Home » Eclipse Projects » Equinox » How to open the Equinox sample web page
How to open the Equinox sample web page [message #78799] Sun, 10 December 2006 19:09 Go to next message
Hi there,
I'm moving my first steps with Equinox server side. I've checked out the
latest bundles from CVS and installed the sample.http.registry bundle from
http://www.eclipse.org/equinox/server/http_in_equinox.php but while the
bundles all seems activated:
osgi> ss
Framework is launched.
id State Bundle
0 ACTIVE system.bundle_3.2.1.R32x_v20060919
8 ACTIVE javax.servlet_2.4.0.qualifier
9 ACTIVE org.eclipse.equinox.common_3.2.0.v20060603
10 ACTIVE org.eclipse.equinox.http.registry_1.0.0.qualifier
11 ACTIVE org.eclipse.equinox.http.servlet_1.0.0.qualifier
13 ACTIVE org.eclipse.equinox.registry_3.2.1.R32x_v20060814
15 ACTIVE org.eclipse.osgi.services_3.1.100.v20060601
16 ACTIVE sample.http.registry_1.0.0
osgi>
I do not understand which URL I need to make my browser point to :S I've
tried the command line arguments:
-Dorg.osgi.service.http.port=8080 -console
with no luck too.
So I guess it is something really stupid. Any help for a newbie? :)
Mario
Mario Scalas
"Relax. You don't have to be a great designer --you just have to be
creatively lazy."
-- Kent Beck
Re: How to open the Equinox sample web page [message #78855 is a reply to message #78799] Mon, 11 December 2006 07:44 Go to previous messageGo to next message
Originally posted by: ridcully560.yahoo.com
Hi Mario,
I think that you can access them via:
http://localhost:8080/bridge/helloworld (Servlet)
or
http://localhost:8080/bridge/helloworld.html (HTML-Resource)
with some browser. You mentioned, that you followed the desription on
the "Embedding an HTTP server in Equinox"-page. But I'm unsure if
there's a webserver (like Jetty) in the status-output you posted -
although I may be wrong there. You might try it with one of this (just
see the website you mentioned for details):
> * org.eclipse.equinox.http
OR
> * org.eclipse.equinox.http.jetty
> * org.eclipse.equinox.http.servlet
> * org.mortbay.jetty (v5_1_11 - from Orbit Depot)
> * org.apache.commons.logging (v1_0_4 - from Orbit Depot)
Hope that helps,
Johannes
Re: How to open the Equinox sample web page [message #78892 is a reply to message #78855] Tue, 12 December 2006 13:28 Go to previous messageGo to next message
Hi Johannes
Johannes wrote:
<snip>
> OR
:O Silly me! And I double checked that list several times ... just passed
over the name "equinox.http" ... with all those *.http* I got confused.
Well, I think I've expended much of my newbie credit :)
> Hope that helps,
> Johannes
Of course it had! Thank you very much!! There is only one problem: how to
change the listening port: I tried setting
in the arguments tab but with no effect :S
Cheers
Mario
Mario Scalas
creatively lazy."
-- Kent Beck
Re: How to open the Equinox sample web page [message #78922 is a reply to message #78892] Wed, 13 December 2006 05:39 Go to previous messageGo to next message
Hi Mario,
I don't think so!
Hmm... I think you can start the jetty server with some kind of
configuration-file. To do that I had to change the HttpServer to Server
in the jetty-Activator (in org.eclipse.equinox.http.jetty). I think you
can create a server with new Server(/path/to/config/file). I tried it
that way once to get my hibernate running, but for some reason I'm not
using that way anymore - and I fear I can't tell you if that is a way to
change the port, but maybe it's woth a look.
As it was easier for the moment, I simply switched the tomcat that I
need to run next to the jetty to another port - I'll have to change that
one day, but for now it works.
Johannes
Re: How to open the Equinox sample web page [message #78944 is a reply to message #78892] Wed, 13 December 2006 12:33 Go to previous messageGo to next message
Originally posted by: skaegi.sympatico.ca
Hi Mario,
That looks right.
The -Dorg.osgi.service.http.port=8080 should be in the "VM Arguments"
portion of the argument tab.
-Simon
"Mario Scalas" <mario.scalas@gmail.com> wrote in message
news:elmsdb$1ps$1@utils.eclipse.org...
> Hi Johannes
> Johannes wrote:
> <snip>
> > OR
> > Hope that helps,
> > Johannes
> Cheers
> Mario
> Mario Scalas
> creatively lazy."
> -- Kent Beck
Re: How to open the Equinox sample web page [message #78952 is a reply to message #78944] Wed, 13 December 2006 18:37 Go to previous message
Hi Simon,
Simon Kaegi wrote:
> That looks right.
Sgrunt! I did append the option in the program section, of course! Appending
in the VM args section worked perfectly.
Now I can start with the serious problems ... :)
Thanks!
Mario
Mario Scalas
creatively lazy."
-- Kent Beck
Previous Topic:is OSGi comparable with iBATIS SQLMAP 2
Next Topic:problem with export of bundles when resuming an osgi application
Current Time: Sat Jul 26 07:41:17 EDT 2025
Powered by FUDForum. Page generated in 0.08911 seconds
