Home » Modeling » GMF (Graphical Modeling Framework) » Ubuntu and GMF
Ubuntu and GMF [message #78069] |
Wed, 15 November 2006 21:16  |
Originally posted by: cedric.jeanneret.epfl.ch
Hi all,
GMF behaves strangely on Ubuntu Edgy. In the main "diagram" window, only
the first node is drawn. Its labels, other nodes and links are not
present on the diagram. The outline view is working perfectly.
I've tested with several diagrams, all of them present this strange
behavior. They are perfectly working on Windows XP.
I'm using latest Callisto release, with GMF 1.02. Error log doesn't
provide any error.
Any idea ?
Cédric
Re: Ubuntu and GMF [message #78085 is a reply to message #78069] |
Wed, 15 November 2006 21:30   |
This type of question has been asked before
( http://dev.eclipse.org/newslists/news.eclipse.technology.gmf /msg03999.html)
, so I've added it to the FAQ
http://wiki.eclipse.org/index.php/Graphical_Modeling_Framewo rk_FAQ#Why_can.2
7t_I_see_elements_on_my_diagram.2C_although_I_can_select_the m.3F
Hope this helps.
Best,
Rich
On 11/15/06 9:16 PM, in article ejghmj$39e$1@utils.eclipse.org, "Cédric
Jeanneret" <cedric.jeanneret@epfl.ch> wrote:
> Hi all,
> provide any error.
> Any idea ?
> Cédric
Re: Ubuntu and GMF [message #78100 is a reply to message #78085] |
Wed, 15 November 2006 22:25   |
Thank you for your answer.
I've already Cairo installed (1.2.4). I'll try with the latest.
Cédric
Richard Gronback wrote:
> Hope this helps.
> Best,
> Rich
>> Hi all,
>> provide any error.
>> Any idea ?
>> Regards,
>> Cédric
Re: Ubuntu and GMF [message #78630 is a reply to message #78100] |
Fri, 17 November 2006 13:29   |
have a look at https://bugs.eclipse.org/bugs/show_bug.cgi?id=164623
Fedor.
Cédric Jeanneret wrote:
> Cédric
>> Hope this helps.
>> Best,
>> Rich
>>> Hi all,
>>> provide any error.
>>> Any idea ?
>>> Regards,
>>> Cédric
Re: Ubuntu and GMF [message #78681 is a reply to message #78630] |
Sat, 18 November 2006 03:00   |
It solved my problem =)
Thank you very much.
Fedor Isakov wrote:
> Cheers,
> Fedor.
>> Regards,
>> Cédric
>>> Hi,
>>> Hope this helps.
>>> Best,
>>> Rich
>>>> Hi all,
>>>> only
>>>> provide any error.
>>>> Any idea ?
>>>> Regards,
>>>> Cédric
Re: Ubuntu and GMF [message #80260 is a reply to message #80137] |
Wed, 22 November 2006 16:12   |
Yep, I do confirm:
gtk2.10.6-0
libpango1.14.5-0
Cédric
Anthony Hunter wrote:
> Hi Team,
> I think the issue is a newer version of GTK2 that we have not tested.
> I added a comment to https://bugs.eclipse.org/bugs/show_bug.cgi?id=159840
> On my RedHat workstation I have the following RPM:
> gtk2.4.13-19
> pango1.6.0-9
> Can you confirm on Ubuntu Linux 6.10 by running rpm -qa and tell me what you
> have?
> gtk2.10.6-0 ?
> libpango1.14.5-0 ?
> Cheers...
> Anthony
> "Fedor Isakov" <fisakov@gmail.com> wrote in message
> news:ejkv31$9ib$1@utils.eclipse.org...
>> Cheers,
>> Fedor.
>>> Hi,
>>> Regards,
>>> Cédric
>>>> Hi,
>>>> Hope this helps.
>>>> Best,
>>>> Rich
>>>>> Hi all,
>>>>> only
>>>>> provide any error.
>>>>> Any idea ?
>>>>> Regards,
>>>>> Cédric
Re: Ubuntu and GMF [message #81293 is a reply to message #81207] |
Mon, 27 November 2006 17:50   |
Hi Anthony,
this thought has also crossed my mind. I naively tried to substitute the
libcairo.so.2 on my system with the libcairo-swt.so from Eclipse,
thinking it could help, but it looks like these libraries are completely
unrelated and not compatible in any way... Let the linux gurus here
forgive my ignorance.
Here's what I tried:
- I ran Eclipse with strace to see where it looks for libcairo.so.2.
It tries many locations before resorting to /usr/lib, in my case the
last directory was /usr/lib/jvm/java-1.5.0-sun-1.5.0.08/lib/i386/
- I put a symlink to libcairo-swt.so into that directory and named it
libcairo.so.2
- After all this, any attempts to start Eclipse were unsuccessful.
So, I call the myth that we can substitute Cairo library with the one
provided with Eclipse debunked. Unless, of course, I did something
completely wrong, which is quite likely.
Best,
Fedor.
> Hi
> I am wondering if an option is to try replacing the 1.2.4-1ubuntu2 with the
> libcairo-swt.so and see if that resolves the issue. Then we will know that
> the new or old version of cairo is the issue.
> I am not sure which version of cairo is included in libcairo-swt.so , but I
> think that Eclipse is likely using the 1.2.4-1ubuntu2 rather than the one
> provided with Eclipse. Not if you "ldd eclipse", the cairo library is not
> listed as a dependant library, so I am not sure how to tell which cairo SWT
> is finding.
> I have added the Eclipse platform SWT newgroup to see if this is a known
> issue.
> Cheers...
> Anthony
> I cannot tell
> news:ek9nr8$bbf$1@utils.eclipse.org...
>> indeed, there is a Cairo library in Ubuntu:
>> aptitude show libcairo2 | egrep 'Package:|Version:'
>> Package: libcairo2
>> Version: 1.2.4-1ubuntu2
>> Best,
>> Fedor.
>>> Thanks Fedor and Cédric
>>> So the issue cannot be GTK
>>> It must be a Cairo issue.
>>> Can you tell me if you have a version of libcairo on Ubuntu?
>>> I know that there is no such library on RedHat and this means that the
>>> libcairo-swt.so library in the Eclipse home is being used (same directory
>>> where eclipse binary is found).
>>> Cheers...
>>> Anthony
>>> news:ek596t$48c$1@utils.eclipse.org...
>>>> Hi,
>>>>> what you have?
>>>>> gtk2.10.6-0 ?
>>>>> libpango1.14.5-0 ?
>>>> Ubuntu 6.10 (Edgy Eft):
>>>> aptitude show libgtk2.0-0 libpango1.0-0 | egrep 'Package:|Version:'
>>>> Package: libgtk2.0-0
>>>> Version: 2.10.6-0ubuntu1
>>>> Package: libpango1.0-0
>>>> Version: 1.14.5-0ubuntu1
>>>> The 'ubuntu1' suffix is most likely an Ubuntu-specific patch.
>>>> Best,
>>>> Fedor.
Current Time: Fri Jul 18 11:53:06 EDT 2025
Powered by FUDForum. Page generated in 0.29264 seconds
