Home » Language IDEs » ServerTools (WTP) » can WTP1.0M3 work on Eclipse-SDK 3.0.1?
can WTP1.0M3 work on Eclipse-SDK 3.0.1? [message #77869] Sun, 27 February 2005 21:06 Go to next message
hi everyone,
I've installed wtp 1.0M3 on eclipse 3.0.1, but I saw lots of error box.
My question is :
Does WTP 1.0M3 only work on Eclipse 3.1M5a platform?
This is one part of the eclise log file:
!ENTRY org.eclipse.core.runtime 4 2 2 28, 2005 09:14:59.93
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.runtime".
!STACK 0
java.lang.NoSuchMethodError:
org.eclipse.core.runtime.IConfigurationElement.getNamespace( )Ljava/lang/String;
org.eclipse.wst.common.dependencychecker.CheckMissingFiles.g etMissingFiles(CheckMissingFiles.java:87)
org.eclipse.wst.common.dependencychecker.CheckMissingFiles.e arlyStartup(CheckMissingFiles.java:45)
org.eclipse.ui.internal.EarlyStartupRunnable.runEarlyStartup (EarlyStartupRunnable.java:81)
org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartu pRunnable.java:61)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:616)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
at org.eclipse.ui.internal.Workbench$15.run(Workbench.java:1283 )
at java.lang.Thread.run(Unknown Source)
!ENTRY org.eclipse.ui 4 4 2 28, 2005 09:14:59.93
!MESSAGE Unhandled Exception
!ENTRY org.eclipse.wst.common.dependencychecker 4 0 2 28, 2005 09:14:59.109
!MESSAGE Unable to execute early startup code for an extension
!STACK 0
thanks in advance!
Re: can WTP1.0M3 work on Eclipse-SDK 3.0.1? [message #77901 is a reply to message #77869] Sun, 27 February 2005 22:44 Go to previous messageGo to next message
webster wrote:
> hi everyone,
> My question is :
> =========================================================== Does WTP
> !STACK 0
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> thanks in advance!
Yes, WTP 1.0 M3 works only on Eclipse 3.1M5a platform.
- Vijay
Re: can WTP1.0M3 work on Eclipse-SDK 3.0.1? [message #78243 is a reply to message #77869] Mon, 28 February 2005 10:37 Go to previous message
> My question is :
Yes, it was designed for and only tested with Eclipse 3.1M5a (and
whatever else is posted on the download page).
Previous Topic:Error copying M3 files to plugins folder
Next Topic:tab character (M3)
Current Time: Sun Aug 31 11:20:19 EDT 2025
Powered by FUDForum. Page generated in 0.10163 seconds
