Home » Archived » XML Schema Definition (XSD) » Namespace Resolution
Namespace Resolution [message #7022] Fri, 13 December 2002 14:42 Go to next message
Originally posted by: dsingh.altoweb.com
Hi all,
I am wondering if something is possible with the current XSD API.
I have a WSDL document similar in structure to the following,
<definitions xmlns:a='http://mynamespace' xmlns
xmlns:s='http://www.w3.org/2001/XMLSchema'>
<types>
<s:schema targetNamespace="http://mynamespace">
<s:element name="myElement" type="string"/>
</s:schema>
</types>
</definitions>
If I extract the schema content and attempt to parse it using the xsd parser
I understand it will fail because it will not be able to resolve the prefix
s. However in this situation is it possible to pass in a set of
prefix/namespace pairs to help with the resolution.
Or is there another way to handle this situation.
Dharminder Singh
Re: Namespace Resolution [message #7092 is a reply to message #7022] Fri, 13 December 2002 16:44 Go to previous messageGo to next message
Dharminder,
I would suggest parsing the whole thing as a DOM. You can then navigate to the
<schema> element(s), create an XSDSchema, and do
xsdSchema.setElement(schemaElement). Please see the response to Mark Carman
question, just two notes up. ;-)
I'll bet a lot of people would like it if there were an XSDResourceImpl that
handled .wsdl; I wish I had more time...
Dharminder Singh wrote:
> Hi all,
> <types>
> </s:schema>
> </types>
> </definitions>
> Thanks
> Dharminder Singh
Ed Merks
Re: Namespace Resolution (WSDL documents) [message #7162 is a reply to message #7092] Mon, 23 December 2002 12:37 Go to previous messageGo to next message
Originally posted by: carman.itc.it
Dear Dharminder, Ed
First of all, thanks a lot to Ed for answering all our questions so
promptly!
I had to deal with the same problem as Dharminder when attempting to load
schemas defined within WSDL documents - namely that sometimes namespace
prefix definitions are found in the root <wsdl:definitions> element and
not repeated in the <xsd:schema> element. One work-around is to first
parse the WSDL document using a DOM parser (which you need to do anyway)
and then simply copy the missing definitions into the <schema> element. -
See attached code.
Secondly, I was unsuccessful in loading the <schema> element directly into
XSD by using the XSDSchema.setElement() method. (Even when calling the
XSDSchema.setSchemaLocation() method as described in the previous mail). I
could query the schema, but all the links to type-definitions were broken.
The work-around I used was to print-out the DOM <schema> element to a
temporary file (see attached code), and then load it as you would a normal
schema document.
A question for Ed:
When resolving type definitions, if the corresponding type definition is
not found, a new XSDSimpleTypeDefinition is returned. Wouldn't it be
better if it returned a null pointer or some sort of exception? As it is,
it is a bit difficult to know whether namespace links are working or not,
i.e. whether the returned definition is the real one or not.
Mark Carman
// some code for loading schemas from WSDL documents
public static XSDSchema loadSchemaFromWSDL(String wsdlURL) {
try {
// load WSDL document into DOM
javax.xml.parsers.DocumentBuilderFactory f =
javax.xml.parsers.DocumentBuilderFactory.newInstance();
f.setNamespaceAware(true);
Document doc = f.newDocumentBuilder().parse(wsdlURL);
// get the attributes (namespace declarations) from the root node
NamedNodeMap m = doc.getDocumentElement().getAttributes();
// find the <schema> element (ignoring namespace prefix)
Element schemaElement = (Element)
doc.getDocumentElement().getElementsByTagNameNS("*","schema ").item(0);
// add any missing namespace declarations to schema element
for (int i = 0; i < m.getLength(); i++) {
if
(m.item(i).getNodeName().startsWith("xmlns:" )&&!schemaElement.hasAttribute(m.item(i).getNodeName ()))
schemaElement.setAttribute(m.item(i).getNodeName(),m.item(i) .getNodeValue());
// write the <schema> node to a temporary file as though it were a
schema document
org.apache.xml.serialize.DOMWriterImpl d = new
org.apache.xml.serialize.DOMWriterImpl(true);
String tempSchemaFile = "/tmp/schema.xsd";
d.writeNode(new FileOutputStream(new
File(tempSchemaFile)),schemaElement);
// now load from schema from a file in normal fashion
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "xsd",
new XSDResourceFactoryImpl());
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getLoadOptions().put(XSDResourceImpl.XSD_TRACK_L OCATION,
Boolean.TRUE);
// create URI from relative file path
URI schemaURI = URI.createFileURI(new
java.io.File(tempSchemaFile).getAbsoluteFile().getCanonicalP ath());
XSDResourceImpl xsdSchemaResource =
(XSDResourceImpl)resourceSet.getResource(schemaURI, true);
// find the schema from amongst the resources
Iterator resources = resourceSet.getResources().iterator();
while (resources.hasNext()) {
Resource resource = (Resource) resources.next();
if (resource instanceof XSDResourceImpl) {
return ((XSDResourceImpl) resource).getSchema();
catch (Exception e) {
e.printStackTrace();
return null;
Re: Namespace Resolution (WSDL documents) [message #7260 is a reply to message #7162] Mon, 06 January 2003 20:23 Go to previous message
Hello Mark,
I know you were asking Ed but I will answer this. Yes when resolving type
definitions or if you resolve any object in the XML Schema
model you will be returned a dummy object if it can not be resolved. This
is actually very powerful because then you do not have to take care of null
or NullPointers everywhere in your code.
If you want you could do an eContainer() on the XSDElementDeclaration's type
definition and if it returns null then it is a dummy (unresolved) type.
Dave
"Mark Carman" <carman@itc.it> wrote in message
news:au7hko$e6l$1@rogue.oti.com...
> Dear Dharminder, Ed
> promptly!
> See attached code.
> schema document.
> A question for Ed:
> Mark Carman
> try {
> if
(m.item(i).getNodeName().startsWith("xmlns:")&&!schemaElement.hasAttribute(m
..item(i).getNodeName()))
> schema document
> Boolean.TRUE);
> return null;
Re: Namespace Resolution [message #564193 is a reply to message #7022] Fri, 13 December 2002 16:44 Go to previous message
Dharminder,
> Hi all,
> <types>
> </s:schema>
> </types>
> </definitions>
> Thanks
> Dharminder Singh
Ed Merks
Re: Namespace Resolution (WSDL documents) [message #564270 is a reply to message #7092] Mon, 23 December 2002 12:37 Go to previous message
Dear Dharminder, Ed
promptly!
See attached code.
schema document.
A question for Ed:
Mark Carman
try {
if
schema document
Boolean.TRUE);
return null;
Re: Namespace Resolution (WSDL documents) [message #564368 is a reply to message #7162] Mon, 06 January 2003 20:23 Go to previous message
Hello Mark,
Dave
> Dear Dharminder, Ed
> promptly!
> See attached code.
> schema document.
> A question for Ed:
> Mark Carman
> try {
> if
> schema document
> Boolean.TRUE);
> return null;
Previous Topic:Is there a <xsd:all> limitation?
Next Topic:Is there a <xsd:all> limitation?
Current Time: Mon Jul 21 21:07:42 EDT 2025
Powered by FUDForum. Page generated in 0.04028 seconds
