Home » Newcomers » Newcomers » Jface Viewer in Java Project??
Jface Viewer in Java Project?? [message #78843] Fri, 17 June 2005 23:39 Go to next message
Is there a tutorial concerning Jface viewers, such as a TreeViewer, NOT in a
plugin? Or is this impossible? Thank you.
Re: Jface Viewer in Java Project?? [message #79135 is a reply to message #78843] Mon, 20 June 2005 16:56 Go to previous messageGo to next message
Originally posted by: myersj.gmail.com
J. Michael,
See: http://www-106.ibm.com/developerworks/opensource/library/os- ecgui1/
And: https://bugs.eclipse.org/bugs/show_bug.cgi?id=49497
Hope this helps,
- Jeff
Re: Jface Viewer in Java Project?? [message #79642 is a reply to message #79135] Wed, 22 June 2005 07:51 Go to previous messageGo to next message
Originally posted by: BertinK.tiscali.nl
maybe you found out yourself, there is also a part two
http://www-106.ibm.com/developerworks/opensource/library/os- ecgui2/
and a part three
http://www-106.ibm.com/developerworks/opensource/library/os- ecgui3/
"Jeff Myers" <myersj@gmail.com> wrote in message
news:d97ahi$cl1$1@news.eclipse.org...
> J. Michael,
> Hope this helps,
> - Jeff
>> in a
Re: Jface Viewer in Java Project?? [message #80253 is a reply to message #79642] Thu, 23 June 2005 18:37 Go to previous message
Thanks for the quick response. I did not convey my question properly. I am
trying to get a TreeViewer to work with an object tree that I retrieve via
Hibernate, but am stymied at a much earlier point. I have a Junit test that
sets up a shell, and then displays a label widget in a shell; after that, I
try to test a viewer, but it fails:
public class TestWidgets extends TestCase {
Display display = null;
Shell shell = null;
Label label = null;
protected void setUp() throws Exception {
super.setUp();
display = new Display();
shell = new Shell(display);
public void testLabelWidget() {
label = new Label (shell, SWT.CENTER);
label.setText("Hello world");
label.setBounds(shell.getClientArea());
shell.open();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep (); }
display.dispose ();
NOTE - I CAN INSERT A SERIES OF LABEL WIDGET TESTS HERE, WITH DIFFERENT
NAMES, AND THEY ALL WORK IN SEQUENCE AS I CLOSE EACH SWT SHELL. THE NEXT
TEST FAILS, HOWEVER:
public void testListWidget(){
ListViewer viewer = new ListViewer(shell);
//ERROR OCCURS HERE
//viewer.setContentProvider(new TrialTreeContentProvider());
//viewer.setLabelProvider(new TrialTreeLabelProvider());
shell.open();
display.dispose ();
BUT I get an error here, fired at the ListViewer viewer = new
ListViewer(shell):
java.lang.NoClassDefFoundError: org/eclipse/core/runtime/ISafeRunnable
at edu.utah.cdmcc.test.TestWidgets.testListWidget(TestWidgets.j ava:48)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
junit.framework.TestCase.runTest(TestCase.java:154)
junit.framework.TestCase.runBare(TestCase.java:127)
junit.framework.TestResult$1.protect(TestResult.java:106)
junit.framework.TestResult.runProtected(TestResult.java:124)
junit.framework.TestResult.run(TestResult.java:109)
junit.framework.TestCase.run(TestCase.java:118)
junit.framework.TestSuite.runTest(TestSuite.java:208)
junit.framework.TestSuite.run(TestSuite.java:203)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRu
nner.java:478)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.
java:344)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner
..java:196)
On 6/22/05 5:51 AM, in article d9bjck$25a$1@news.eclipse.org, "Bertin"
> and a part three
>> J. Michael,
>> Hope this helps,
>> - Jeff
>>> in a
Previous Topic:Eclipse 3.0 RCP Export Wizard
Next Topic:Installtion of EMF plugin
Current Time: Sun Aug 31 19:40:52 EDT 2025
Powered by FUDForum. Page generated in 0.11402 seconds
