Home » Archived » BIRT » Unable to checkout CVS as anonymous user
Unable to checkout CVS as anonymous user [message #79160] Wed, 05 October 2005 05:45 Go to next message
Originally posted by: daviskv.crimsonlogic.com
Hi All,
I am trying to checkout the source from the BIRT CVS repository, but I get
error saying "unable to connect as anonymous user, the password is
required". If any one encountered the same or any one knows if its
possible to access the CVS as anonymous login, please help.
Thanks In advance.
Davis
Re: Unable to checkout CVS as anonymous user [message #79289 is a reply to message #79160] Wed, 05 October 2005 11:11 Go to previous messageGo to next message
Davis,
I just tried with anonymous and it works for me.
It didnt require a password. Which version are you trying to download?
Jason Weathersby
BIRT PMC
"Davis" <daviskv@crimsonlogic.com> wrote in message
news:3f6ba40246c3982418d582c38f420cd5$1@www.eclipse.org...
> Hi All,
> Thanks In advance.
> Davis
Re: Unable to checkout CVS as anonymous user [message #79458 is a reply to message #79289] Thu, 06 October 2005 00:22 Go to previous messageGo to next message
Hi Jason,
I managed to checkout, actually the page
( http://www.eclipse.org/birt/frameizer.php?page=http://dev.ec lipse.org/viewcvs/index.cgi
} was missleading. I gave /cvsroot/birt instead of /home/birt. This I
found in another page.
However I am getting the following error in the midst of checkout out the
whole build version 2.0. I haven't build yet to see if any dependent files
are missing.
cvs checkout: Updating
source/org.eclipse.birt.tests.regression.data/test/plugins/o rg.eclipse.birt.report.data.oda.jdbc_1.0.0
source/org.eclipse.birt.tests.regression.data/test/plugins/o rg.eclipse.birt.report.data.oda.jdbc_1.0.0/drivers
ok (took 7:40.561)
Error: The following warnings were reported while performing the "cvs
checkout" command.
Warning: : cvs checkout: warning: cannot open
/home/birt/CVSROOT/val-tags read/write: Permission denied
Error: : cvs checkout: could not read RCS file for
org.eclipse.birt.converters/.classpath
org.eclipse.birt.converters/.cvsignore
org.eclipse.birt.converters/.project
Davis
Re: Unable to checkout CVS as anonymous user [message #79531 is a reply to message #79458] Thu, 06 October 2005 10:08 Go to previous messageGo to next message
Davis,
Which version are you trying to checkout?
Look at
http://www.eclipse.org/birt/index.php?page=build/build_instr .html
Remeber to set the configuration in
"Configuring Your Eclipse Workbench".
Judging from the error message it doesnt appear that you are getting that
far.
Can you browse the CVS repository?
Jason Weathersby
BIRT PMC
"Davis" <davis_k_v@yahoo.com> wrote in message
news:de1cbf1f320ce4f72c1757c37a96c149$1@www.eclipse.org...
> Hi Jason,
> are missing.
> ok (took 7:40.561)
> checkout" command.
> Davis
Re: Unable to checkout CVS as anonymous user [message #80013 is a reply to message #79531] Sun, 09 October 2005 07:29 Go to previous messageGo to next message
Hi Jason,
Now I managed to checkout the project following the page given by you
below. I hope the BIRT project must have build automatically because no
error or message. however, I am getting the following error while
"preparing the viewer". I can browse the CVS, I am using eclipse 3.1 and
java 1.4.2.
Please advise me what could be the cause.
Thanks & Regards,
Davis
compileSource:
Jar:
[echo] end call Jar task in ../org.eclipse.birt.core
[echo] start call Jar task in C:\Documents and
Settings\Davis\workspace\org.eclipse.datatools.connectivity. oda
BUILD FAILED
C:\Documents and
Settings\Davis\workspace\org.eclipse.birt.report.viewer\Buil dViewer.xml:214:
The following error occurred while executing this line:
C:\Documents and
Settings\Davis\workspace\org.eclipse.birt.report.model\Build Model.xml:297:
C:\Documents and
Settings\Davis\workspace\org.eclipse.birt.data.oda\BuildOda. xml:194:
Basedir C:\Documents and
Settings\Davis\workspace\org.eclipse.datatools.connectivity. oda does not
exist
Total time: 4 seconds
Re: Unable to checkout CVS as anonymous user [message #80830 is a reply to message #80013] Thu, 13 October 2005 21:54 Go to previous message
Hi Jason,
I've posted this question in the news group as separate subject, but no
body seems to be replying, hence I am writing personnaly.
I succeeded checkout the project and am trying to build it, but I got some
validation error in org.eclipse.birt.data/BuildData.xml file. I looked the
content of this file as pasted below, but doesn't make sense to me, it
refers jasperReport DTD file instead of build format. Could you please let
me know if this is correct ?. Are we using jasperReport in the BIRT
project in any ways, other than in convertors ?.
<!-- Created using an evaluation version of JasperAssistant
(http://www.jasperassistant.com) -->
<!DOCTYPE jasperReport PUBLIC "-//JasperReports//DTD Report Design//EN"
"http://jasperreports.sourceforge.net/dtds/jasperreport.dtd">
<jasperReport name="Unnamed" pageWidth="595" pageHeight="842"
columnWidth="555" leftMargin="20" rightMargin="20" topMargin="30"
bottomMargin="30">
</jasperReport>
Thanks in Advance.
Warm Regards,
Davis
Previous Topic:Missing ECore Registry
Next Topic:workspace\org.eclipse.datatools.connectivity.oda does not exist
Current Time: Sun Aug 31 22:35:27 EDT 2025
Powered by FUDForum. Page generated in 0.08375 seconds
