Home » Archived » BIRT » Can I use BIRT to create a RTF report from a swing app.
Can I use BIRT to create a RTF report from a swing app. [message #78484] Mon, 03 October 2005 13:16 Go to next message
Originally posted by: jluger.web.de
Can I export a ready designed BIRT report from a swing based application?
It doesn't matter what application I use to design the report, but after
it is designed it has to be possible to export it from a swing based
application in either RTF or Word Doc format. Is this possible or depends
the exporting runtime of BIRD also on Eclipse/SWT based technologie?
Jörg Luger
Re: Can I use BIRT to create a RTF report from a swing app. [message #78715 is a reply to message #78484] Mon, 03 October 2005 22:49 Go to previous messageGo to next message
Jorg,
On order to export a report as a RTF or Word Doc, you need an emitter
that supports RTF or Word. At this point the only emitters are for PDF
and HTML. The 2.0 release will add a .CSV emitter, but we do not have
the emitters you are looking for scheduled at this point.
Scott Rosenbaum
BIRT PMC
Jörg Luger wrote:
>Hello,
>Jörg Luger
Re: Can I use BIRT to create a RTF report from a swing app. [message #86181 is a reply to message #78715] Tue, 01 November 2005 10:49 Go to previous message
Originally posted by: m.n.com
Scott,
I plan to use BIRT from a Swing app too. The Swing UI will be webstarted
with the "data access" and report genetration occuring server-side. The
client will communicate via cajo or Hessian. So I am trying to figure out
the best way to display the report. I could download a PDF or provide a way
to view the report in a browser. I don't thing there currently is a Swing
viewer. Any thoughts?
"Scott Rosenbaum" <scottr@innoventsolutions.com> wrote in message
news:dhsqjs$eqi$2@news.eclipse.org...
> Jorg,
> On order to export a report as a RTF or Word Doc, you need an emitter that
> supports RTF or Word. At this point the only emitters are for PDF and
> HTML. The 2.0 release will add a .CSV emitter, but we do not have the
> Scott Rosenbaum
> BIRT PMC
> J
Previous Topic:Apache + Birt
Next Topic:Reporting POJO attributes
Current Time: Wed Oct 29 00:39:28 EDT 2025
Powered by FUDForum. Page generated in 0.03226 seconds
