Home » Eclipse Projects » Remote Application Platform (RAP) » setText(String text) in MenuManager
setText(String text) in MenuManager [message #78729] Wed, 19 March 2008 06:02 Go to next message
Hi all,
I try to implement a multilanguage application. Everything works fine
except the menu.
There is no setText method in MenuManager to change dynamically the text
of my menu items... I though that I can override getText() method but I
did not found any method to update the menu text. It seems that the update
method of IContributionItem does not update the text...
Any suggestion ?
Emmanuel
Re: setText(String text) in MenuManager [message #78926 is a reply to message #78729] Sun, 23 March 2008 11:45 Go to previous messageGo to next message
it seems you want to change the language of your application on the fly.
I don't think that this would be much sense as RCP (including JFace and
SWT) is conceptional not able to handle this. What you can do is to use
the I18n features of RAP to have a localized version of your
application. See
http://help.eclipse.org/help33/topic/org.eclipse.rap.help/he lp/html/advanced/internationalization.html
Greets
Benny
Emmanuel wrote:
> Hi all,
> except the menu.
> update method of IContributionItem does not update the text...
> Any suggestion ?
> Emmanuel
Re: setText(String text) in MenuManager [message #79046 is a reply to message #78729] Mon, 24 March 2008 14:35 Go to previous message
Originally posted by: fappel.innoopract.com
hm I'm not sure, but you can get the Menu widget by
MenuManager#getMenu(). This in turn returns the List of children of type
MenuItem - this inherits Item#setText(). Maybe that helps.
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Emmanuel [mailto:emmanuel.marchal@n-side.be]
Bereitgestellt: Mittwoch, 19. März 2008 11:03
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: setText(String text) in MenuManager
Betreff: setText(String text) in MenuManager
Hi all,
except the menu.
Any suggestion ?
Emmanuel
Previous Topic:Tree issue
Next Topic:Problems with event enqueueing and client-server synchronization
Current Time: Mon Jul 21 23:55:48 EDT 2025
Powered by FUDForum. Page generated in 0.25171 seconds
