Home » Newcomers » Newcomers » Tables
Tables [message #78726] Fri, 17 June 2005 11:38 Go to next message
Originally posted by: chris.glengordonsoftware.co.uk
I know this is a really lame question but for the life of me when i use
the method to set a Jtables size, i cant seem to do it, where exactly
should be the code put is it just after JTable table = new JTable;
or is it else where ?
i can post code if that would help ?
Re: Tables [message #82078 is a reply to message #78726] Wed, 29 June 2005 16:42 Go to previous messageGo to next message
Originally posted by: user.server.net
Chris,
It would indeed help to see the code...
Did you set the preferred size or the actual size?
Kai
Chris G wrote:
Re: Tables [message #83516 is a reply to message #78726] Wed, 06 July 2005 07:46 Go to previous message
Originally posted by: djgarcias.itdeusto.com
Chris G escribió:
Hi,you have to look at your caontainer layout, try to put it to null
Previous Topic:How to keep login information?
Next Topic:Eclipse "Build Project" has NO effect
Current Time: Fri May 09 02:15:15 EDT 2025
Powered by FUDForum. Page generated in 0.13357 seconds
