Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Jet 2.0?
Jet 2.0? [message #78918] Mon, 09 April 2007 12:38 Go to next message
I was trying to use Jet to generate some XSL source for me. I tried to
add the <%@ taglib directive, but the Jet compiler gives a "bad directive"
error. I did a cut and past from the documention, so I am sure that it is
not a type.
My guess is that I don't have Jet 2 installed correctly. I downloaded the
latest that I could find in downloads, but that was only 0.8.0 which
doesn't sound correct. Installing it didn't solve the problem.
FYI, I am using the bleeding edge stuff.
Eclipse 3.3 M5
EMF 2.3 M5
GEF 3.3 M5
WTP 2.0 M5
Re: Jet 2.0? [message #78928 is a reply to message #78918] Mon, 09 April 2007 13:06 Go to previous messageGo to next message
Greg,
For future questions about JET2, please use the M2T newsgroup, which
I've added to the "to" list so that Paul will see your question.
> to add the <%@ taglib directive, but the Jet compiler gives a "bad
> directive" error. I did a cut and past from the documention, so I am
> sure that it is not a type.
> the latest that I could find in downloads, but that was only 0.8.0
> which doesn't sound correct. Installing it didn't solve the problem.
> Eclipse 3.3 M5
> EMF 2.3 M5
> GEF 3.3 M5
> WTP 2.0 M5
Re: Jet 2.0? [message #79122 is a reply to message #78928] Tue, 10 April 2007 08:12 Go to previous message
Greg:
JET2 downloads are available here:
http://www.eclipse.org/emft/downloads/?project=jet
And, yes, 0.8.0 is the correct version. Because JET2 is still an
"incubating" technology, the Eclipse foundation insists it have a version
number less than 1.0.
Install JET 0.8.0, then use the EMFT JET Transformation Project new project
wizard to create a project.
You can get a very quick introduction here:
http://www-128.ibm.com/developerworks/opensource/library/os- ecl-jet/
Paul
Re: Jet 2.0? [message #604496 is a reply to message #78918] Mon, 09 April 2007 13:06 Go to previous message
Greg,
> Eclipse 3.3 M5
> EMF 2.3 M5
> GEF 3.3 M5
> WTP 2.0 M5
Re: Jet 2.0? [message #604546 is a reply to message #78928] Tue, 10 April 2007 08:12 Go to previous message
Greg:
Paul
Previous Topic:Teneo: getChoiceOfValues(Object object) very long...
Next Topic:Teneo: refresh data from DB
Current Time: Tue Jul 15 06:23:26 EDT 2025
Powered by FUDForum. Page generated in 0.24684 seconds
