Re: Debug timeout [message #78704] |
Tue, 22 July 2003 14:44 |
The debug timeout is set on the preference page you mention. There appears
to be a bug in our validation code. However, I noticed you can change the
value to something like "100000" and then backspace it to "10000", and it
works. I will enter a bug for this.
Darin
"Jorgen Rapp" <jorgen_rapp@yahoo.com> wrote in message
news:bfk0da$ool$1@eclipse.org...
> Does anyone know how to change the default timout during debugging?
> I am using Eclipse 3 M2 with jre 3.1_08
> The prefs page java.debug has a field for the timeout but when trying to
set
> it to
> any value (like 10000) it reports that it has to be bigger than 3000...
> Can it be changed in a flat file, if this is an issue with the prefs?
> Where are the prefs stored anyway, tried to export and search the exported
> .eps, but no luck.
> The consequence of it is that when a thread is being debugged and I want
to
> check something in the code,
> all of a sudden the application terminates with a detailed message
> org.jdt.timoutexception or similar.
> Any ideas?
FUDForum. Page generated in 0.02852 seconds
