Home » Language IDEs » ServerTools (WTP) » WTP M3: Error opening xml document with XML Editor
WTP M3: Error opening xml document with XML Editor [message #78613] Tue, 01 March 2005 09:40 Go to next message
Originally posted by: michael.giroux.objectweb.org
I've installed Eclipse 3.1M5a, WTP M3 and all required jars including those
needed for Web Services support.
When I attempt to open an XML document with the XML Editor, I get the error
shown below.
Any thoughts?
Michael Giroux
!ENTRY org.eclipse.wst.sse.ui 2 2 2005-03-01 07:36:35.248
!MESSAGE StructuredTextEditor being used without StructuredDocument
!MESSAGE Input Name: web.xml
!MESSAGE Document implementation: class
org.eclipse.jface.text.Document
Re: WTP M3: Error opening xml document with XML Editor [message #79144 is a reply to message #78613] Wed, 02 March 2005 10:27 Go to previous messageGo to next message
> shown below.
> Any thoughts?
> Michael Giroux
The same happens here (same configuration), although only for file
types I've added in the Window->Preferences->File Associations
to open with the XML Source Page Editor. They get opened but no
syntax coloring happens :-(
Christian
Re: WTP M3: Error opening xml document with XML Editor [message #79213 is a reply to message #78613] Wed, 02 March 2005 11:30 Go to previous messageGo to next message
> shown below.
> Any thoughts?
> Michael Giroux
After a little searching on bugs.eclipse.org I found a workaround
(take a look at comment <a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=81710#c6">#6</a> of
bug <a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=81710">81710</a>.
I patched plugin.xml in org.eclipse.wst.xml.core_1.0.0 to match my file
types
and Voila! the files open in the XML editor _and_ are colorized.
Hth,
Christian
Re: WTP M3: Error opening xml document with XML Editor [message #79227 is a reply to message #79213] Wed, 02 March 2005 11:31 Go to previous messageGo to next message
Sorry for the messed up links :/
Re: WTP M3: Error opening xml document with XML Editor [message #79333 is a reply to message #79213] Wed, 02 March 2005 13:06 Go to previous messageGo to next message
Christian,
"Christian Schmitt" <schmitt.christian@gmx.de> wrote in message
news:d04pnr$r00$1@www.eclipse.org...
> types
Thanks for pointing me to the bug report. Any chance you could post the
patch to your plugin.xml file?
I looked at the file, and the bug report, but I'm not sure I'm clear on what
needs to be changed.
Michael
Re: WTP M3: Error opening xml document with XML Editor [message #79454 is a reply to message #79333] Wed, 02 March 2005 15:33 Go to previous messageGo to next message
Michael,
open the file
$ECLIPSE_HOME/plugins/org.eclipse.wst.xml.core_1.0.0/plugin. xml
find
<extension
point="org.eclipse.core.runtime.contentTypes">
<content-type
file-extensions="xml,xsl,xslt,dadx,wsdl,nst,xmi,xsd,exsd"
priority="low"
name="%XML_Content_Type_Extension_Element.name"
id="xmlsource"
base-type="org.eclipse.core.runtime.xml"
default-charset="UTF-8"
alias-for="org.eclipse.core.runtime.xml"
<describer
class=" org.eclipse.wst.xml.core.internal.contenttype.ContentDescrib erForXML "/>
</content-type>
</extension>
and add your needed filename extensions to the "file-extensions"
attribute (seperated by commas). That's all!
> Thanks
> Michael
Christian
Re: WTP M3: Error opening xml document with XML Editor [message #79482 is a reply to message #79454] Wed, 02 March 2005 15:42 Go to previous messageGo to next message
news:d057uu$53u$1@www.eclipse.org...
> find
> <extension
> <content-type
> [ text omitted]
> and add your needed filename extensions to the "file-extensions" attribute
Unfortunately, xml is already in the list. Were you getting the
error shown below?
Michael
Input Name: web.xml
Document implementation: class org.eclipse.jface.text.Document
Re: WTP M3: Error opening xml document with XML Editor [message #79629 is a reply to message #79482] Thu, 03 March 2005 02:43 Go to previous messageGo to next message
> error shown below?
> Michael
> Input Name: web.xml
Well, I was able to open file.xml in the XML editor from the beginning.
The thing that would not work was assign other file extensions to
the XML editor. In these cases I got the error/warning message.
Christian
Re: WTP M3: Error opening xml document with XML Editor [message #79952 is a reply to message #78613] Thu, 03 March 2005 16:33 Go to previous message
It looks like I was getting some interferance from other non-WTP plugins.
I did the following:
1. deleted eclipse 3.1 M5a install
2. deleted entire contents of the configured extension location (I keep
addon plugins in extension location)
3. installed eclipse 3.1 M5a into a new directory
4. installed WTP 1.0 M3 and all required plugins
The XML editor is now working as expected, as is the WSDL editor and other
WTP features that were not working previously.
I'm working with Sun JDK 1.4.2_07 and with Sun JDK 1.5.0_01.
Michael Giroux
Previous Topic:Adding server to existing project?
Next Topic:Can't start Tomcat
Current Time: Sun Jul 27 06:13:54 EDT 2025
Powered by FUDForum. Page generated in 0.07699 seconds
