Home » Eclipse Projects » Remote Application Platform (RAP) » Login UI issue
Login UI issue [message #78027] Wed, 12 March 2008 03:10 Go to next message
Originally posted by: dnise.hotmail.com
Hi all:
I have created a login UI interface before entrying my application. I have
created a shell which included userName and password controls in
createUI method. so I can display a Login UI interface before launching
whole system.it would cut down some resource consumption.if someone
inputed correct username and password,he can pass into system. I have
implemented these too. but there was a problem that how could I return to
login interface when i logout the system? how could i return to these
shell?
can i implement this in RAP??
is there anyone can give me some advice?
Thanks in advance
best regards
dnise
Re: Login UI issue [message #78044 is a reply to message #78027] Wed, 12 March 2008 03:29 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
does logout close your workbench? If so you could create a while loop in
your IEntryPoint#createUI() implementation:
display creation
while( !exit )
loginShell
createWorkbench
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: dnise [mailto:dnise@hotmail.com]
Bereitgestellt: Mittwoch, 12. März 2008 08:11
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: Login UI issue
Betreff: Login UI issue
Hi all:
have created a shell which included userName and password controls in
to login interface when i logout the system? how could i return to these
shell?
Thanks in advance
best regards
dnise
Re: Login UI issue [message #78074 is a reply to message #78044] Wed, 12 March 2008 03:59 Go to previous messageGo to next message
Frank Appel wrote:
> display creation
> while( !exit )
> loginShell
> createWorkbench
> Ciao
> Frank
> Hi all:
> shell?
> Thanks in advance
> best regards
> dnise
HI Franks:
Thanks for the first. Assume my application includes more than one
perspective . It will close all the perspectives, release all the resource
which application take up when logout system. it won't close workbench. my
code as follows:
Shell shell =new Shell(display);
add some control codes.
while (!shell.isDisposed()) {
if (login) { // if username and password are correct,we entry into system
break;
if (!display.readAndDispatch()) {
display.sleep();
return PlatformUI.createAndRunWorkbench(display, advisor);
I wrote all the code which logout system in a action. My object is how to
return the shell ??
Re: Login UI issue [message #78147 is a reply to message #78044] Wed, 12 March 2008 22:42 Go to previous messageGo to next message
Hi Frank:
maybe I haven't described the problem clearly.The createUI method
is a entrance of application.In order to avoid a long startup time
and preserve resources, so I have created a shell and filled some controls
on it before "return PlatformUI.createAndRunWorkbench(display, advisor)",
it can entry into application while inputing correct username and password.
there is a logout button in system of each "ViewPart". i wanna to display
the shell which was create firstly. I don't know how to return to this
shell, I think the workbench has been closed, because it haven't created
workbench as shell generated. my codes as follows:
public int createUI() {
Display display = PlatformUI.createDisplay();
WorkbenchAdvisor advisor = new ApplicationWorkbenchAdvisor();
int i = 0;
shell = new Shell(display, SWT.NO_TRIM);
shell.setLayout(new GridLayout(2, false));
Label lbl1 = new Label(shell, SWT.NONE);
lbl1.setText("UserName:");
lbl1.setSize(40, 30);
txtUserName = new Text(shell, SWT.BORDER);
txtUserName.setSize(90, 30);
Label lbl2 = new Label(shell, SWT.NONE);
lbl2.setText("Password:");
lbl2.setSize(40, 30);
txtPassword = new Text(shell, SWT.BORDER);
txtPassword.setSize(90, 30);
Button btn = new Button(shell, SWT.PUSH);
btn.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent e) {
login = validata_Login(txtUserName.getText(), txtPassword
.getText());
System.out.println(login);
btn.setText("submit");
btn.setSize(50, 30);
shell.setSize(400, 300);
shell.setMaximized(false);
shell.open();
shell.layout();
if (login) {
break;
display.sleep();
Thanks & regards
Dnise
2008-03-13
Re: Login UI issue [message #78162 is a reply to message #78147] Wed, 12 March 2008 23:35 Go to previous messageGo to next message
Originally posted by: anupgokhale.rediffmail.com
dnise wrote:
> Hi Frank:
I think your are unnecessarily over complicating the problem. I can
suggest two simple solutions:
1. Each of your views as a "Log-Out" menu/toolbar. When user clicks on
this menu, you can perform all clean up operations, and close all th
eopen editors and views. In this case you workbench will remain open.
You can then display the "Log-In" shell/dialog. In this shell, after
user credentials have been validated, you can decide whether the shell
has been loaded for the in which case you can run
PlatformUI.createAndRunWorkbench. If the log-in shell has been displayed
due to a log-off action, then the work bench has already been created
and you only need to load the required editors/views.
2. In the second option, whenever th euser logs off you can simply
redirect the browser to your original startup entry point.
Anup
Re: Login UI issue [message #97844 is a reply to message #78044] Sat, 12 July 2008 19:39 Go to previous messageGo to next message
Frank Appel schrieb:
> display creation
> while( !exit )
> loginShell
> createWorkbench
Hi Frank, that's exactly the idea I was looking for. However,
createworkbench works only once. When the loop is executed a second
time, the workbench does not start, bug 201545.
Do you know a workaround?
Frank.
Re: Login UI issue [message #98841 is a reply to message #97844] Fri, 18 July 2008 05:07 Go to previous message
The only workaround I could think of at the moment is to cleanup the
session completle. Somewhere on this list I described how to do this by
an URL "redirect" using the browser widget. Not nice but it worked...
Ciao
Frank
Von: Frank Gerhardt [mailto:fg@frankgerhardt.com]
Bereitgestellt: Sonntag, 13. Juli 2008 01:40
Betreff: Re: Login UI issue
in
> display creation
> while( !exit )
> loginShell
> createWorkbench
Frank.
Previous Topic:SWT graphics classes are internal in RWT (org.eclipse.swt.internal.graphics)
Next Topic:Update image for already redistered path
Current Time: Sat Jul 12 12:47:04 EDT 2025
Powered by FUDForum. Page generated in 0.25391 seconds
