Home » Eclipse Projects » Eclipse Platform » Debug stack is blank, .log has StringIndexOutOfBoundsException
Debug stack is blank, .log has StringIndexOutOfBoundsException [message #77953] Wed, 18 June 2003 14:02 Go to next message
Originally posted by: magellan94.hotmail.com
Has anybody seen this problem? I recently upgraded from 2.1 to 3.0 M1, and I
am seeing an exception in the debug perspective. As soon as execution hits a
breakpoint, the debugger becomes active and Eclipse tries to update the
debug view. Suddenly, a dialog appears to tell me that an error has occurred
and that I should check the metadata/.log file for error messages. The .log
file shows a stack trace for a java.lang.StringIndexOutOfBoundsException
(see below for the entire stack trace.) After dismissing the dialog, the
stack view in the debugger his blank lines where the stack frames should be.
Closing and reopening the debug view clears the problem, but it crops up
again the next time a breakpoint is hit. Is this a known bug? Does anybody
know the cause? If nobody has seen it, I'll log the bug.
Here's the system information output in my eclipse log:
java.version=1.4.2-beta
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Command-line arguments: -os win32 -ws win32 -arch x86 -data -install
file:E:/java/eclipse/current/eclipse/
Thanks, Dave
[stack trace from .log]
!MESSAGE Unhandled exception caught in event loop.
!ENTRY org.eclipse.ui 4 0 Jun 09, 2003 17:43:17.420
!MESSAGE String index out of range: 0
!STACK 0
java.lang.StringIndexOutOfBoundsException: String index out of range: 0
at java.lang.StringBuffer.charAt(StringBuffer.java:274)
org.eclipse.jdi.internal.SourceDebugExtensionParser.getNonAs teriskString(Sou
rceDebugExtensionParser.java:514)
org.eclipse.jdi.internal.SourceDebugExtensionParser.parseFil eInfo(SourceDebu
gExtensionParser.java:405)
org.eclipse.jdi.internal.SourceDebugExtensionParser.parseFil eSection(SourceD
ebugExtensionParser.java:378)
org.eclipse.jdi.internal.SourceDebugExtensionParser.parseStr atumSection(Sour
ceDebugExtensionParser.java:338)
org.eclipse.jdi.internal.SourceDebugExtensionParser.parseSec tions(SourceDebu
gExtensionParser.java:310)
org.eclipse.jdi.internal.SourceDebugExtensionParser.parseSma p(SourceDebugExt
ensionParser.java:278)
org.eclipse.jdi.internal.SourceDebugExtensionParser.parse(So urceDebugExtensi
onParser.java:260)
org.eclipse.jdi.internal.ReferenceTypeImpl.getSourceDebugExt ension(Reference
TypeImpl.java:1516)
org.eclipse.jdi.internal.ReferenceTypeImpl.isSourceDebugExte nsionAvailable(R
eferenceTypeImpl.java:1562)
org.eclipse.jdi.internal.ReferenceTypeImpl.getStratum(Refere nceTypeImpl.java
:1478)
org.eclipse.jdi.internal.ReferenceTypeImpl.lineNumber(Refere nceTypeImpl.java
:1712)
at org.eclipse.jdi.internal.LocationImpl.lineNumber(LocationImp l.java:163)
at org.eclipse.jdi.internal.LocationImpl.lineNumber(LocationImp l.java:109)
org.eclipse.jdt.internal.debug.core.model.JDIStackFrame.getL ineNumber(JDISta
ckFrame.java:330)
org.eclipse.jdt.internal.debug.ui.JDIModelPresentation.getSt ackFrameText(JDI
ModelPresentation.java:1388)
org.eclipse.jdt.internal.debug.ui.JDIModelPresentation.getTe xt(JDIModelPrese
ntation.java:201)
org.eclipse.debug.internal.ui.LazyModelPresentation.getText( LazyModelPresent
ation.java:74)
org.eclipse.debug.internal.ui.DelegatingModelPresentation.ge tText(Delegating
ModelPresentation.java:127)
org.eclipse.debug.internal.ui.actions.CopyToClipboardActionD elegate.append(C
opyToClipboardActionDelegate.java:86)
opyToClipboardActionDelegate.java:93)
org.eclipse.debug.internal.ui.actions.CopyToClipboardActionD elegate.doAction
(CopyToClipboardActionDelegate.java:74)
org.eclipse.debug.internal.ui.actions.CopyToClipboardActionD elegate$1.run(Co
pyToClipboardActionDelegate.java:127)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.debug.internal.ui.actions.CopyToClipboardActionD elegate.run(Copy
ToClipboardActionDelegate.java:123)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:263)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(Action
ContributionItem.java:542)
org.eclipse.jface.action.ActionContributionItem.access$4(Act ionContributionI
tem.java:496)
org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContribu
tionItem.java:468)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :81)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:848)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2034)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1741)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1399)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1382)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.jav
a:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Re: Debug stack is blank, .log has StringIndexOutOfBoundsException [message #80766 is a reply to message #77953] Mon, 23 June 2003 11:55 Go to previous message
Originally posted by: John_Arthorne.oti.com_
You should just enter the bug report. If it is a duplicate, they can
easily close it.
> Thanks, Dave
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> onParser.java:260)
> at
> TypeImpl.java:1516)
> at
> at
> :1478)
> at
> :1712)
> at
> ckFrame.java:330)
> at
> at
> ntation.java:201)
> at
> ation.java:74)
> at
> at
> at
> at
> at
> at
> at
> at
> tem.java:496)
> at
> tionItem.java:468)
> at
> a:858)
> at
> at
> .java:25)
Previous Topic:CVS Compare of ASCII file give _binary_ compare error
Next Topic:CVS integration build I20030618
Current Time: Sat Jul 26 06:04:11 EDT 2025
Powered by FUDForum. Page generated in 0.06757 seconds
