CVS patches [message #78976] |
Sun, 19 June 2005 07:03  |
Originally posted by: hendrik_maryns.despammed.com
I recently found out how to set up cvs from Eclipse. I don't have write
acces to the repository, so I have to make patches and send them in via
the bug database.
The problem is: when I right-click a file, and choose Team -> make
patch, this works, but the first line of the patch only gives the file
name, whereas I would like to have its full path in the cvs-tree.
If I use Tortoise outside of Eclipse, it does this just right.
The first few lines look like this:
(Tortoise)
Index: nl/browser/chrome/help/firebird-index1.rdf
RCS file: /l10n/l10n/nl/browser/chrome/help/firebird-index1.rdf,v
retrieving revision 1.5
diff -u -r1.5 firebird-index1.rdf
--- nl/browser/chrome/help/firebird-index1.rdf 16 Jun 2005 09:55:45
-0000 1.5
+++ nl/browser/chrome/help/firebird-index1.rdf 19 Jun 2005 10:51:14 -0000
@@ -48,7 +48,7 @@
(Eclipse)
Index: firebird-index1.rdf
--- firebird-index1.rdf 16 Jun 2005 09:55:45 -0000 1.5
+++ firebird-index1.rdf 19 Jun 2005 10:50:57 -0000
@@ -48,7 +48,7 @@
How can I make Eclipse to give me the same heading as Tortoise (which is
what the bug assignee wants, for ease of applying patches)
Cheers, H.
Hendrik Maryns
Interesting websites:
www.lieverleven.be (I cooperate)
www.eu04.com European Referendum Campaign
aouw.org The Art Of Urban Warfare
Re: CVS patches [message #79494 is a reply to message #79207] |
Wed, 22 June 2005 01:34   |
Originally posted by: eclipse.rizzoweb.com
Hendrik Maryns wrote:
> Sebastian Brocks uitte de volgende tekst op 20/06/2005 23:14:
>> Don't right click the file and choose Team - Create Patch, right click
>> the nl folder and choose Team - Create Patch
> Thanks, but I have several edited files, and I don't want to create a
> patch for all of them, only for that particular file (this is to keep
> the patches manageable, but I don't want to wait until it gets patched
> to continue working, there are currently about 7 patches pending now...)
> Other suggestions?
All you have to do is indicate at what level the patch was created when
you submit it. Then whomever is applying can apply it at the same level.
Patches use relative locations, so as long as someone knows where the
root at which it was created, it will work if they apply it at the same
root.
Another option that is more work for you would be to create a patch of
all your changes from the project root, then revert the project back to
the CVS version, then apply your own patch only accepting the one file
you are interested in (Eclipse lets you select which files to include
when applying a patch), then create a new patch from the root that will
only include the one file that was changed when you applied your first
patch. Problem is that this is a bit of work and must be repeated for
every different patch you want to create.
No matter what, you should search the Bugzilla database to see if anyone
has entered an enhancement request for the option of selecting files for
inclusion/exclusion during patch creation. If no such request exists,
enter one yourself. That is how Eclipse moves forward - users requesting
changes.
HTH,
Eric
Re: CVS patches [message #79627 is a reply to message #79494] |
Wed, 22 June 2005 07:31  |
Eric Rizzo uitte de volgende tekst op 22/06/2005 7:34:
>> Other suggestions?
> root.
> changes.
I'll do this, and use Tortoise to create the patches in the meantime...
Hendrik Maryns
FUDForum. Page generated in 0.08438 seconds
