Home » Archived » Test and Performance Tools Platform (TPTP) » tptp junit test is not able to run with ant script
tptp junit test is not able to run with ant script [message #79003] Wed, 26 July 2006 11:30 Go to next message
Originally posted by: bjorn.vanhauwaert.barco.com
Hello, i am trying out the tptp test suite, but i am not able to run any
tests using only ant at the command prompt(Windows XP)
when i run ant -f test1.xml I get the following error. Anybody has any
ideas where the problem might be?
D:\TEMP\test>ant -f test1.xml
Buildfile: test1.xml
test:
java.io.IOException: CreateProcess: .\eclipse -nosplash -application
org.eclipse.hyades.execution.server -data "D:\APPZ\workspace\test" -vmargs
-Dtptp.automation.command=execute
-Dtptp.automation.synchronicity=synchronous
-Dtptp.automation.data="C:\Temp\memento38213.dat" error=2
at java.lang.ProcessImpl.create(Native Method)
at java.lang.ProcessImpl.<init>(ProcessImpl.java:81)
at java.lang.ProcessImpl.start(ProcessImpl.java:30)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:451)
at java.lang.Runtime.exec(Runtime.java:591)
at java.lang.Runtime.exec(Runtime.java:429)
at java.lang.Runtime.exec(Runtime.java:326)
org.eclipse.hyades.automation.client.strategies.OutOfProcess Strategy.execute(OutOfProcessStrategy.java:285)
org.eclipse.hyades.automation.client.ServiceProxy.execute(Se rviceProxy.java:77)
org.eclipse.hyades.automation.client.AutomationClient$Defaul t.execute(AutomationClient.java:160)
org.eclipse.hyades.automation.client.adapters.java.Automatio nClientAdapter.execute(AutomationClientAdapter.java:168)
org.eclipse.hyades.automation.client.adapters.java.Automatio nClientAdapter.execute(AutomationClientAdapter.java:147)
org.eclipse.hyades.automation.client.adapters.ant.Automation ClientAdapter$Automation.execute(AutomationClientAdapter.jav a:273)
org.eclipse.hyades.automation.client.adapters.ant.Automation ClientAdapter$Execution.execute(AutomationClientAdapter.java :578)
org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:275)
at org.apache.tools.ant.Task.perform(Task.java:364)
at org.apache.tools.ant.Target.execute(Target.java:341)
at org.apache.tools.ant.Target.performTasks(Target.java:369)
org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1216)
at org.apache.tools.ant.Project.executeTarget(Project.java:1185 )
org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D efaultExecutor.java:40)
at org.apache.tools.ant.Project.executeTargets(Project.java:106 8)
at org.apache.tools.ant.Main.runBuild(Main.java:668)
at org.apache.tools.ant.Main.startAnt(Main.java:187)
at org.apache.tools.ant.launch.Launcher.run(Launcher.java:246)
at org.apache.tools.ant.launch.Launcher.main(Launcher.java:67)
BUILD FAILED
D:\TEMP\test\test1.xml:25: java.lang.NullPointerException
Total time: 0 seconds
this is my ant script(test1.xml):
<project name="TPTP Ant Tasks Test Script"
default="test"
xmlns:tptp="antlib:org.eclipse.hyades.automation.client.adapters.ant ">
<property name="eclipse.home"
value="D:\APPZ\eclipse32_with_TPTP_subversive"/>
<description>
This ant script tests the TPTP automation ant task client adapters
and also can be used to test the underlying execution of TPTP automatable
services via the TPTP automation server
</description>
<!-- Execute TPTP test suites -->
<target
name="test" description="Executes TPTP Test Suites using default TPTP Ant
Tasks">
Execute a TPTP test suite using the test task and providing the workspace
<tptp:test
workspace="D:\APPZ\workspace\test"
project="guitest"
suite="UnitTest.testsuite"
</target>
</project>
Re: tptp junit test is not able to run with ant script [message #79013 is a reply to message #79003] Wed, 26 July 2006 12:20 Go to previous messageGo to next message
Have you included org.eclipse.hyades.execution under your library?
I use the following command to run a test using ant:
ant -f -lib
<ECLIPSE-HOME>\plugins\org.eclipse.hyades.execution_4.2.0.v200606131519
test-run.xml
Your best bet is to look at the log file generated under your workspace
(i.e. inside of D:\APPZ\workspace\test)
"Bjorn Vanhauwaert" <bjorn.vanhauwaert@barco.com> wrote in message
news:df0a800d2b32b091d44f1da0be303ddb$1@www.eclipse.org...
> test:
> at
> at
77)
> at
> at
> at
> at
tomation.execute(AutomationClientAdapter.java:273)
> at
ecution.execute(AutomationClientAdapter.java:578)
> at
> at
> at
ava:40)
> BUILD FAILED
> default="test"
> <description>
automatable
> </description>
> <target
> Tasks">
> <tptp:test
> project="guitest"
> </target>
> </project>
Re: tptp junit test is not able to run with ant script [message #79115 is a reply to message #79013] Thu, 27 July 2006 05:58 Go to previous messageGo to next message
Originally posted by: Bjorn.Vanhauwaert.barco.com
I tryed that suggestion but it didnt work still get the same error.
But after digging some further i found that
Could be comming from the java runtime.exec there are problems with some
path formatting to start it up.
To solve this i added the dir where eclipse
is(D:\APPZ\eclipse32_with_TPTP_subversive) to my path var => same error
could it be that there might be a problem that the script wants to execute
the .\eclipse as a command ? and doesnt find the exe. On this problem i
found some stuff on the forums they said the problem could be fixed if you
runitme.exe with the full path.
"Ali Mehregani" <amehrega@ca.ibm.com> wrote in message
news:ea84oc$4vq$1@utils.eclipse.org...
> ant -f -lib
> test-run.xml
>> test:
>> at
>> at
> 77)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
> ava:40)
>> BUILD FAILED
>> default="test"
>> <description>
> automatable
>> </description>
>> <target
>> Tasks">
>> <tptp:test
>> project="guitest"
>> </target>
>> </project>
Re: tptp junit test is not able to run with ant script [message #79130 is a reply to message #79115] Thu, 27 July 2006 06:06 Go to previous messageGo to next message
I just did some more testing
Using the simple class
on example 2 eclipse starts up
on example 1 i get this error: looks like the same thing to me
java.io.IOException: CreateProcess: .\eclipse error=2
at java.lang.ProcessImpl.<init>(Unknown Source)
at java.lang.ProcessImpl.start(Unknown Source)
at java.lang.ProcessBuilder.start(Unknown Source)
at java.lang.Runtime.exec(Unknown Source)
at antrunning.ExecTest.main(ExecTest.java:13)
public static void main(String args[])
try
Runtime rt = Runtime.getRuntime();
Process proc = rt.exec(".\\eclipse");//--------------------------1
//Process proc = rt.exec("eclipse");---------------------------2
int exitVal = proc.waitFor();
System.out.println("Process exitValue: " + exitVal);
} catch (Throwable t)
t.printStackTrace();
"Bjorn Vanhauwaert" <Bjorn.Vanhauwaert@barco.com> wrote in message
news:eaa2ou$pr7$1@utils.eclipse.org...
>> ant -f -lib
>> test-run.xml
>>> test:
>>> at
>>> at
>> 77)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>> ava:40)
>>> at
>>> BUILD FAILED
>>> default="test"
>>> <description>
>> automatable
>>> </description>
>>> <target
>>> Ant
>>> Tasks">
>>> workspace
>>> <tptp:test
>>> project="guitest"
>>> </target>
>>> </project>
Re: tptp junit test is not able to run with ant script [message #79248 is a reply to message #79130] Mon, 31 July 2006 01:02 Go to previous messageGo to next message
Looking at your script, I don't think "eclipse.home" is a valid property:
According to the example ant script included under
org.eclipse.hyades.execution/example.xml, the eclipse home property is
"tptp.automation.eclipse". Change the property name from "eclipse.home" to
"tptp.automation.eclipse" and try running your script again. This explains
the error that you were getting regarding the ./eclipse command. I have
opened the following defect against our help documentation to fix the typo:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=152291
Thanks.
news:eaa36h$rqt$1@utils.eclipse.org...
> try
execute
you
> >> ant -f -lib
> >> test-run.xml
any
> >>> test:
> >>> at
> >>> at
> >> 77)
> >>> at
> >>> at
> >>> at
> >>> at
> >>> at
> >>> at
> >>> at
> >>> at
> >>> at
> >> ava:40)
> >>> at
> >>> BUILD FAILED
> >>> default="test"
> >>> <description>
> >> automatable
> >>> </description>
> >>> <target
> >>> Ant
> >>> Tasks">
> >>> workspace
> >>> <tptp:test
> >>> project="guitest"
> >>> </target>
> >>> </project>
Re: tptp junit test is not able to run with ant script [message #79933 is a reply to message #79248] Mon, 07 August 2006 04:19 Go to previous message
Ok this made it work thnx :)
news:eak2qk$b31$1@utils.eclipse.org...
> to
> explains
> typo:
> Thanks.
>> try
>> > some
> execute
> you
>> >> ant -f -lib
>> >> test-run.xml
>> >> workspace
> any
>> >>> any
>> >>> test:
>> >>> at
>> >>> at
>> >> 77)
>> >>> at
>> >>> at
>> >>> at
>> >>> at
>> >>> at
>> >>> at
>> >>> at
>> >>> at
>> >>> at
>> >> ava:40)
>> >>> at
>> >>> at
>> >>> at
>> >>> BUILD FAILED
>> >>> default="test"
>> >>> <description>
>> >> automatable
>> >>> </description>
>> >>> <target
>> >>> Ant
>> >>> Tasks">
>> >>> workspace
>> >>> <tptp:test
>> >>> project="guitest"
>> >>> </target>
>> >>> </project>
Previous Topic:Agent Controller Confusion
Next Topic:Problem with AC on non default port number
Current Time: Sun Aug 31 07:18:43 EDT 2025
Powered by FUDForum. Page generated in 0.03454 seconds
