Home » Archived » Visual Editor (VE) » Problem with ve 1.0.2 and java 1.5
Problem with ve 1.0.2 and java 1.5 [message #77959] Mon, 24 January 2005 14:15 Go to next message
Originally posted by: jtesser.nbbc.edu
I am using linux and eclipse 3.1m4. I have installed the gef, emf, and
ve. I also downloaded jdk 1.5 from sun's website and installed it. I
created a test project and and set my jre to 1.5 in the prefernces in
eclipse. The editor fails every time i have the jre set to 1.5 but if i
set it back to 1.4.2 it works fine. It gives a bunch of error boxes here
is the text from them
IWAV0138E Remote VM terminated too soon. See .log file for trace of
output. For VM "Project (swingtest)-VM for swingtest".
Then it says an internal error occurred during "Create Remote VM for
Visual Editor for java"
How can I fix this. Is it a bug or I am doing something wrong?
Re: Problem with ve 1.0.2 and java 1.5 [message #77993 is a reply to message #77959] Mon, 24 January 2005 15:40 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
The VE is not yet tested to work with 1.5, however, it should still
start it. Please attach the .log file. That should have a more complete
trace of why it couldn't start it.
Rich Kulp
Re: Problem with ve 1.0.2 and java 1.5 [message #78023 is a reply to message #77993] Mon, 24 January 2005 16:37 Go to previous messageGo to next message
Which log file do I send? WHere is it?
Re: Problem with ve 1.0.2 and java 1.5 [message #78038 is a reply to message #78023] Mon, 24 January 2005 17:11 Go to previous messageGo to next message
The .log in the workspace's .metadata directory.
Rich Kulp
Re: Problem with ve 1.0.2 and java 1.5 [message #78056 is a reply to message #77993] Mon, 24 January 2005 17:19 Go to previous messageGo to next message
OK i got the trace from the workspace log file It is long. I know I can
use this with jdk 1.5 in windows. I am starting eclipse with java 1.4.2
It is the jre in the eclipce preferences that I am changing. ANyways here
is the log
!SESSION 2005-01-24 16:16:46.414
eclipse.buildId=I20041216-2000
java.version=1.4.2_06
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:16:46.415
!MESSAGE
+++ Warning +++: Mon Jan 24 16:16:46 CST 2005 Project (testswing)-VM
for testswing:err>java.net.ConnectException: Connection refused
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:16:46.417
!MESSAGE
for testswing:err>
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:16:46.419
!MESSAGE
for testswing:err> at java.net.PlainSocketImpl.socketConnect(Native
Method)
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:16:46.421
!MESSAGE
for testswing:err>
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:16:46.422
!MESSAGE
java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:16:46.423
!MESSAGE
for testswing:err>
!MESSAGE
java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.ja va:195)
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:16:46.424
!MESSAGE
for testswing:err>
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:16:46.425
!MESSAGE
java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:16:46.426
!MESSAGE
for testswing:err>
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:16:46.427
!MESSAGE
java.net.SocksSocketImpl.connect(SocksSocketImpl.java:364)
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:16:46.441
!MESSAGE
for testswing:err>
at java.net.Socket.connect(Socket.java:507)
at java.net.Socket.connect(Socket.java:457)
at java.net.Socket.<init>(Socket.java:365)
at java.net.Socket.<init>(Socket.java:178)
org.eclipse.jem.internal.proxy.vm.remote.RemoteVMServerThrea d$2.run(RemoteVMServerThread.java:617)
at java.lang.Thread.run(Thread.java:595)
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:16:46.480
!MESSAGE IWAV0138E Remote VM terminated too soon. See .log file for trace
of output. For VM "Project (testswing)-VM for testswing".
IWAV0072I Remote VM terminated before any commands can be sent. Following
are the error and output streams.
-- Error Stream --
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:364)
-- Output Stream --
Couldn't retrieve a socket from master server in 60 seconds.
-- End of Stream Output --
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:16:46.546
!MESSAGE
(testswing)-Beaninfo:err>java.net.ConnectException: Connection refused
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:16:46.547
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:16:46.548
!MESSAGE
(testswing)-Beaninfo:err> at
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:16:46.549
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:16:46.551
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:16:46.552
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:16:46.553
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:16:46.554
!MESSAGE
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:16:46.555
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:16:46.556
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:16:46.568
!MESSAGE
!ENTRY org.eclipse.ui 4 4 2005-01-24 16:16:51.578
!MESSAGE The command 'org.eclipse.ui.edit.delete' is not defined, but is
being asked if it is active. Are you using an actionDefinitionId without
defining a command?
!ENTRY org.eclipse.ui 4 0 2005-01-24 16:16:51.579
!MESSAGE The command is undefined
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:17:45.954
!MESSAGE No Server to retrieve a connection.
!ENTRY org.eclipse.core.runtime 4 2 2005-01-24 16:17:45.955
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.runtime".
!STACK 0
java.lang.IllegalStateException: IWAV0171E Could not create a socket
connection to remote vm.
org.eclipse.jem.internal.proxy.remote.REMProxyFactoryRegistr y.createConnection(REMProxyFactoryRegistry.java:399)
org.eclipse.jem.internal.proxy.remote.REMProxyFactoryRegistr y.getFreeConnection(REMProxyFactoryRegistry.java:334)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.getBeanTypeProxy(REMStandardBeanTypeProxyFactory.j ava:286)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.getBeanTypeProxy(REMStandardBeanTypeProxyFactory.j ava:237)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorVMController$1.contributeToRegistry(JavaVisualEditorVMCo ntroller.java:153)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport$3.run (ProxyLaunchSupport.java:445)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:439)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:295)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:227)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorVMController$CreateRegistry.run(JavaVisualEditorVMContro ller.java:164)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:17:45.968
!ENTRY org.eclipse.core.runtime 4 2 2005-01-24 16:17:45.968
!STACK 0
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoProxyCons tants. <init>(BeaninfoProxyConstants.java:98)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoProxyCons tants.getConstants(BeaninfoProxyConstants.java:89)
org.eclipse.jem.internal.beaninfo.core.Utilities.setBeanInfo SearchPath(Utilities.java:332)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoNature.se tProxySearchPath(BeaninfoNature.java:427)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoNature$Co nfigurationContributor.contributeToRegistry(BeaninfoNature.j ava:935)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoNature.cr eateRegistry(BeaninfoNature.java:393)
org.eclipse.jem.internal.beaninfo.adapters.CreateRegistryJob Handler.doCreateRegistry(CreateRegistryJobHandler.java:154)
org.eclipse.jem.internal.beaninfo.adapters.CreateRegistryJob Handler.processCreateRegistry(CreateRegistryJobHandler.java: 109)
org.eclipse.jem.internal.beaninfo.adapters.UICreateRegistryJ obHandler.processCreateRegistry(UICreateRegistryJobHandler.j ava:52)
org.eclipse.jem.internal.beaninfo.adapters.CreateRegistryJob Handler.createRegistry(CreateRegistryJobHandler.java:75)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoNature.ge tRegistry(BeaninfoNature.java:374)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoNature$6. getRegistry(BeaninfoNature.java:312)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoAdapterFa ctory.getRegistry(BeaninfoAdapterFactory.java:78)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.getRegistry(BeaninfoClassAdapter.java:275)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.applyExtensionDocument(BeaninfoClassAdapter.java:510)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspect(BeaninfoClassAdapter.java:437)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspectIfNecessary(BeaninfoClassAdapter.java:394)
org.eclipse.jem.java.impl.JavaClassImpl.getEAnnotations(Java ClassImpl.java:339)
org.eclipse.ve.internal.cde.emf.ClassDecoratorSourceIterator .findDecorator(ClassDecoratorSourceIterator.java:37)
org.eclipse.ve.internal.cde.emf.ClassDecoratorIterator.initi alize(ClassDecoratorIterator.java:47)
org.eclipse.ve.internal.cde.emf.ClassDecoratorSourceIterator . <init>(ClassDecoratorSourceIterator.java:33)
org.eclipse.ve.internal.cde.emf.ClassDecoratorFeatureAccess. getDecoratorWithFeature(ClassDecoratorFeatureAccess.java:67)
org.eclipse.ve.internal.java.codegen.java.rules.InstanceVari ableCreationRule.getDefaultBooleanValue(InstanceVariableCrea tionRule.java:70)
org.eclipse.ve.internal.java.codegen.java.rules.InstanceVari ableCreationRule.isModelled(InstanceVariableCreationRule.jav a:97)
org.eclipse.ve.internal.java.codegen.java.rules.InstanceVari ableRule.isModelled(InstanceVariableRule.java:114)
org.eclipse.ve.internal.java.codegen.java.rules.InstanceVari ableRule.ignoreVariable(InstanceVariableRule.java:46)
org.eclipse.ve.internal.java.codegen.java.TypeVisitor.visit( TypeVisitor.java:151)
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.visitType(JavaBeanModelBuilder.java:406)
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.build(JavaBeanModelBuilder.java:372)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:877)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(JavaSourceTranslator.java:656)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1444)
!ENTRY org.eclipse.core.runtime 4 2 2005-01-24 16:17:45.975
!MESSAGE An internal error occurred during: "Create Remote VM for Visual
Editor for Java".
!STACK 0
java.lang.RuntimeException: IWAV0067E No Standard Bean Type Proxy Factory
has been set.
org.eclipse.jem.internal.proxy.core.ProxyFactoryRegistry.get BeanTypeProxyFactory(ProxyFactoryRegistry.java:174)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorVMController$CreateRegistry.run(JavaVisualEditorVMContro ller.java:168)
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:17:45.999
of output. For VM "Project (testswing)-Beaninfo".
-- Error Stream --
-- Output Stream --
!ENTRY org.eclipse.jem.beaninfo 2 0 2005-01-24 16:17:46.17
!MESSAGE IWAV0155E Introspection failed on class "javax.swing.JPanel."
msg="."
!STACK 0
org.eclipse.jem.internal.beaninfo.core.BeaninfoPlugin.applyO verrides(BeaninfoPlugin.java:481)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.applyExtensionDocTo(BeaninfoClassAdapter.java:523)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.applyExtensionDocument(BeaninfoClassAdapter.java:519)
!ENTRY org.eclipse.ve.java.core 4 16 2005-01-24 16:17:46.102
Editor for Java".
!STACK 1
org.eclipse.core.runtime.CoreException[2]: java.lang.RuntimeException:
IWAV0067E No Standard Bean Type Proxy Factory has been set.
!SUBENTRY 1 org.eclipse.core.runtime 4 2 2005-01-24 16:17:46.103
Editor for Java".
!STACK 0
has been set.
!ENTRY org.eclipse.ui 4 4 2005-01-24 16:17:46.266
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2005-01-24 16:17:46.267
!MESSAGE Failed to execute runnable (java.lang.NullPointerException)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
at org.eclipse.swt.SWT.error(SWT.java:2827)
at org.eclipse.swt.SWT.error(SWT.java:2752)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:121)
org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2675)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2400)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:718 )
at org.eclipse.jface.window.Window.open(Window.java:696)
at org.eclipse.jface.dialogs.ErrorDialog.open(ErrorDialog.java: 274)
org.eclipse.ui.internal.progress.ErrorNotificationManager.op enErrorDialog(ErrorNotificationManager.java:171)
org.eclipse.ui.internal.progress.ErrorNotificationManager.ac cess$2(ErrorNotificationManager.java:157)
org.eclipse.ui.internal.progress.ErrorNotificationManager$2. runInUIThread(ErrorNotificationManager.java:131)
at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:96)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:118)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1569)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1540)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:285)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:144)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:102)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:220)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:710)
at org.eclipse.core.launcher.Main.main(Main.java:694)
!ENTRY org.eclipse.ui 4 4 2005-01-24 16:17:46.282
!MESSAGE *** SWT nested exception
!ENTRY org.eclipse.ui 4 0 2005-01-24 16:17:46.283
!MESSAGE java.lang.NullPointerException
!STACK 0
org.eclipse.jface.dialogs.ErrorDialog.toggleDetailsArea(Erro rDialog.java:430)
org.eclipse.jface.dialogs.ErrorDialog.showDetailsArea(ErrorD ialog.java:507)
org.eclipse.ui.internal.progress.JobErrorDialog.refresh(JobE rrorDialog.java:100)
org.eclipse.ui.internal.progress.ErrorNotificationManager$2. runInUIThread(ErrorNotificationManager.java:122)
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:17:46.565
!MESSAGE
+++ Warning +++: Mon Jan 24 16:17:46 CST 2005 Project
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:17:46.566
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:17:46.568
!MESSAGE
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:17:46.569
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:17:46.570
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:17:46.571
!MESSAGE
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:17:46.572
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:17:46.573
!MESSAGE
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:17:46.585
!MESSAGE
!ENTRY org.eclipse.jem.proxy 2 0 2005-01-24 16:17:46.624
-- Error Stream --
-- Output Stream --
Re: Problem with ve 1.0.2 and java 1.5 [message #78087 is a reply to message #78056] Mon, 24 January 2005 17:52 Go to previous messageGo to next message
There is a socket problem when you load 1.5. Are you on SUSE? If so then
you need to go to the etc/.hosts file. In there there is a double
definition of localHost. One is for 127.0.0.1 and the other is for :::1
(or something like that). Remove the localHost definition from the line
that is NOT 127.0.0.1.
> trace of output. For VM "Project (testswing)-VM for testswing".
> Following are the error and output streams.
> -- Error Stream --
> at
> at
Rich Kulp
Re: Problem with ve 1.0.2 and java 1.5 [message #78130 is a reply to message #78087] Mon, 24 January 2005 20:34 Go to previous messageGo to next message
Originally posted by: rainer.lay.informatik.uni-erlangen.de
I have SuSE 9.2 with java 1.5 and VE 1.0.2 too and I also cannot start
ve. I get a setup error. In the logs, I found:
java.lang.NoClassDefFoundError:
org/eclipse/jem/internal/plugin/JavaEMFNature
Where do I get the required?
I installed ve via eclipse update mechanism and I am wondering, how a
class file can be missing. BTW, I have several EMF files ...
rgds, Rainer
>> -- Error Stream --
>> at
>> at
Re: Problem with ve 1.0.2 and java 1.5 [message #78144 is a reply to message #78130] Mon, 24 January 2005 21:27 Go to previous messageGo to next message
To make it more clear: regarding to Product Configuration, I have EMF
Version 2.0.1 installed.
I am now wondering, why theis class file is missing and where I get it.
rgds, Rainer
> rgds, Rainer
>> then you need to go to the etc/.hosts file. In there there is a double
>> :::1 (or something like that). Remove the localHost definition from
>> the line that is NOT 127.0.0.1.
>>> -- Error Stream --
>>> at
>>> at
Re: Problem with ve 1.0.2 and java 1.5 [message #78172 is a reply to message #78144] Tue, 25 January 2005 09:51 Go to previous messageGo to next message
Did you use update manager or did you unzip fromthe download page? If
you unzipped, did you start eclipse with -clean?
Your's is a different situation then the original one. The original was
a connection refused. Your's indicates an Eclipse configuration or
installation error.
Rich Kulp
Re: Problem with ve 1.0.2 and java 1.5 [message #78303 is a reply to message #78172] Tue, 25 January 2005 16:42 Go to previous messageGo to next message
I installed this ve via the update manager.
First installed version 1.0.1? than upgraded 1.0.1.1 and than updated to
1.0.2. I DID NOT download and unzip the file manually.
I also tried -clean. It did not really help.
Grepping .log for class files not found returns:
com.ibm.wtp.internal.emf.workbench.ProjectResourceSetImpl.se tURIResourceMap(Ljava/util/Map;)V
java.lang.NoSuchMethodError:
org.eclipse.ve.internal.jcm.impl.JCMPackageImpl.freeze()V
What should I install?
> installation error.
Re: Problem with ve 1.0.2 and java 1.5 [message #78333 is a reply to message #78303] Tue, 25 January 2005 17:05 Go to previous messageGo to next message
After you upgraded to 1.02, did you then go and uninstall VE 1.0.1.1
through the update manager? If you did, that would explain the errors.
There is an Eclipse bug with the uninstall process when a subfeature of
the same version is shared between two different versions of an
enclosing feature. It doesn't recognize this and it goes and deletes the
subfeature, even though it still is required by the newer version. This
has been fixed in the latest Eclipse 3.1 builds.
If you had done that the only thing you can do is to get the JEM 1.0.2
runtime or SDK zip (depending on whether you installed VE runtime or
SDK) and unzipping that overtop of your installation and then starting
with -clean.
Rich Kulp
Re: Problem with ve 1.0.2 and java 1.5 [message #78349 is a reply to message #78333] Tue, 25 January 2005 17:26 Go to previous messageGo to next message
--------------040508080602040405050405
Content-Type: text/plain; charset=us-ascii; format=flowed
I did what you told me: unzipped JEM-runtime-1.0.2.zip in /opt/eclipse
and startet eclipse -clean.
Same problem. I am attaching the log file.
Changing to java 1.4 did not help anything :-(
any hints?
> with -clean.
name=".log"
Content-Disposition: inline;
filename=".log"
!SESSION Jan 25, 2005 23:17:48.463 ---------------------------------------------
eclipse.buildId=I200406251208
java.version=1.5.0_01
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=de_DE
!ENTRY org.eclipse.core.filebuffers 4 0 Jan 25, 2005 23:17:48.479
!MESSAGE The content type with id "com.objfac.xmlbuddy.xmlfile" specified in the extension point does not exist.
!ENTRY org.tigris.subversion.subclipse.core 4 -6 Jan 25, 2005 23:17:53.779
!MESSAGE Javahl client adapter is not available
!STACK 0
org.tigris.subversion.svnclientadapter.SVNClientException: Javahl client adapter is not available
at org.tigris.subversion.svnclientadapter.javahl.JhlClientAdapt erFactory.setup(JhlClientAdapterFactory.java:48)
at org.tigris.subversion.subclipse.core.SVNClientManager.startu p(SVNClientManager.java:40)
at org.tigris.subversion.subclipse.core.SVNProviderPlugin.start (SVNProviderPlugin.java:120)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:958)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:954)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:937)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:421)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:293)
at org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:110)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:371)
at org.eclipse.osgi.framework.internal.core.BundleLoader.requir eClass(BundleLoader.java:336)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findRe quiredClass(BundleLoader.java:914)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:399)
at org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:93)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319 )
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:23 28)
at java.lang.Class.getConstructor0(Class.java:2640)
at java.lang.Class.newInstance0(Class.java:321)
at java.lang.Class.newInstance(Class.java:303)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:153)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:933)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:402)
at org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:307)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:336)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1313)
at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:131)
at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:124)
at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:113)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:196)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:51)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:193)
at org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition$1.run(LightweightDecoratorDefinition.java:83)
at org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:616)
at org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition.internalGetDecorator(LightweightDecoratorDefinition.ja va:79)
at org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition.decorate(LightweightDecoratorDefinition.java:153)
at org.eclipse.ui.internal.decorators.LightweightDecoratorManag er$LightweightRunnable.run(LightweightDecoratorManager.java: 60)
at org.eclipse.ui.internal.decorators.LightweightDecoratorManag er.decorate(LightweightDecoratorManager.java:258)
at org.eclipse.ui.internal.decorators.LightweightDecoratorManag er.getDecorations(LightweightDecoratorManager.java:241)
at org.eclipse.ui.internal.decorators.DecorationScheduler$1.run (DecorationScheduler.java:264)
!ENTRY org.eclipse.osgi Jan 25, 2005 23:18:49.503
!MESSAGE An error occured while automatically activating bundle org.eclipse.jem.workbench (42).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.jem.internal.plugin.JavaPlugin.start() of bundle org.eclipse.jem.workbench.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:975)
at org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.initializeForProject(JavaVisualEditorPart.jav a:1822)
at org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.initialize(JavaVisualEditorPart.java:1717)
at org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1518)
Caused by: java.lang.NoSuchMethodError: com.ibm.wtp.internal.emf.workbench.ProjectResourceSetImpl.se tURIResourceMap(Ljava/util/Map;)V
at com.ibm.wtp.internal.emf.workbench.ProjectResourceSetImpl.<init >(ProjectResourceSetImpl.java:28)
at com.ibm.wtp.internal.emf.workbench.ProjectResourceSetImpl.<init >(ProjectResourceSetImpl.java:31)
at com.ibm.wtp.emf.workbench.plugin.EMFWorkbenchPlugin.getPlugi nResourceSet(EMFWorkbenchPlugin.java:134)
at org.eclipse.jem.internal.plugin.JavaPlugin.start(JavaPlugin. java:64)
... 15 more
Root exception:
!ENTRY org.eclipse.core.runtime 4 2 Jan 25, 2005 23:18:49.509
!MESSAGE An internal error occurred during: "Setup Java Visual Editor".
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/jem/internal/plugin/JavaEMFNature
!ENTRY org.eclipse.core.runtime 4 2 Jan 25, 2005 23:18:50.320
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.core.runtime".
!STACK 0
java.lang.NoSuchMethodError: org.eclipse.ve.internal.jcm.impl.JCMPackageImpl.freeze()V
at org.eclipse.ve.internal.jcm.impl.JCMPackageImpl.init(JCMPack ageImpl.java:247)
at org.eclipse.ve.internal.jcm.JCMPackage.<clinit>(JCMPackage.java:71)
at org.eclipse.ve.internal.java.vce.SubclassCompositionContaine rPolicy. <init>(SubclassCompositionContainerPolicy.java:34)
at org.eclipse.ve.internal.java.vce.SubclassCompositionComponen tsGraphicalEditPart.getContainerPolicy(SubclassCompositionCo mponentsGraphicalEditPart.java:39)
at org.eclipse.ve.internal.java.core.CompositionComponentsGraph icalEditPart.createEditPolicies(CompositionComponentsGraphic alEditPart.java:51)
at org.eclipse.gef.editparts.AbstractEditPart.addNotify(Abstrac tEditPart.java:228)
at org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotif y(AbstractGraphicalEditPart.java:212)
at org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:196)
at org.eclipse.gef.editparts.FreeformGraphicalRootEditPart.setC ontents(FreeformGraphicalRootEditPart.java:303)
at org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents( AbstractEditPartViewer.java:581)
at org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.createGraphicalViewer(JavaVisualEditorPart.java:745 )
at org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.createPrimaryViewer(JavaVisualEditorPart.java:725)
at org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.createSplitpaneEditor(JavaVisualEditorPart.java:525 )
at org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.createPartControl(JavaVisualEditorPart.java:464)
at org.eclipse.ui.internal.PartPane$2.run(PartPane.java:137)
at org.eclipse.ui.internal.PartPane.createChildControl(PartPane .java:133)
at org.eclipse.ui.internal.PartPane.createControl(PartPane.java :205)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:939)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:921)
at org.eclipse.ui.internal.EditorStack.setSelection(EditorStack .java:196)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:10 20)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:290)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:121 )
at org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:59)
at org.eclipse.ui.internal.EditorAreaHelper.openEditor(EditorAr eaHelper.java:266)
at org.eclipse.ui.internal.EditorManager$4.run(EditorManager.ja va:694)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:683)
at org.eclipse.ui.internal.EditorManager.openInternalEditor(Edi torManager.java:779)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:582)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:570)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2244)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2177)
at org.eclipse.ui.internal.WorkbenchPage.access$6(WorkbenchPage .java:2169)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2156)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2151)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2134)
at org.eclipse.ui.actions.OpenWithMenu.openEditor(OpenWithMenu. java:258)
at org.eclipse.ui.actions.OpenWithMenu.access$0(OpenWithMenu.ja va:251)
at org.eclipse.ui.actions.OpenWithMenu$2.handleEvent(OpenWithMe nu.java:166)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:954)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2595)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2298)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
!SESSION Jan 25, 2005 23:24:56.395 ---------------------------------------------
!ENTRY org.eclipse.core.filebuffers 4 0 Jan 25, 2005 23:24:56.396
!ENTRY org.eclipse.core.runtime 4 2 Jan 25, 2005 23:24:59.544
!STACK 0
at org.eclipse.ui.internal.EditorManager.access$12(EditorManage r.java:763)
at org.eclipse.ui.internal.EditorManager$9.run(EditorManager.ja va:948)
at org.eclipse.ui.internal.EditorManager.busyRestoreEditor(Edit orManager.java:922)
at org.eclipse.ui.internal.EditorManager$8.run(EditorManager.ja va:915)
at org.eclipse.ui.internal.EditorManager.restoreEditor(EditorMa nager.java:911)
at org.eclipse.ui.internal.EditorManager.restoreEditorState(Edi torManager.java:1487)
at org.eclipse.ui.internal.EditorManager.restoreState(EditorMan ager.java:874)
at org.eclipse.ui.internal.WorkbenchPage.restoreState(Workbench Page.java:2470)
at org.eclipse.ui.internal.WorkbenchWindow.restoreState(Workben chWindow.java:1372)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1224)
at org.eclipse.ui.internal.Workbench.access$10(Workbench.java:1 185)
at org.eclipse.ui.internal.Workbench$13.run(Workbench.java:1096 )
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1029)
at org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(Wor kbenchConfigurer.java:167)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:652)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:819)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1325)
!ENTRY org.eclipse.osgi Jan 25, 2005 23:25:03.141
!STACK 0
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:302 )
... 15 more
Root exception:
!ENTRY org.eclipse.core.runtime 4 2 Jan 25, 2005 23:25:03.170
!STACK 0
!ENTRY org.tigris.subversion.subclipse.core 4 -6 Jan 25, 2005 23:25:03.607
!STACK 0
at java.lang.Class.privateGetDeclaredConstructors(Class.java:16 18)
at java.lang.Class.getConstructor0(Class.java:1930)
at java.lang.Class.newInstance0(Class.java:278)
at java.lang.Class.newInstance(Class.java:261)
--------------040508080602040405050405--
Re: Problem with ve 1.0.2 and java 1.5 [message #78365 is a reply to message #78349] Tue, 25 January 2005 18:09 Go to previous messageGo to next message
I'm not sure you have the final released EMF 2.0.1 installed. The errors
indicate you are using an older version of EMF. Make sure you have the
final released version of 2.0.1 and not some pre-finalized development
build. It should be the Sept. 17, 2004 build of EMF 2.0.1. If you have
an earlier development build the methods we need may not be there.
Rich Kulp
Re: Problem with ve 1.0.2 and java 1.5 [message #78379 is a reply to message #78365] Tue, 25 January 2005 18:30 Go to previous message
that it! I re-installed emf and xsd and it is working now!
tanx a lot, Rainer
Re: Problem with ve 1.0.2 and java 1.5 [message #604783 is a reply to message #77959] Mon, 24 January 2005 15:40 Go to previous message
Rich Kulp
Re: Problem with ve 1.0.2 and java 1.5 [message #604787 is a reply to message #77993] Mon, 24 January 2005 16:37 Go to previous message
Re: Problem with ve 1.0.2 and java 1.5 [message #604790 is a reply to message #78023] Mon, 24 January 2005 17:11 Go to previous message
Rich Kulp
Re: Problem with ve 1.0.2 and java 1.5 [message #604792 is a reply to message #77993] Mon, 24 January 2005 17:19 Go to previous message
is the log
!MESSAGE
!MESSAGE
for testswing:err>
!MESSAGE
Method)
!MESSAGE
for testswing:err>
!MESSAGE
!MESSAGE
for testswing:err>
!MESSAGE
!MESSAGE
for testswing:err>
!MESSAGE
!MESSAGE
for testswing:err>
!MESSAGE
!MESSAGE
for testswing:err>
-- Error Stream --
-- Output Stream --
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
defining a command?
!STACK 0
!STACK 0
Editor for Java".
!STACK 0
has been set.
-- Error Stream --
-- Output Stream --
msg="."
!STACK 0
Editor for Java".
!STACK 1
Editor for Java".
!STACK 0
has been set.
!STACK 0
!STACK 0
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
-- Error Stream --
-- Output Stream --
Re: Problem with ve 1.0.2 and java 1.5 [message #604797 is a reply to message #78056] Mon, 24 January 2005 17:52 Go to previous message
> -- Error Stream --
> at
> at
Rich Kulp
Re: Problem with ve 1.0.2 and java 1.5 [message #604804 is a reply to message #78087] Mon, 24 January 2005 20:34 Go to previous message
rgds, Rainer
>> -- Error Stream --
>> at
>> at
Re: Problem with ve 1.0.2 and java 1.5 [message #604806 is a reply to message #78130] Mon, 24 January 2005 21:27 Go to previous message
rgds, Rainer
> rgds, Rainer
>>> -- Error Stream --
>>> at
>>> at
Re: Problem with ve 1.0.2 and java 1.5 [message #604812 is a reply to message #78144] Tue, 25 January 2005 09:51 Go to previous message
installation error.
Rich Kulp
Re: Problem with ve 1.0.2 and java 1.5 [message #604835 is a reply to message #78172] Tue, 25 January 2005 16:42 Go to previous message
> installation error.
Re: Problem with ve 1.0.2 and java 1.5 [message #604841 is a reply to message #78303] Tue, 25 January 2005 17:05 Go to previous message
with -clean.
Rich Kulp
Re: Problem with ve 1.0.2 and java 1.5 [message #604844 is a reply to message #78333] Tue, 25 January 2005 17:26 Go to previous message
any hints?
> with -clean.
name=".log"
filename=".log"
!STACK 0
!STACK 0
... 15 more
Root exception:
!STACK 0
!STACK 0
!STACK 0
!STACK 0
... 15 more
Root exception:
!STACK 0
!STACK 0
Re: Problem with ve 1.0.2 and java 1.5 [message #604846 is a reply to message #78349] Tue, 25 January 2005 18:09 Go to previous message
Rich Kulp
Re: Problem with ve 1.0.2 and java 1.5 [message #604849 is a reply to message #78365] Tue, 25 January 2005 18:30 Go to previous message
tanx a lot, Rainer
Previous Topic:How to create/associate a swing popup memu in/with a textfield by using VE
Next Topic:How to set what VE does ?
Current Time: Tue Jul 15 13:21:13 EDT 2025
Powered by FUDForum. Page generated in 0.36452 seconds
