Home » Language IDEs » ServerTools (WTP) » Internet > Proxy Settings
Internet > Proxy Settings [message #78673] Tue, 01 March 2005 12:42 Go to next message
I'm trying to figure out exactly when the proxy settings are being used by
the WTP. It seems like they're not being used for any of the
actions/plugins/features I need them to be. :(
Q1: What plugins/features use these settings?
Q2: Is there a way to coherce the xml validator (xml entity resolving in
general) to use these settings? I work behind an authentication-requiring
http proxy, and thus, I can't validate/resolve any dtds/schemas for xml
files (e.g. web.xml, spring definitions, hibernate definitions, etc etc).
I opened a bug about this here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=82037
Environment: Eclipse 3.1M5a and WTP 1.0M3 on a windows xp platform.
Thanks!
Christian
Re: Internet > Proxy Settings [message #78779 is a reply to message #78673] Tue, 01 March 2005 15:50 Go to previous messageGo to next message
Hi Christian,
I believe the Web services wizards and some of the J2EE tools use these
settings.
Thanks for opening the bug. I haven't had a chance to look at this so I've
tagged it as help wanted. This is a common problem for several validators
which will probably be solved once for all of them.
If you want validation to work without this you can download the relevant
schemas and add them to the XML catalog. The XML validator will use
entries found in the XML catalog.
Lawrence
Re: Internet > Proxy Settings [message #78838 is a reply to message #78779] Tue, 01 March 2005 16:43 Go to previous message
Lawrence... thanks for the response...
I posted about the xml catalog solution you suggested as well, since I've
had some trouble getting it to work for validating web.xml (v2.4). The
post is located at:
http://www.eclipse.org/newsportal/article.php?id=2892&gr oup=eclipse.webtools
Maybe you (or someone else) can shed some light on this?
Thanks a million!
Christian
Lawrence Mandel wrote:
> Hi Christian,
> settings.
> Lawrence
Previous Topic:NullPointer with M3
Next Topic:JSP errors tracking
Current Time: Thu Jul 24 01:08:16 EDT 2025
Powered by FUDForum. Page generated in 0.03697 seconds
