Home » Modeling » GMF (Graphical Modeling Framework) » Ubuntu and GMF
Ubuntu and GMF [message #78069] Wed, 15 November 2006 21:16 Go to next message
Originally posted by: cedric.jeanneret.epfl.ch
Hi all,
GMF behaves strangely on Ubuntu Edgy. In the main "diagram" window, only
the first node is drawn. Its labels, other nodes and links are not
present on the diagram. The outline view is working perfectly.
I've tested with several diagrams, all of them present this strange
behavior. They are perfectly working on Windows XP.
I'm using latest Callisto release, with GMF 1.02. Error log doesn't
provide any error.
Any idea ?
Cédric
Re: Ubuntu and GMF [message #78085 is a reply to message #78069] Wed, 15 November 2006 21:30 Go to previous messageGo to next message
This type of question has been asked before
( http://dev.eclipse.org/newslists/news.eclipse.technology.gmf /msg03999.html)
, so I've added it to the FAQ
http://wiki.eclipse.org/index.php/Graphical_Modeling_Framewo rk_FAQ#Why_can.2
7t_I_see_elements_on_my_diagram.2C_although_I_can_select_the m.3F
Hope this helps.
Best,
Rich
On 11/15/06 9:16 PM, in article ejghmj$39e$1@utils.eclipse.org, "Cédric
Jeanneret" <cedric.jeanneret@epfl.ch> wrote:
> Hi all,
> provide any error.
> Any idea ?
> Cédric
Re: Ubuntu and GMF [message #78100 is a reply to message #78085] Wed, 15 November 2006 22:25 Go to previous messageGo to next message
Thank you for your answer.
I've already Cairo installed (1.2.4). I'll try with the latest.
Cédric
Richard Gronback wrote:
> Hope this helps.
> Best,
> Rich
>> Hi all,
>> provide any error.
>> Any idea ?
>> Regards,
>> Cédric
Re: Ubuntu and GMF [message #78630 is a reply to message #78100] Fri, 17 November 2006 13:29 Go to previous messageGo to next message
have a look at https://bugs.eclipse.org/bugs/show_bug.cgi?id=164623
Fedor.
Cédric Jeanneret wrote:
> Cédric
>> Hope this helps.
>> Best,
>> Rich
>>> Hi all,
>>> provide any error.
>>> Any idea ?
>>> Regards,
>>> Cédric
Re: Ubuntu and GMF [message #78681 is a reply to message #78630] Sat, 18 November 2006 03:00 Go to previous messageGo to next message
It solved my problem =)
Thank you very much.
Fedor Isakov wrote:
> Cheers,
> Fedor.
>> Regards,
>> Cédric
>>> Hi,
>>> Hope this helps.
>>> Best,
>>> Rich
>>>> Hi all,
>>>> only
>>>> provide any error.
>>>> Any idea ?
>>>> Regards,
>>>> Cédric
Re: Ubuntu and GMF [message #80137 is a reply to message #78630] Wed, 22 November 2006 09:57 Go to previous messageGo to next message
Hi Team,
I think the issue is a newer version of GTK2 that we have not tested.
I added a comment to https://bugs.eclipse.org/bugs/show_bug.cgi?id=159840
On my RedHat workstation I have the following RPM:
gtk2.4.13-19
pango1.6.0-9
Can you confirm on Ubuntu Linux 6.10 by running rpm -qa and tell me what you
have?
gtk2.10.6-0 ?
libpango1.14.5-0 ?
Cheers...
Anthony
"Fedor Isakov" <fisakov@gmail.com> wrote in message
news:ejkv31$9ib$1@utils.eclipse.org...
> Cheers,
> Fedor.
> C
Re: Ubuntu and GMF [message #80260 is a reply to message #80137] Wed, 22 November 2006 16:12 Go to previous messageGo to next message
Yep, I do confirm:
gtk2.10.6-0
libpango1.14.5-0
Cédric
Anthony Hunter wrote:
> Hi Team,
> gtk2.4.13-19
> pango1.6.0-9
> have?
> gtk2.10.6-0 ?
> libpango1.14.5-0 ?
> Cheers...
> Anthony
>> Cheers,
>> Fedor.
>>> Hi,
>>> Regards,
>>> Cédric
>>>> Hi,
>>>> Hope this helps.
>>>> Best,
>>>> Rich
>>>>> Hi all,
>>>>> only
>>>>> provide any error.
>>>>> Any idea ?
>>>>> Regards,
>>>>> Cédric
Re: Ubuntu and GMF [message #80564 is a reply to message #80137] Thu, 23 November 2006 18:00 Go to previous messageGo to next message
> have?
> gtk2.10.6-0 ?
> libpango1.14.5-0 ?
Ubuntu 6.10 (Edgy Eft):
aptitude show libgtk2.0-0 libpango1.0-0 | egrep 'Package:|Version:'
Package: libgtk2.0-0
Version: 2.10.6-0ubuntu1
Package: libpango1.0-0
Version: 1.14.5-0ubuntu1
The 'ubuntu1' suffix is most likely an Ubuntu-specific patch.
Best,
Fedor.
Re: Ubuntu and GMF [message #80793 is a reply to message #80564] Fri, 24 November 2006 17:08 Go to previous messageGo to next message
Thanks Fedor and C
Re: Ubuntu and GMF [message #80808 is a reply to message #80793] Fri, 24 November 2006 17:21 Go to previous messageGo to next message
the library is libcairo2 1.2.4-1ubuntu2
Cédric
> Thanks Fedor and Cédric
> So the issue cannot be GTK
> It must be a Cairo issue.
> Can you tell me if you have a version of libcairo on Ubuntu?
> I know that there is no such library on RedHat and this means that the
> libcairo-swt.so library in the Eclipse home is being used (same directory
> where eclipse binary is found).
> Cheers...
> Anthony
> news:ek596t$48c$1@utils.eclipse.org...
>>> you have?
>>> gtk2.10.6-0 ?
>>> libpango1.14.5-0 ?
>> Best,
>> Fedor.
Re: Ubuntu and GMF [message #80828 is a reply to message #80793] Sat, 25 November 2006 10:35 Go to previous messageGo to next message
indeed, there is a Cairo library in Ubuntu:
aptitude show libcairo2 | egrep 'Package:|Version:'
Package: libcairo2
Version: 1.2.4-1ubuntu2
Best,
Fedor.
> Cheers...
> Anthony
>>> you have?
>>> gtk2.10.6-0 ?
>>> libpango1.14.5-0 ?
>> Best,
>> Fedor.
Re: Ubuntu and GMF [message #81207 is a reply to message #80828] Mon, 27 November 2006 13:25 Go to previous messageGo to next message
I am wondering if an option is to try replacing the 1.2.4-1ubuntu2 with the
libcairo-swt.so and see if that resolves the issue. Then we will know that
the new or old version of cairo is the issue.
I am not sure which version of cairo is included in libcairo-swt.so , but I
think that Eclipse is likely using the 1.2.4-1ubuntu2 rather than the one
provided with Eclipse. Not if you "ldd eclipse", the cairo library is not
listed as a dependant library, so I am not sure how to tell which cairo SWT
is finding.
I have added the Eclipse platform SWT newgroup to see if this is a known
issue.
Cheers...
Anthony
I cannot tell
news:ek9nr8$bbf$1@utils.eclipse.org...
> Package: libcairo2
> Best,
> Fedor.
>> Thanks Fedor and C
Re: Ubuntu and GMF [message #81293 is a reply to message #81207] Mon, 27 November 2006 17:50 Go to previous messageGo to next message
Hi Anthony,
this thought has also crossed my mind. I naively tried to substitute the
libcairo.so.2 on my system with the libcairo-swt.so from Eclipse,
thinking it could help, but it looks like these libraries are completely
unrelated and not compatible in any way... Let the linux gurus here
forgive my ignorance.
Here's what I tried:
- I ran Eclipse with strace to see where it looks for libcairo.so.2.
It tries many locations before resorting to /usr/lib, in my case the
last directory was /usr/lib/jvm/java-1.5.0-sun-1.5.0.08/lib/i386/
- I put a symlink to libcairo-swt.so into that directory and named it
libcairo.so.2
- After all this, any attempts to start Eclipse were unsuccessful.
So, I call the myth that we can substitute Cairo library with the one
provided with Eclipse debunked. Unless, of course, I did something
completely wrong, which is quite likely.
Best,
Fedor.
> Hi
> is finding.
> issue.
> Cheers...
> Anthony
> I cannot tell
>> Package: libcairo2
>> Best,
>> Fedor.
>>> Cheers...
>>> Anthony
>>>> Hi,
>>>>> what you have?
>>>>> gtk2.10.6-0 ?
>>>>> libpango1.14.5-0 ?
>>>> Best,
>>>> Fedor.
Re: Ubuntu and GMF [message #82158 is a reply to message #78681] Fri, 01 December 2006 11:34 Go to previous messageGo to next message
I've the same problem on Kubuntu Edgy, so I wonder how did you solve it.
Have you installed an other version of libcairo ?
Francois Gaudin
Makina Corpus
Re: Ubuntu and GMF [message #82539 is a reply to message #82158] Mon, 04 December 2006 09:28 Go to previous message
it may have been wise to read the whole thread in order to understand
the topic.
At the moment, there is no good solution to this problem, only a
workaround, which is to disable anti-aliasing. The GMF FAQ has more info:
http://wiki.eclipse.org/index.php/Graphical_Modeling_Framewo rk_FAQ#Why_can.27t_I_see_elements_on_my_diagram.2C_although_ I_can_select_them.3F
Fedor.
> Francois Gaudin
> Makina Corpus
Previous Topic:How to change LEDs' order in a Circuit
Next Topic:navigator in package browser
Current Time: Mon Jul 21 23:24:27 EDT 2025
Powered by FUDForum. Page generated in 0.05308 seconds
