Home » Newcomers » Newcomers » Error in launchin eclipse platform
Error in launchin eclipse platform [message #78090] Wed, 15 June 2005 10:10 Go to next message
Originally posted by: reema.kunar.gmail.com
Hello ,
I am having the same problem in lauching the eclipse.exe.I have my
PATH(system varaible as ) as :
PATH=C:\j2sdk1.4.2_05\bin;C:\opt\eate\watchdog\EXPAT-~1.5\Li bs;C:\WINNT\system32..etc
etc .
JAVA_HOME=C:\j2sdk1.4.2_05\
CLASSPATH=C:\j2sdk1.4.2_05\lib\tools.jar;C:\j2sdk1.4.2_05\li b\dt.jar;
I want to use eclipse 3.0.2 and so i installed it at c:\myProg\Eclipse
previously i had another version at c:\eclipse.(I removed this c:\eclipse
first.)
As soon has i click eclipse.exe in the c:\myProg\Eclipse i get an error in
the
c:\myProg\Eclipse\configuration\ directory as ...which is pasted below:
!SESSION Wed Jun 15 15:27:19 CEST 2005
!ENTRY org.eclipse.core.launcher 4 0 Jun 15, 2005 15:27:19.831
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.RuntimeException: Could not find framework
at org.eclipse.core.launcher.Main.getBootPath(Main.java:395)
at org.eclipse.core.launcher.Main.basicRun(Main.java:174)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
Please advice me how to tackle this and start using eclipse.
Re: Error in launchin eclipse platform [message #78121 is a reply to message #78090] Wed, 15 June 2005 10:21 Go to previous message
Originally posted by: hcs33.egon.gyaloglo.hu
Do you use Windows ME or using a FAT16/FAT32 partition? There is a bug
report for such a problem:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=93329
It has been fixed in the Eclipse 3.1 stream. You should try Eclipse 3.1RC2
or wait for the final version (it will be about here within 2-3 weeks I
hope).
HTH,
Csaba
Reima wrote:
> Hello ,
em32..etc
> etc .
> first.)
> the
> !STACK
Previous Topic:newbie Q: Eclipse for j2me
Next Topic:How to get the java 1.4 documentation inside eclipse ?
Current Time: Sat Aug 30 22:43:52 EDT 2025
Powered by FUDForum. Page generated in 0.08789 seconds
