Home » Archived » M2M (model-to-model transformation) » [ATL] UML 2 BPEL
[ATL] UML 2 BPEL [message #78410] Sun, 06 April 2008 04:43 Go to next message
Originally posted by: hr_mi.live.cn
Hi,everyone
I have a problem about the transformation from uml to bpel.
I don't know how to judge a Class Diagram is whether a <<Message>>
sterotype or not.
for example,
<packagedElement xmi:type="uml:Class" xmi:id="_ImpYMMWmEdyvEKV9jp3p8g"
name="purchaseOrderMessage">
</packagedElement>
<BPEL:Message
xmi:id="_1Tu7EMW7EdytsYnsx_eveQ"base_Class="_ImpYMMWmEdyvEKV9jp3p8g "/>
who can help me manage it ??
Thanks very much.
Best whishes!
Re: [ATL] UML 2 BPEL [message #78567 is a reply to message #78410] Wed, 09 April 2008 11:07 Go to previous messageGo to next message
--------------010305010202090004000100
Content-Type: text/plain; charset=GB2312
To check stereotypes into ATL, you need to use UML2 api methods like in
Java. For instance, here is a helper which checks if an ELement has a
given stereotype :
helper context UML!"uml::Element" def: hasStereotype(stereotype :
String) : Boolean =
self.getAppliedStereotypes() -> collect(st | st.name) ->
includes(stereotype);
William
unique a
Re: [ATL] UML 2 BPEL [message #79376 is a reply to message #78567] Wed, 16 April 2008 04:48 Go to previous message
William Piers 写道:
> Hello,
> given stereotype :
> String) : Boolean =
> Best regards,
> William
> unique a écrit :
>> Hi,everyone
>> sterotype or not.
>> for example,
>> </packagedElement>
>> <BPEL:Message
>> Thanks very much.
>> Best whishes!
Hi William,
Thanks for your help. I will try it. If I have some other problem , I
am looking forward to your help.
Thanks again!
Previous Topic:[ATL] creating aggregation relation between model elements
Next Topic:[ATL] XML to XML transformation: XSLT or ATL?
Current Time: Mon Jul 21 21:51:58 EDT 2025
Powered by FUDForum. Page generated in 0.04906 seconds
