Home » Language IDEs » C / C++ IDE (CDT) » Plug-in blocks java path
Plug-in blocks java path [message #78542] Sat, 16 August 2003 02:00 Go to next message
Originally posted by: graeme.cracklingsmarts.com
Hello. I installed Eclipse 2.1 from a download a week ago. I have
written a lot of trivial tests in Java. All worked well. I downloaded the
c++ plugin, installed the features and plugins, ran eclipse -initialize
(on Red Hat 9.0 with Java sdk 1.4.2, JAVA_HOME and ANT_HOME all
working)and after trying out the c++ plugin the java runtime cannot be
found. I removed eclipse, and started again, and same success (or lack of
it: great until the configuration file was changed by installing the c++
plugin). What am I doing wrong,please?
Re: Plug-in blocks java path [message #78890 is a reply to message #78542] Sun, 24 August 2003 00:12 Go to previous message
Graeme wrote:
Silence. I am running Red Hat 9.0 Java 1.4.2 and I had installed GTK
version of eclipse. Thanks to some help from the tech people at SlickEdit
I have installed the motif version of eclipse, and my problem has been
removed. C++ plugin works, Java still works, slickedit editor works, and I
am removing the gtk version of eclipse from my box. This is a pity,
really, because the look of eclipse under gtk was better, in my opinion.
It just didn't run java after the c++ plug-in had been used. Other people
must be having this problem.
Previous Topic:remote buuilding
Next Topic:C++ libraries
Current Time: Fri Jul 25 22:34:14 EDT 2025
Powered by FUDForum. Page generated in 0.06301 seconds
