FIT tests in the TPTP framework [message #78201] |
Fri, 21 July 2006 04:42  |
Originally posted by: laksefisker.hotmail.com
Greetings!
I'm attempting to extend the TPTP framework to handle FIT tests, and was
wondering: have anyone attempted this in the past?
I've followed the "Creating a custom execution environment" tutorial that
was in one of the presentation slides for EclipseCon2005 - the one where
PERL tests were integrated, and am at the point where the only thing I lack
is the buisness logic that actually runs the FIT tests.
I've figured that I should extend the HyadesTestRunner (or the HyadesRunner?
Which one?), but I'm not sure exactly how.
Any tips and pointers would be greatly appreciated.
Henrik W Lund
Re: FIT tests in the TPTP framework [message #83106 is a reply to message #78201] |
Mon, 11 September 2006 08:03   |
Hi Henrick,
Although I am not aware of examples of using the TPTP framework to
handle FIT tests, your approach of using a custom test type and execution
environment will work.
As for the runner extension, the tutorial contains instructions for
implementing a custom runner in Hyades V3.3.x so here are few suggestions
specific for TPTP V4.x:
1) Make sure you have properly added your runner to the classpath in the
agent controller as described in slides 83/84. In TPTP 4.2, the directory
you should be working with is
<AgentControllerHome>\plugins\org.eclipse.hyades.test.tools.core_ <buildID>\config
for the pluginconfig.xml file.
2) Make sure you have not inadvertently copied Microsoft "smart quotes" from
the text of the presentation into your pluginconfig.xml file (making it an
invalid XML file.) You can easily check this by trying to open the file in
a web browser.
3) If you're convinced that your runner has been properly added to the agent
controller's classpath and that the pluginconfig.xml file contains all valid
XML characters, you will need to do some debugging to determine why your
runner process is not coming up properly. As the tutorial describes on
slide 51, there are 3 JVMs you may be concerned with. I suggest debugging
the workbench first, as it is the easiest to debug, and often has enough
information to determine the problem. Set a breakpoint in your executable
object adapter class and double check the arguments that are being passed to
the JVM. Ensure that these arguments are correct. Double check this by
trying to launch a jvm with the classpath described in your modified
pluginconfig.xml file, and with the command line arguments constructed by
your executable object adapter. This shouldn't actually run a test
successfully, but it also should not complain that it couldn't find your
runner class. If it does, then you have a problem with the classpath
described by your pluginconfig,xml.
Paul
"Henrik W Lund" <laksefisker@hotmail.com> wrote in message
news:baa5ffa06498c87ac982a07159@news.eclipse.org...
> Greetings!
> lack is the buisness logic that actually runs the FIT tests.
> HyadesRunner? Which one?), but I'm not sure exactly how.
> Henrik W Lund
Re: FIT tests in the TPTP framework [message #87385 is a reply to message #78201] |
Wed, 15 November 2006 08:49  |
Originally posted by: rotbart.e-sim.co.il
Henrik W Lund wrote:
> Greetings!
> that was in one of the presentation slides for EclipseCon2005 - the one
> where PERL tests were integrated, and am at the point where the only
> thing I lack is the buisness logic that actually runs the FIT tests.
> Henrik W Lund
Henrik,
If you succeed in running FIT under TPTP I would be very interested in
trying your integration code.
- Fred
FUDForum. Page generated in 0.15886 seconds
