Home » Archived » M2M (model-to-model transformation) » [ATL] XML to XML transformation: XSLT or ATL?
[ATL] XML to XML transformation: XSLT or ATL? [message #78084] Tue, 01 April 2008 11:36 Go to next message
Originally posted by: xiong.irit.fr
Hi all,
In the case of an XML to XML transformation, I was wondering whether using
XSLT or using ATL is the best solution.
In particular, my questions would be:
1) What are the advantages/disadvantages of each of these languages?
2) Are these transformations equivalent? (e.g do ATL and XSLT languages
have the same expressive power?)
Could someone give me a hint about that?
Yours sincerely,
Joseph Xiong.
Re: [ATL] XML to XML transformation: XSLT or ATL? [message #78372 is a reply to message #78084] Fri, 04 April 2008 17:05 Go to previous messageGo to next message
Hi there,
XSLT has been made for XML to XML transformations and it can do that
job very very well. I doubt there are good reasons to perfer ATL over
XSLT and if so I would be really curious to hear them.
I would assume using ATL instead of XSLT is not advisable.
Richard
Joseph Xiong schrieb:
> Hi all,
> using XSLT or using ATL is the best solution.
> Yours sincerely,
> Joseph Xiong.
Re: [ATL] XML to XML transformation: XSLT or ATL? [message #78435 is a reply to message #78084] Sun, 06 April 2008 06:49 Go to previous messageGo to next message
Originally posted by: milan.milanovic.org
Dear Joseph,
Joseph Xiong wrote:
> Hi all,
Advantages of this approach are that when you have two XML files injected
into XML models and later to the domain metamodel, and the same for other
XML language and its metamodel, then you can define transformations
between that two metamodels on a very high level, using only metamodel
concepts (classes) and of course powerfull ATL language.
Disadvatages is that you need to have or define metamodel for you
XML-based language, and to define usually two uni-directional
transformations, namely, XML2MM and MM2XML.
Those two languages works in completely different technical spaces, so
they work with little bit different concepts. But, I must say that when
you have transformed you XML files into the domain metamodel instance, it
is easier and more expressive to work with ATL. More on this you can find
here:
http://www.research.ibm.com/journal/sj/453/czarnecki.pdf
http://dx.doi.org/10.1007/978-3-540-72982-2_25
_____________________________
Best regards, Milan Milanovic
> Yours sincerely,
> Joseph Xiong.
Re: [ATL] XML to XML transformation: XSLT or ATL? [message #79391 is a reply to message #78435] Wed, 16 April 2008 08:59 Go to previous message
Many thanks to your answers ;)
Joseph Xiong
Previous Topic:[ATL] UML 2 BPEL
Next Topic:[QVTO]Incompatible input type 'modelparam::ResourceEObject', expected 'uml::Model'
Current Time: Sat Aug 30 06:21:34 EDT 2025
Powered by FUDForum. Page generated in 0.06633 seconds
