Home » Eclipse Projects » Equinox » questions on bundle and event
questions on bundle and event [message #78841] Mon, 11 December 2006 04:31 Go to next message
Originally posted by: godman_polly.yahoo.com
I BundleActivator are required to implement the methods start() and stop().
These 2 methods allows users control the installed bundle explicitly. I
would like to know that is there any method allow user to query the internal
state of the bundle and send controlling command to the bundle?
Besides, I don't what is the different between service and bundle? Both of
them are java objects.
How do i load new modules dynamically without restart the whole program?
Should I just deploy a bundle with a new version?
godman
Re: questions on bundle and event [message #79463 is a reply to message #78841] Mon, 18 December 2006 12:01 Go to previous message
The methods Bundle.start and Bundle.stop control starting and stopping a
bundle. When these methods get called the BundleActivator.start/stop
methods are called. There is also a method Bundle.getState that can be
used to see what state a bundle is currently in. Is this what you are
after?
Bundles are the installable unit in OSGi. For anything to be installed
into an OSGi framework it must be packaged into a bundle. A Bundle
(org.osgi.framework.Bundle) is a java interface but the interface
represents a bundle as an installable unit. The Bundle interface is
used to control the lifecycle of the bundle. For example, activation,
deactivation, install, update and uninstall.
OSGi Services implementations are delivered as part of a bundle. When a
bundle is activated its BundleActivator.start method can be used to
register service objects with the service registry. There are also
various declarative ways to offer/require OSGi services using
declarative services, Spring-OSGi, iPOJO etc.
It depends on if you are adding new bundles or updating old versions.
If you are adding new bundles then just installing them (using
BundleContext.installBundle should work. If you want to update an
existing bundle then Bundle.update should work for you.
> godman
HTH
Tom
Previous Topic:Problem registering custom ProtocolHandler
Next Topic:Host bundle exists but is unresolved
Current Time: Tue Jul 22 13:53:23 EDT 2025
Powered by FUDForum. Page generated in 0.04397 seconds
