Home » Eclipse Projects » GEF » Layout of figures in an editpart
Layout of figures in an editpart [message #78242] Wed, 07 May 2003 05:16 Go to next message
Originally posted by: j.verschoor.nefli.nl
Hello
I've create an editpart that has a number of child editparts.
The parent editpart creates a figure that extends from a rectanglefigure and
adds a label in top of the rectangle.
The child figures should be inside the parent, and aligned right, right
under the parentlabel:
| Label |
| child |
| child |
| child |
My problem is that I can't get the positioning / alignment done properly. I
get something that looks like:
| child |
| child |
| child |
| Label |
If somone could tell me where I should specify the layout, I'd appreciate
it.
Thanks.
Re: Layout of figures in an editpart [message #78352 is a reply to message #78242] Wed, 07 May 2003 11:43 Go to previous messageGo to next message
The children cannot have other sibling figures like the label you describe.
You need to create a "contents pane" figure for containing the children:
| Label |
| | child| |
| | child| |
For the outer-most figure, use a ToolbarLayout
For the contents pane, use a ToolbarLayout, with
setMinorAlignment(ToolbarLayout.ALIGN_BOTTOMRIGHT)
"Joris Verschoor" <j.verschoor@nefli.nl> wrote in message
news:b9aiod$na9$1@rogue.oti.com...
> Hello
and
> | Label |
> | child |
> | child |
> | child |
I
> | child |
> | child |
> | child |
> | Label |
> it.
> Thanks.
Re: Layout of figures in an editpart [message #78431 is a reply to message #78352] Wed, 07 May 2003 15:15 Go to previous messageGo to next message
I have a question relating to figure use.
I use a org.eclipse.draw2d.Label figure with a text on the top and an image
under it. I put source and target anchors on the figure but when the text is
wider than the image, the anchors don't reach all the way to the imgae.
Instead they start and end at the width of the text. See attached file.
Should I use some kind of decorator to solve the problem or is it possible
to create one Label without an image and an ImageFigure and try to connect
to two?
Thanks.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:b9b9ic$agq$1@rogue.oti.com...
describe.
> | Label |
> | | child| |
> | | child| |
> > Hello
> and
> > | Label |
> > | child |
> > | child |
> > | child |
properly.
> I
> > | child |
> > | child |
> > | child |
> > | Label |
appreciate
> > it.
> > Thanks.
  • Attachment: snap.gif
    (Size: 1.78KB, Downloaded 109 times)
Re: Layout of figures in an editpart [message #78446 is a reply to message #78431] Wed, 07 May 2003 15:33 Go to previous messageGo to next message
see LabelAnchor
"Stefan Junsved" <stefan.junsved@comactivity.net> wrote in message
news:b9blvs$llb$1@rogue.oti.com...
is
> to two?
> Thanks.
> describe.
> > | Label |
> > | | child| |
> > | | child| |
> > > Hello
rectanglefigure
> > and
right
> > > | Label |
> > > | child |
> > > | child |
> > > | child |
> properly.
> > I
> > > | child |
> > > | child |
> > > | child |
> > > | Label |
> appreciate
> > > it.
> > > Thanks.
Re: Layout of figures in an editpart [message #78520 is a reply to message #78352] Thu, 08 May 2003 06:59 Go to previous messageGo to next message
Hi, I think you misunderstand me.
I have two EditParts (the container and the children)
They both have figures. (they are editparts because I want to be able to
select a child and remove / rename it etc)
So I don't really have a LayoutManager for the editparts..
describe.
> | Label |
> | | child| |
> | | child| |
> > Hello
> and
> > | Label |
> > | child |
> > | child |
> > | child |
properly.
> I
> > | child |
> > | child |
> > | child |
> > | Label |
appreciate
> > it.
> > Thanks.
Re: Layout of figures in an editpart [message #78652 is a reply to message #78520] Thu, 08 May 2003 10:57 Go to previous messageGo to next message
Actually, that is what I understood. The label is getting pushed down to
the bottom in refreshChildren because it is a sibling of the children
editparts' figures. Your container edipart must consist of 3 separate
figures, one for the editpart, one for the label, and one to contain the
children editparts.
+Figure in ToolbarLayout
|-Label
|-+ Figure in ToolbarLayout
| - figure from first child editpart
| - figure from second child editpart
news:b9dd63$m3f$1@rogue.oti.com...
> describe.
> > | Label |
> > | | child| |
> > | | child| |
> > > Hello
rectanglefigure
> > and
right
> > > | Label |
> > > | child |
> > > | child |
> > > | child |
> properly.
> > I
> > > | child |
> > > | child |
> > > | child |
> > > | Label |
> appreciate
> > > it.
> > > Thanks.
Re: Layout of figures in an editpart [message #78695 is a reply to message #78652] Thu, 08 May 2003 11:12 Go to previous messageGo to next message
Ok I understand that, but what I don't understand is where and how I can
add() a child to the figure with toolbar layout
I create a figure in createFigure(), and gef does some magic, so there's no
way of adding the figure to another figure instead of the figure I return in
createFigure()
news:b9dr8d$2mt$1@rogue.oti.com...
> children editparts.
> |-Label
> > describe.
children:
> > > | Label |
> > > | | child| |
> > > | | child| |
> > > > Hello
> rectanglefigure
> > > and
> right
> > > > | Label |
> > > > | child |
> > > > | child |
> > > > | child |
> > properly.
> > > I
> > > > | child |
> > > > | child |
> > > > | child |
> > > > | Label |
> > appreciate
> > > > it.
> > > > Thanks.
Re: Layout of figures in an editpart [message #78769 is a reply to message #78695] Thu, 08 May 2003 12:12 Go to previous messageGo to next message
create a field in your graphicaleditpart subclass called contentsPane. in
createFigure, hold onto the contentsPane. override getContentsPane to return
the contentsPane field.
news:b9ds1c$3je$1@rogue.oti.com...
no
in
> createFigure()
to
> > children editparts.
> > |-Label
to
> > > describe.
> children:
> > > > | Label |
> > > > | | child| |
> > > > | | child| |
> > > > > Hello
> > rectanglefigure
> > > > and
> > right
> > > > > | Label |
> > > > > | child |
> > > > > | child |
> > > > > | child |
> > > properly.
> > > > I
> > > > > | child |
> > > > > | child |
> > > > > | child |
> > > > > | Label |
> > > appreciate
> > > > > it.
> > > > > Thanks.
Re: Layout of figures in an editpart [message #79000 is a reply to message #78769] Mon, 12 May 2003 05:11 Go to previous message
Ah thanks for explaining. I also found the same code in the logic example.
news:b9dvkt$6rc$1@rogue.oti.com...
return
> no
return
> in
> > createFigure()
> to
the
> > > children editparts.
> > > |-Label
able
> to
> > > > describe.
> > children:
> > > > > | Label |
> > > > > | | child| |
> > > > > | | child| |
> > > > > > Hello
> > > rectanglefigure
> > > > > and
right,
> > > right
> > > > > > | Label |
> > > > > > | child |
> > > > > > | child |
> > > > > > | child |
> > > > properly.
> > > > > I
> > > > > > | child |
> > > > > > | child |
> > > > > > | child |
> > > > > > | Label |
> > > > appreciate
> > > > > > it.
> > > > > > Thanks.
Previous Topic:debugging into Eclipse Src
Next Topic:Handling Request of Type open
Current Time: Thu Jul 17 21:33:14 EDT 2025
Powered by FUDForum. Page generated in 0.05054 seconds
