Home » Eclipse Projects » Eclipse Platform » CVS Dialog Trouble
CVS Dialog Trouble [message #78079] Wed, 18 June 2003 17:01 Go to next message
Originally posted by: jgrimshaw.knowledgepoint.com
I'm having a fundamental problem in trying to use Eclipse to browse a
CVS repository. I'm using Eclipse 2.1.0 on a Slackware 9 distribution
with Dropline Gnome.
From the CVS Repositories view, I choose New-->Repository Location...
from the context menu and the Add CVS Repository dialog comes up. In
that dialog, the dropdown list for Connection type is blank, so I can't
select (or type in) the correct conection type (:pserver: in this case).
I can connect and use the repository with CVS command line tools.
Any ideas? Thanks in advance.
--Jeff
Re: CVS Dialog Trouble [message #80638 is a reply to message #78079] Mon, 23 June 2003 10:34 Go to previous message
Originally posted by: Michael_Valenta.oti.com
Does restarting Eclipse fix the problem (i.e. someone else reported this
and stated that restarting fixed the problem)? If it doesn't fix the
problem, please log a bug report against Platform VCM.
> --Jeff
Previous Topic:How to create a customized Editor Input?
Next Topic:Changing order of projects in package explorer?
Current Time: Wed Oct 29 22:08:51 EDT 2025
Powered by FUDForum. Page generated in 0.24264 seconds
