Home » Eclipse Projects » GEF » Deleting an editpart
Deleting an editpart [message #77981] Tue, 06 May 2003 07:43 Go to next message
I have followed the Logic example when trying to implement the delete
functionality. Unfortunatley I've encountered a problem:
I have a ContextMenuProvider implementation and in its buildContextMenu()
method I check if the deleteAction.isEnabled(). The answer is no, and I
cannot obviously delete the selected editPart!! The deleteAction.isEnabled()
method returns false if there is no DeleteCommand created, and the
DeleteCommand is not created if there is nothing selected in the view...but
I can see with my own eyes that an editpart really is selected. Where is the
selection event caught or registered?
On my editpart I have set an editpolicy with the EditPolicy.COMPONENT_ROLE.
When right clicking on an editpart the DeleteCommand is created but in the
same time the opposite is reality when I check the deleteAction.isEnabled()
in the ContextMenuProvider implementation. I'm confused.
What should I do to make sure that the DeleteCommand is created on right
click selection so that the deleteAction really is enabled?
Thanks in advance.
/Stefan
Re: Deleting an editpart [message #78030 is a reply to message #77981] Tue, 06 May 2003 14:35 Go to previous messageGo to next message
After some time of serious debugging I have come to the following
conclusion:
First the Logic example. When initializing the logic editor it is registered
as an ISelectionChangedListener in the AbstractEditPartViewer class. When
selections are made in the logic edtior, the AbstractEditPartViewer loops
over its listeners and notifies them.
My implementation. I have pretty much followed the logic example but my
implementation differs on one point. My "GEF editor" is one page among many
in a MultiPageEditor. It seems as if the GEF editor in that page isn't
registered as an ISelectionChangedListener. On the other hand I think that
the MultiPageEditor is. That should do it but it doesn't.
My previous question has changed somewhat though I still have the same
problem. Creating a delete command on a selection event in the GEF editor
never happens since I haven't been able to register the editor at all.
/Stefan
"Stefan Junsved" <stefan.junsved@comactivity.net> wrote in message
news:b9874o$1g6$1@rogue.oti.com...
view...but
the
> Thanks in advance.
> /Stefan
Re: Deleting an editpart [message #78092 is a reply to message #78030] Tue, 06 May 2003 15:35 Go to previous messageGo to next message
The normal chain of events are:
1) User opens GraphicalEditor
2a) Editor registers GraphicalViewer as the selection provider into the
Selection Service.
2b) Editor adds itself as listener to selection service.
2c) Editor registers its internal DeleteAction as the global action handler
for "Delete"
3) User selected editpart
4) graphical editor receives notification from selection service, and calls
update() on the DeleteAction, which then calculates enablement.
news:b98va6$m2g$1@rogue.oti.com...
> conclusion:
registered
many
Then it sounds like your nested graphicaleditor is not calling update on the
DeleteAction.
> /Stefan
> > Hi,
buildContextMenu()
> view...but
> the
the
> > Thanks in advance.
> > /Stefan
Re: Deleting an editpart [message #78506 is a reply to message #78092] Thu, 08 May 2003 06:41 Go to previous messageGo to next message
Finally it works. The problem was that I didn't call the init(site, input)
method on
the GEF editor when switching to that page. I do that now from the
pageChange() method in the MPE.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:b992pl$oqt$1@rogue.oti.com...
> Selection Service.
handler
> for "Delete"
calls
> > conclusion:
> registered
When
loops
> many
that
the
> DeleteAction.
editor
> > /Stefan
> > > Hi,
> buildContextMenu()
I
> > view...but
is
> > the
> the
right
> > > Thanks in advance.
> > > /Stefan
Re: Deleting an editpart [message #78607 is a reply to message #78506] Thu, 08 May 2003 10:38 Go to previous messageGo to next message
calling init(site, input) more than once is not proper use of that API. The
behavior is undefined.
news:b9dc9i$lg7$1@rogue.oti.com...
> method on
> > Selection Service.
> handler
> > for "Delete"
> calls
> > > conclusion:
> > registered
> When
> loops
my
> > many
> that
> the
> > DeleteAction.
> editor
> > > /Stefan
> > > > Hi,
delete
> > buildContextMenu()
and
> I
> > > view...but
Where
> is
> > > the
in
> > the
> right
> > > > Thanks in advance.
> > > > /Stefan
Re: Deleting an editpart [message #80596 is a reply to message #78607] Fri, 23 May 2003 03:51 Go to previous message
The behavior I've experienced is a stack overflow which in turn crashes the
workbench.
I am now calling init only once and that has solved the problem.
news:b9dq54$1mi$1@rogue.oti.com...
The
input)
> > method on
the
> > > Selection Service.
> > handler
> > > for "Delete"
> > calls
> > > > conclusion:
> > > registered
> > When
> > loops
> my
among
> > > many
isn't
think
> > that
on
> > the
> > > DeleteAction.
same
> > editor
all.
> > > > /Stefan
> > > > > Hi,
> delete
> > > buildContextMenu()
> and
> > I
> > > > view...but
> Where
> > is
> > > > the
but
> in
> > > the
> > right
> > > > > Thanks in advance.
> > > > > /Stefan
Previous Topic:Org Chart/Hierarchical Tree Layout for 2.2
Next Topic:Move Bendpoints With ManhattanConnection Router
Current Time: Thu Jul 17 23:42:50 EDT 2025
Powered by FUDForum. Page generated in 1.31236 seconds
