Home » Language IDEs » C / C++ IDE (CDT) » Debug output to Eclipse console window?
Debug output to Eclipse console window? [message #78557] Sat, 16 August 2003 13:27 Go to next message
Hello. I am using Eclipse 2.1.1 and CDT 1.1.0 with Cygwin gcc 3.2-3. I want
to be able to debug a program using the Cygwin gcc debugger, and have the
program output display in the Eclipse console view. When I try debugging,
the output goes to a new system window. This is odd, since when I run a
program through Eclipse, its output goes to the Eclipse console view.
Is there some gcc debugger or Eclipse setting that I need to change to make
the debugging output appear in the console window?
Thanks for your help,
Ed
Re: Debug output to Eclipse console window? [message #78620 is a reply to message #78557] Tue, 19 August 2003 08:28 Go to previous messageGo to next message
> Ed
I'm wondering the same. Probably someone can point us to settings for it...
Thank you.
Re: Debug output to Eclipse console window? [message #78708 is a reply to message #78620] Tue, 19 August 2003 22:41 Go to previous message
Originally posted by: alain.nowhere.ca
Tan wrote:
want
> > Ed
> Thank you.
We've done it for other platform, GNU/Linux, QnX etc where it is possible
to create pseudo-tty and have gdb write the inferior(application being
debug)
to it. But we(I) do not know how to make pseudo-ttys in Windows/Cygwin
to make this work.
Any ideas welcome.
Previous Topic:Newbee question - Getting Debug to work
Next Topic:CDT gets stuck when building
Current Time: Tue Jul 15 10:35:39 EDT 2025
Powered by FUDForum. Page generated in 0.06354 seconds
