Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Mechanism for updating the ecore-model and the database automatically?!
[Teneo] Mechanism for updating the ecore-model and the database automatically?! [message #77836] Sat, 31 March 2007 06:41 Go to next message
Hi again,
I just wondered if there is a possibility to update the ecore-model (and
therefore using a new hiber-mapping file) and to let Teneo update the
database, so that the stored objects remain valid. Of course this can only
work, if the new ecore-file and the old one are compatible (e.g. adding a
new field to an element).
My first idea was to export the datastore, make the changes manually in die
xml-file, and then import the datastore. But maybe there is another
mechanism?!
Markus
Re: [Teneo] Mechanism for updating the ecore-model and the database automatically?! [message #77866 is a reply to message #77836] Sat, 31 March 2007 13:56 Go to previous message
Hi Markus,
Both Hibernate and Jpox will automatically add new fields, tables and database constraints when
Teneo is initialized. All within a certain reasonable set of schema changes ofcourse.
Note that:
- The database schema update adds fields but does not set their default value (as far as I know). So
if you add a non-nullable field then you have to set the default value separately.
- There is an option in Teneo to disable the update of the database schema but as a default the
database schema will be updated.
gr. Martin
Markus Bischof wrote:
> Hi again,
> mechanism?!
> Markus
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Mechanism for updating the ecore-model and the database automatically?! [message #604161 is a reply to message #77836] Sat, 31 March 2007 13:56 Go to previous message
Hi Markus,
Note that:
gr. Martin
> Hi again,
> mechanism?!
> Markus
The Netherlands
Previous Topic:[Teneo] Mechanism for updating the ecore-model and the database automatically?!
Next Topic:[teneo]:Newbie tutorial1 question
Current Time: Mon Jul 21 23:54:33 EDT 2025
Powered by FUDForum. Page generated in 0.26397 seconds
