Files not managed by CVS show up with dirty flag [message #78623] |
Fri, 17 June 2005 03:48  |
Originally posted by: jacobsph.hotmail.com
I have recently installed Eclipse to develop in C and I am using CVS.
Great IDE, but there is one big problem that I cannot resolve (I have been
checking all preferences to solve it.. without success):
When I run a make (from a command-line, so external to the eclipse IDE) of
my project, suddenly a lot of folders get a "dirty tag". Isn't this
"dirty tag" used to indicate that a file/folder has been modified form the
latest CVS version? When I look deeper, I see that Eclipse is putting
dirty flags to every file which is not managed by CVS. But I'd like to
see this only for files managed by CVS. I tried adding the *.o, *.ln, ...
in the exclude list. But of course this is not helping, since my
executables don't have an extension.
Why is Eclipse taking files not managed by CVS into account? And where
can I change this?
Thx for your help,
Ph
Re: Files not managed by CVS show up with dirty flag [message #78698 is a reply to message #78623] |
Fri, 17 June 2005 11:30  |
Originally posted by: eclipse.rizzoweb.com
jacobsph wrote:
> Hello,
> been checking all preferences to solve it.. without success):
> of my project, suddenly a lot of folders get a "dirty tag". Isn't this
> the latest CVS version? When I look deeper, I see that Eclipse is
> putting dirty flags to every file which is not managed by CVS. But I'd
> like to see this only for files managed by CVS. I tried adding the *.o,
> *.ln, ... in the exclude list. But of course this is not helping, since
> my executables don't have an extension.
> can I change this?
New files (those created in your workspace since the last time you
synchronized with the repository) are considered a change, so the
directory that contains them is flagged as modified.
You might be able to add the pattern *. to the Team > Ignored Resources
exclude list, but I'm not sure that will do what you want.
The best way to address this is to use .cvsignore
Highlight a directory or file(s) and choose Team > Add to .cvsignore...
from the pop-up menu (or you can create/edit .cvsignore manually). It is
generally a good idea to include in the .cvsignore any directories where
files are generated into.
Do a Help search for .cvsignore and you'll find all the details you need.
HTH,
Eric
FUDForum. Page generated in 1.30155 seconds
