Home » Modeling » GMF (Graphical Modeling Framework) » Can I close compartment and maintain overall size of figure ?
Can I close compartment and maintain overall size of figure ? [message #78759] Sun, 19 November 2006 14:19 Go to next message
Originally posted by: awm_abu.yahoo.com
Hey,
I am wondering whether I can use compartments in my figure.
I need the figure to stay the same size at all times.
So I was wondering if it was possible to have a compartment open/close and
change the rest of the figure
in a relative way so as to keep overall size the same ?
Alan.
Re: Can I close compartment and maintain overall size of figure ? [message #78955 is a reply to message #78759] Mon, 20 November 2006 16:14 Go to previous messageGo to next message
Alan,
Yes, this should be possible. The circuit figure in the Logic Diagram
Example does not change size when the circuit compartment figure is
collapsed. I think you just need to set the preferred size in your
top-level figure, but if that doesn't work I suggest you put a
breakpoint in ConstrainedToolbarLayout.layout(IFigure) and then collapse
the compartment to see what happens. This layout manager will allocate
space to the children based on their preferred size.
Cherie
Alan wrote:
> Hey,
> Alan.
Re: Can I close compartment and maintain overall size of figure ? [message #79544 is a reply to message #78955] Tue, 21 November 2006 13:56 Go to previous message
Thanks very much I will do that
"Cherie Revells" <crevells@ca.ibm.com> wrote in message
news:ejt618$e28$1@utils.eclipse.org...
> Alan,
> top-level figure, but if that doesn't work I suggest you put a breakpoint
> in ConstrainedToolbarLayout.layout(IFigure) and then collapse the
> compartment to see what happens. This layout manager will allocate space
> Cherie
> Alan wrote:
>> Hey,
>> and change the rest of the figure
>> Thanks,
>> Alan.
Previous Topic:DecoratorProvider configuration
Next Topic:planned maintenance releases?
Current Time: Mon Jul 21 21:43:01 EDT 2025
Powered by FUDForum. Page generated in 0.69280 seconds
