Home » Modeling » EMF » Ecore UUID serialization doubles id
Ecore UUID serialization doubles id [message #727484] Wed, 21 September 2011 07:06 Go to next message
Hi there,
I'm using an Ecore model with XML serialization using UUIDs for unique
identifiers.
I do this by overriding the useUUIDs() method in the corresponding
XMLResourceImpl with returning true.
Now the "id" property of a model is just another EMF feature and hence,
I can change it manually. If I do so, e.g. set an id to "foo23" and save
the model in the sample tree editor, it will save an xml element with
two id attributes, i.e. invalid XML like this
<myReference xsi:type="foo:MyType" id="_WIWryuRAEeC_QIwRrW2zOQ" id="foo23">
</myReference>
I found out, that the additional ID is assigned when loading the model.
So I also overwrote addignIDsWhileLoading() with false in the
XMLResourceImpl.
Now when I programmatically do a resource.save(), I again get the
doubled id Attribute this time from
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElementID(EObject o)
because it is nowhere checked whether the element might already have
feature called "id" that is already set.
Is this behavior a bug or a feature?
Rationale: I want to use UUIDs, but in some cases, I create my model by
a M2M transformation from some other language where I would like to
preserve the UUIDs from the origin model. So I copy them to the target
model semantically as "id" is just another business property in my model.
Hauke
Re: Ecore UUID serialization doubles id [message #727485 is a reply to message #727484] Wed, 21 September 2011 07:28 Go to previous message
Hauke,
Comments below.
On 21/09/2011 7:06 AM, Hauke Fuhrmann wrote:
> Hi there,
> identifiers.
> hence, I can change it manually. If I do so, e.g. set an id to "foo23"
> and save the model in the sample tree editor, it will save an xml
> element with two id attributes, i.e. invalid XML like this
> id="foo23">
> </myReference>
> model. So I also overwrote addignIDsWhileLoading() with false in the
> XMLResourceImpl.
The extrinsic IDs and intrinsic IDs are two different things and there
is a general assumption that you use one or the other, but not both. It
clearly don't make sense to have more than one ID, so you should decide
on one approach (let resource assign and manage them) or the other
(model them in the objects themselves and let them control and manage them).
> by a M2M transformation from some other language where I would like to
XMLResource.setID can be used to assign an ID of your choice.
> So I copy them to the target model semantically as "id" is just
There's no support for mixing the two approaches.
Maybe you look into specializing XMLResourceImpl to avoid generating a
UUID for objects with an intrinsic ID. Not sure how best to do that...
Maybe getID would return the intrinsic ID if there is one... Or maybe
attachedHelper should ignore objects with an intrinsic ID...
> Cheers,
> Hauke
Previous Topic:Xcore, Ecore and Genmodel in other DSLs
Next Topic:[CDO] Launching server programmatically
Current Time: Sat Jul 19 17:57:12 EDT 2025
Powered by FUDForum. Page generated in 0.07879 seconds
