018 is a reply to message #9275] Fri, 18 August 2006 15:43 Go to previous message
> Chris,
> Greets
> Guido
>> -Chris
Previous Topic:column visibility
Next Topic:Re: Blank view when implementing CTableTree
Current Time: Fri Jul 11 20:48:13 EDT 2025
Powered by FUDForum. Page generated in 0.29251 seconds
