Home » Language IDEs » Java Development Tools (JDT) » cvsignore problems
cvsignore problems [message #78231] Fri, 18 July 2003 21:48 Go to next message
Eclipse doesn't seem to recognize the .cvsignore file in my project
directory.
This causes several effects:
1 - Team | Add to .cvsignore is disabled
2 - Eclipse thinks too much stuff needs to be committed to the
repository : for example, I have a "jars" directory is in .cvsignore,
but Eclipse thinks it's a new add.
cvs from the command line works fine, so I am using that for now.
This problem is occuring in all of my (previously working) projects.
What could be the problem?
With kind regards,
Josh Rehman
citysearch.com
Re: cvsignore problems [message #78260 is a reply to message #78231] Fri, 18 July 2003 22:28 Go to previous messageGo to next message
> directory.
FWIW, I've seen this too. It works on some projects and not on others,
and I think I've seen it suddenly stop working in a project for no
apparent reason. I'm using 2.1.1.
Re: cvsignore problems [message #78286 is a reply to message #78260] Sat, 19 July 2003 01:46 Go to previous messageGo to next message
Laura Werner wrote:
>> directory.
It's worth a lot, actually. It tells me that I am neither crazy and
casts doubt on whether or not my Eclipse installation is damaged.
With kind regards,
Josh Rehman
Discover your city: citysearch.com
Re: cvsignore problems [message #78539 is a reply to message #78286] Sun, 20 July 2003 15:23 Go to previous message
Hi Josh,
Have you filed a bug on this yet, or looked to see if there's an
existing one? If not, I'll try to get to it...
-- Laura
Previous Topic:"Remote Version" Quickdiff reference provider missing
Next Topic:'flag' a specific .java file as not being part of the buildprocess?
Current Time: Thu Jul 17 22:20:36 EDT 2025
Powered by FUDForum. Page generated in 0.07815 seconds
