Home » Language IDEs » C / C++ IDE (CDT) » Debug run won't stop on breakpoint
Debug run won't stop on breakpoint [message #78426] Wed, 13 August 2003 17:03 Go to next message
Originally posted by: minhv.hotmail.com
My setup: Windows NT, Eclipse 2.1.1, latest CDT, MinGW with gdb 5.2.1
I followed the tutorial, got the helloworld program built.
Then Run | Debug... and have C:\MinGW\bin\gdb.exe as the debugger under the
Debugger tab.
Eclipse starts the program, suspends it on startup.
I set up a breakpoint, then resume the run. The program keeps running after
several loops w/o stopping at my breakpoint.
What's wrong?
Thanks for your help.
Re: Debug run won't stop on breakpoint [message #78488 is a reply to message #78426] Wed, 13 August 2003 21:38 Go to previous messageGo to next message
I got the answer. I did not compile the code using -g flag :)
Case closed.
"Minh" <minhv@hotmail.com> wrote in message news:bhe8tt$h6k$1@eclipse.org...
the
> Debugger tab.
after
> What's wrong?
Re: Debug run won't stop on breakpoint [message #78647 is a reply to message #78488] Tue, 19 August 2003 11:00 Go to previous messageGo to next message
I still have such problem
i use -g flag to compile but i use gdb.exe from cygwin
Any advices ?
Thank you in advance
> Case closed.
> > Then Run | Debug... and have C:MinGWbingdb.exe as the debugger under
> the
> > Debugger tab.
> after
> > What's wrong?
Re: Debug run won't stop on breakpoint [message #79696 is a reply to message #78647] Wed, 03 September 2003 11:20 Go to previous messageGo to next message
Originally posted by: brian.qisoft.com
"Tan" <btvsoft@yahoo.com> wrote in message news:bhte2v$e4f$1@eclipse.org...
> Any advices ?
> > Case closed.
> > the
> > > Debugger tab.
> > after
> > > What's wrong?
I am using gdb.exe from cygwin and I had the same problem with the debugger
failing with the sample hello world program.
After reading the thread 'CDT Debugging a C++ program on Solaris 8' I found
a solution:
"Go to the "Window"->"Preferences"->"Debug"->"Registers view" preference
page
and uncheck the "Auto-Refresh by default" option."
I don't know why this is a problem or which program the fault is with but I
can now stop on a break point and debug happily.
Re: Debug run won't stop on breakpoint [message #79739 is a reply to message #79696] Thu, 04 September 2003 10:33 Go to previous message
Originally posted by: mikhailk.qnx.com
"Brian Harkness" <brian@qisoft.com> wrote in message
news:bj50rp$o89$1@eclipse.org...
> > Any advices ?
> > > Case closed.
5.2.1
> > > the
> > > > Debugger tab.
running
> > > after
> > > > What's wrong?
debugger
found
> a solution:
> page
I
This is a bug in gdb. It crashes on some register-related commands. Try the
latest version of gdb.
Previous Topic:Can I remove build targets
Next Topic:urgent: #ifdef parsing
Current Time: Mon Jul 21 22:13:51 EDT 2025
Powered by FUDForum. Page generated in 0.04072 seconds
