Home » Modeling » Epsilon » Loading multiple model instances, for translation
Loading multiple model instances, for translation [message #7007] |
Mon, 15 December 2008 06:27  |
I've so far been using ETL to transform a model A to model B (through
Ant). In general, the transformation needs to be applied to several source
models of A, to progressively build up the target model (which
accommodates this). I guess this is a common scenario, but am not sure of
the right way to do it.. Any ideas? I assumed I'd be able to perform
<epsilon.loadModel name="A" ... to load the first instance of A, then
perform the translation, and then <epsilon.loadModel name="A" ... again,
to load the second instance of A, perform translation, etc. However, this
approach only loads the first instance of A. Any help/pointers would be
very handy.
Ta,
Edd
Re: Loading multiple model instances, for translation [message #7034 is a reply to message #7007] |
Mon, 15 December 2008 07:28   |
Hi Edd,
I suspected that a model.dispose between the two model.load would sort
thit out - but this doesn't seem to be the case. Could you please file a
bug against this? I'll start looking for a solution asap.
Dimitris
> source models of A, to progressively build up the target model (which
> of the right way to do it.. Any ideas? I assumed I'd be able to perform
> this approach only loads the first instance of A. Any help/pointers
> would be very handy.
> Ta,
> Edd
Re: Loading multiple model instances, for translation [message #7058 is a reply to message #7034] |
Mon, 15 December 2008 11:02   |
Hi Edd,
I've fixed this problem and committed changes to the SVN. Are you using
Epsilon from source (SVN) or through the update site?
Dimitris
Dimitrios Kolovos wrote:
> Hi Edd,
> Cheers,
> Dimitris
>> perform <epsilon.loadModel name="A" ... to load the first instance of
>> A, then perform the translation, and then <epsilon.loadModel name="A"
>> ... again, to load the second instance of A, perform translation, etc.
>> However, this approach only loads the first instance of A. Any
>> help/pointers would be very handy.
>> Ta,
>> Edd
Re: Loading multiple model instances, for translation [message #7081 is a reply to message #7058] |
Mon, 15 December 2008 11:26   |
Further to my previous email, to load a model with the same name, you'll
still need to first dispose the previous one e.g:
<epsilon.loadModel name="A" type="EMF">
</epsilon.loadModel>
<epsilon.disposeModel model="A"/>
Dimitris
> Hi Edd,
> Cheers,
> Dimitris
>> Hi Edd,
>> a bug against this? I'll start looking for a solution asap.
>> Cheers,
>> Dimitris
>>> sure of the right way to do it.. Any ideas? I assumed I'd be able to
>>> etc. However, this approach only loads the first instance of A. Any
>>> Ta,
>>> Edd
Re: Loading multiple model instances, for translation [message #7127 is a reply to message #7104] |
Mon, 15 December 2008 13:31   |
> Wow, that was quite a speedy fix :), haven't had time yet to submit a
> bug report. Would you like me to do this still, for your records?
That'd be great!
> By the way, I've been using Epsilon via the update site. Should I use it
> via the SVN (and if so are there some instructions on how to use it like
> that) -- sorry, in meeting at mo...
No worries. Since waiting for the next version release is probably not
an option, you could either switch to the SVN version (see
http://www.eclipse.org/gmt/epsilon/doc/EpsilonSVN.pdf) or patch your
existing installation. To patch your installation you'd need to replace
\plugins\org.eclipse.epsilon.workflow_xxx\lib\org.eclipse.ep silon.workflow.jar
with the newer version available under
http://dev.eclipse.org/svnroot/modeling/org.eclipse.gmt.epsi lon/trunk/plugins/org.eclipse.epsilon.workflow/lib/
> Cheers,
> Edd
Dimitris
Re: Loading multiple model instances, for translation [message #7150 is a reply to message #7127] |
Wed, 17 December 2008 04:49  |
Thanks a lot for filing
https://bugs.eclipse.org/bugs/show_bug.cgi?id=258912.
Dimitris
> That'd be great!
>> it via the SVN (and if so are there some instructions on how to use it
>> like that) -- sorry, in meeting at mo...
>> Cheers,
>> Edd
> Cheers,
> Dimitris
Re: Loading multiple model instances, for translation [message #563121 is a reply to message #7007] |
Hi Edd,
Dimitris
> Ta,
> Edd
Re: Loading multiple model instances, for translation [message #563143 is a reply to message #7034] |
Hi Edd,
Dimitris
> Hi Edd,
> Cheers,
> Dimitris
>> Ta,
>> Edd
Re: Loading multiple model instances, for translation [message #563171 is a reply to message #7058] |
Dimitris
> Hi Edd,
> Cheers,
> Dimitris
>> Hi Edd,
>> Cheers,
>> Dimitris
>>> Ta,
>>> Edd
Re: Loading multiple model instances, for translation [message #563192 is a reply to message #7081] |
Mon, 15 December 2008 12:14  |
Wow, that was quite a speedy fix :), haven't had time yet to submit a bug
Edd
Re: Loading multiple model instances, for translation [message #563217 is a reply to message #7104] |
That'd be great!
> Cheers,
> Edd
Dimitris
Re: Loading multiple model instances, for translation [message #563242 is a reply to message #7127] |
Dimitris
> That'd be great!
>> Cheers,
>> Edd
> Cheers,
> Dimitris
Current Time: Fri Jul 18 19:13:08 EDT 2025
Powered by FUDForum. Page generated in 0.10373 seconds
